2407的92脚和19脚功能是不是都是用来指示和外部器件通讯的方
2266|4
 楼主| snakeemail 发表于 2007-8-2 15:48 | 显示全部楼层 |阅读模式
只不过它们的状态正好相反,当读时,一个为高,一个为低<br /><br />PIN92(R/W):<br />Read/write&nbsp;qualifier&nbsp;signal.&nbsp;R/W&nbsp;indicates&nbsp;transfer<br />direction&nbsp;during&nbsp;communication&nbsp;to&nbsp;an&nbsp;external<br />device.&nbsp;It&nbsp;is&nbsp;normally&nbsp;in&nbsp;read&nbsp;mode&nbsp;(high),&nbsp;unless<br />low&nbsp;level&nbsp;is&nbsp;asserted&nbsp;for&nbsp;performing&nbsp;a&nbsp;write<br />operation.&nbsp;R/W&nbsp;is&nbsp;placed&nbsp;in&nbsp;the&nbsp;high-impedance<br />state.<br /><br />PIN19(W/R):<br />Write/Read&nbsp;qualifier&nbsp;or&nbsp;GPIO.&nbsp;This&nbsp;is&nbsp;an&nbsp;inverted<br />R/W&nbsp;signal&nbsp;useful&nbsp;for&nbsp;zero-wait-state&nbsp;memory<br />normally&nbsp;low,&nbsp;unless&nbsp;a&nbsp;memory&nbsp;write<br />interface.&nbsp;It&nbsp;is&nbsp;operation&nbsp;is&nbsp;performed.&nbsp;See&nbsp;Table&nbsp;12,&nbsp;<br />Port&nbsp;C&nbsp;section,&nbsp;for&nbsp;reset&nbsp;note&nbsp;regarding&nbsp;LF2406A&nbsp;and<br />LF2402A.&nbsp;(↑)
tjsheep 发表于 2007-8-2 21:15 | 显示全部楼层
不是指示,是有些芯片的选通引脚……
 楼主| snakeemail 发表于 2007-8-3 14:17 | 显示全部楼层
我的意思是这两个脚的状态是否正好相反
 楼主| snakeemail 发表于 2007-8-3 14:24 | 显示全部楼层
tjsheep 发表于 2007-8-4 22:13 | 显示全部楼层
sure,你发的英文里不是写的么
This&nbsp;is&nbsp;an&nbsp;inverted&nbsp;R/W&nbsp;signal&nbsp;。。。
