Removed fan-outs from the following always-disabled I/O buffers? 如何解决?
2903|4
zhpg009|  楼主 | 2012-12-30 10:56 | 显示全部楼层 回帖奖励 |倒序浏览 |阅读模式
如题,
Warning (13027): Removed fan-outs from the following always-disabled I/O buffers
        Warning (13028): Removed fan-out from the always-disabled I/O buffer "dataout[0]" to the node "dataout[0]"
        Warning (13028): Removed fan-out from the always-disabled I/O buffer "dataout[1]" to the node "dataout[1]"
        Warning (13028): Removed fan-out from the always-disabled I/O buffer "dataout[2]" to the node "dataout[2]"
        Warning (13028): Removed fan-out from the always-disabled I/O buffer "dataout[3]" to the node "dataout[3]"
        Warning (13028): Removed fan-out from the always-disabled I/O buffer "dataout[4]" to the node "dataout[4]"
        Warning (13028): Removed fan-out from the always-disabled I/O buffer "dataout[5]" to the node "dataout[5]"
        Warning (13028): Removed fan-out from the always-disabled I/O buffer "dataout[6]" to the node "dataout[6]"
        Warning (13028): Removed fan-out from the always-disabled I/O buffer "dataout[7]" to the node "dataout[7]"
求高手解决
zhpg009|  楼主 | 2012-12-30 11:01 | 显示全部楼层
代码如下
module ram( dataout, addr, wr, rd, cs, datain );
        output[7:0] dataout;
        input[4:0] addr;
        input[7:0] datain;
        input cs, wr, rd;
        reg[7:0] datastore[31:0];
        reg[7:0] dataout;
        //write data
        always @ ( wr, cs, addr, datastore, datain )
        begin
                if( cs == 0 )
                        begin
                                if( wr )
                                        begin
                                                datastore[addr] = datain;
                                        end
                                else
                                        begin
                                                dataout = 8'bz;
                                        end
                        end
        end
        //read data
        always @ ( rd, cs, addr, datastore )
        begin
                if( cs == 0 )
                        begin
                                if( rd )
                                        begin
                                                dataout = datastore[addr];
                                        end
                                else
                                        begin
                                                dataout = 8'bz;
                                        end
                        end
        end
endmodule
个人签名:进取
16
