给程序挑错
1389|4
 楼主| mentoscui 发表于 2012-12-30 19:40 | 显示全部楼层 |阅读模式
library IEEE ;
use IEEE.std_logic_1164.all ;
use IEEE.std_logic_unsigned.all ;
use IEEE.numeric_std.all ;
entity key1 is
port ( Clk_I   : in std_logic ;
        Rst_I   : in std_logic ;
        key_I : in std_logic ;
        key_O : out std_logic );
end entity ;
architecture rt1 of key1 is
   type state_type is (s0, s1, s2, s3, s4, s5);
   signal state     : state_type ;
   signal count     : integer range 0 to 80000 ;
   signal reg       : std_logic ;
   signal key_confirm : std_logic ;
begin
    reg <= key_I ;
  process (Clk_I, Rst_I)
    begin
     if Rst_I = '0' then
              state <= s0 ;
      elsif Clk_I'event and Clk_I = '1' then
          case state is
               when s0 => if reg = '1' then
                               state <= s0;
                          else state <= s1;
                          end if ;
               when s1 => if count = 80000 then
                             count <= 0 ;
                             state <= s2 ;
                          else count <= count + 1 ;
                               state <= s1 ;
                          end if ;
               when s2 => if reg = '1' then
                               state <= s0 ;
                          else state <= s3;
                          end if ;
               when s3 => if reg = '1' then
                               state <= s0 ;
                          else state <= s4 ;
                          end if ;
               when s4 => if reg = '1' then
                               state <= s0 ;
                          else state <= s5 ;
                          end if ;
               when s5 => if reg ='0' then
                               state <= s0 ;
                          else state <= s5 ;
                          end if ;
               when others => state <= s0 ;
           end case ;
       end if ;
   end process ;
   process (Clk_I)
     begin
         case state is
             when s5 => key_confirm <= '1' ;
             when others => key_confirm <= '0' ;
         end case ;
        end if ;
     end process ;
   key_O <= key_confirm ;
end rt1;
错误:    key_O : out std_logic ); 不应该有分号?
GoldSunMonkey 发表于 2012-12-30 22:20 | 显示全部楼层
自问自答么?
gaochy1126 发表于 2013-1-2 00:06 | 显示全部楼层
好榜样 楼主自己解决问题了
hawksabre 发表于 2013-1-2 18:18 | 显示全部楼层
呵呵   这个不错哦   这样我们的功夫就省了很多了   呵呵   顶一个
