请教msp430中C语言数据转换
1756|0
lhwaizhu|  楼主 | 2012-11-24 21:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在IAR环境中:
#define  uint8    unsigned char
#define  uint16   unsigned int
#define  uint32   unsigned long int
unsigned char BUFFER[512]; //存放数据
typedef struct  //这里一共是512个字节
        uint8 BS_jmpBoot[3];
        uint8 BS_OEMName[8];
        uint16 BPB_BytesPerSec;
        uint8 BPB_SecPerClus;
        uint16 BPB_RsvdSecCnt;
        uint8 BPB_NumFATs;
        uint16 BPB_RootEntCnt;
        uint16 BPB_TotSec16;
        uint8 BPB_Media;
        uint16 BPB_FATSz16;
        uint16 BPB_SecPerTrk;
        uint16 BPB_NumHeads;
        uint32 BPB_HiddSec;
        uint32 BPB_TotSec32;
        uint8 BS_DrvNum;
        uint8 BS_Reservedl;
        uint8 BS_BootSig;
        uint32 BS_VolID;
        uint8 BS_VolLab[11];
        uint8 BS_FilSysType[8];
        uint8 ExecutableCode[448];
        uint8 ExecutableMarker[2];
} FAT_BPB;
FAT_BPB* BPB;
当我读出了512字节存放到BUFFER中后  BPB = (FAT_BPB*)BUFFER; 查看BPB中的数据发现
uint8 BS_OEMName[8]; 这11个数据正常,
BUFFER[11]=0x00;
BUFFER[12]=0x02;
BUFFER[13]=0x40;
转换过去     BPB_BytesPerSec=0x4002 我感觉应该是0x0200才对啊,编译器怎么会把BUFFER[11]给漏掉了呢?请教了 谢谢
