 最近几天都在调试自己做的小型开发板,但是在CAN的这一块就是调试不过去,在初始化的时候就过不去了,程序如下:
 void GPIO_Configuration(void)
 GPIO_InitTypeDef  GPIO_InitStructure;
 /* Configure CAN1 pin: RX */
 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_CAN_RX;
 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
 GPIO_Init(GPIO_CAN, &GPIO_InitStructure);
 /* Configure CAN1 pin: TX */
 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_CAN_TX;
 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
 GPIO_PinRemapConfig(GPIO_Remap_CAN , ENABLE);
 /* Configure CAN2 pin: RX */
 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_CAN_RX_2;
 GPIO_Init(GPIO_CAN_2, &GPIO_InitStructure);
 /* Configure CAN2 pin: TX */
 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_CAN_TX_2;
 GPIO_PinRemapConfig(GPIO_Remap_CAN_2 , ENABLE);
 void CAN_Config(CAN_TypeDef* CANx, uint8_t CAN_FilterNumber)
 /* CAN register init */
 CAN_DeInit(CANx);
 CAN_StructInit(&CAN_InitStructure);
 /* CAN cell init */
 CAN_InitStructure.CAN_TTCM = DISABLE;
 CAN_InitStructure.CAN_ABOM = DISABLE;
 CAN_InitStructure.CAN_AWUM = DISABLE;
 CAN_InitStructure.CAN_NART = DISABLE;
 CAN_InitStructure.CAN_RFLM = DISABLE;
 CAN_InitStructure.CAN_TXFP = DISABLE;
 CAN_InitStructure.CAN_Mode = CAN_Mode_Normal;
 CAN_InitStructure.CAN_SJW = CAN_SJW_1tq;
 CAN_InitStructure.CAN_BS1 = CAN_BS1_3tq;
 CAN_InitStructure.CAN_BS2 = CAN_BS2_5tq;
 CAN_InitStructure.CAN_Prescaler = 4;//2
 CAN_Init(CANx, &CAN_InitStructure);
 /* CAN filter init */
 CAN_FilterInitStructure.CAN_FilterNumber=CAN_FilterNumber;
 CAN_FilterInitStructure.CAN_FilterMode=CAN_FilterMode_IdMask;
 CAN_FilterInitStructure.CAN_FilterScale=CAN_FilterScale_32bit;
 CAN_FilterInitStructure.CAN_FilterIdHigh=0x0000;
 CAN_FilterInitStructure.CAN_FilterIdLow=0x0000;
 CAN_FilterInitStructure.CAN_FilterMaskIdHigh=0x0000;
 CAN_FilterInitStructure.CAN_FilterMaskIdLow=0x0000;
 CAN_FilterInitStructure.CAN_FilterFIFOAssignment=(CANx == CAN1? 0:1);
 CAN_FilterInitStructure.CAN_FilterActivation=ENABLE;
 CAN_FilterInit(CANx, &CAN_FilterInitStructure);
 /* transmit */
 TxMessage.StdId = 0x321;
 TxMessage.ExtId = 0x01;
 TxMessage.RTR = CAN_RTR_DATA;
 TxMessage.IDE = CAN_ID_STD;
 TxMessage.DLC = 1;
 CANx->MCR &= ~MCR_SLEEP;
 /* Request initialisation */
 CANx->MCR |= MCR_INRQ ;
 /* Wait the acknowledge */
 while (((CANx->MSR & MSR_INAK) != MSR_INAK) && (wait_ack != INAK_TimeOut))
 wait_ack++;
 /* ...and check acknowledged */
 if ((CANx->MSR & MSR_INAK) != MSR_INAK)
 InitStatus = CANINITFAILED;
 else
 /* Set the time triggered communication mode */
 if (CAN_InitStruct->CAN_TTCM == ENABLE)
 CANx->MCR |= MCR_TTCM;
 else
 CANx->MCR &= ~MCR_TTCM;
 /* Set the automatic bus-off management */
 if (CAN_InitStruct->CAN_ABOM == ENABLE)
 CANx->MCR |= MCR_ABOM;
 else
 CANx->MCR &= ~MCR_ABOM;
 /* Set the automatic wake-up mode */
 if (CAN_InitStruct->CAN_AWUM == ENABLE)
 CANx->MCR |= MCR_AWUM;
 else
 CANx->MCR &= ~MCR_AWUM;
 /* Set the no automatic retransmission */
 if (CAN_InitStruct->CAN_NART == ENABLE)
 CANx->MCR |= MCR_NART;
 else
 CANx->MCR &= ~MCR_NART;
 /* Set the receive FIFO locked mode */
 if (CAN_InitStruct->CAN_RFLM == ENABLE)
 CANx->MCR |= MCR_RFLM;
 else
 CANx->MCR &= ~MCR_RFLM;
 /* Set the transmit FIFO priority */
 if (CAN_InitStruct->CAN_TXFP == ENABLE)
 CANx->MCR |= MCR_TXFP;
 else
 CANx->MCR &= ~MCR_TXFP;
 /* Set the bit timing register */
 CANx->BTR = (uint32_t)((uint32_t)CAN_InitStruct->CAN_Mode << 30) | ((uint32_t)CAN_InitStruct->CAN_SJW << 24) |
 ((uint32_t)CAN_InitStruct->CAN_BS1 << 16) | ((uint32_t)CAN_InitStruct->CAN_BS2 << 20) |
 ((uint32_t)CAN_InitStruct->CAN_Prescaler - 1);
 /* Request leave initialisation */
 CANx->MCR &= ~MCR_INRQ;
 wait_ack = 0x00;
 while (((CANx->MSR & MSR_INAK) == MSR_INAK) && (wait_ack != INAK_TimeOut))
 wait_ack++;
 if ((CANx->MSR & MSR_INAK) == MSR_INAK)
 else
 InitStatus = CANINITOK ;
 /* At this step, return the status of initialization */
 return InitStatus;
 就是死在了   while (((CANx->MSR & MSR_INAK) == MSR_INAK) && (wait_ack != INAK_TimeOut))
 wait_ack++;
 }手册说是到这个地方是硬件自动对CAN_MSR_INAK位自动清零,但是就是一直没出现,希望各位大神赐教啊!!!!!
