关于Fseek()函数请教
2464|1
 楼主| szhgx26 发表于 2007-8-22 15:59 | 显示全部楼层 |阅读模式
谁作过FAT File system? Fseek()这个函数看着有点迷糊,请高手指点一下大慨思路。源码如下:
bit fat_fseek (Int32 offset)
Uint32  file_pos;                           /* current position in file */
Uint16  cluster_offset;                     /* cluster offset in file */
Byte    sector_offset;                      /* sector offset in cluster */
#define i               sector_offset       /* local variable overlay */
#define byte_offset     cluster_offset      /* local variable overlay */
  /* File size information update for write mode*/
  if (fat_open_mode == WRITE)
    if (fat_cache.current.size.l <= fat_file_size.l)
      fat_cache.current.size.l = fat_file_size.l;
  /* init file pos with the current cluster in the index */
  if (fat_fchain_nb_clust != 0)
    file_pos = fat_fchain_nb_clust - 1;
  else
    file_pos = 0;
  /* Add the previous cluster number */
  for (i = 0; i != fat_fchain_index; i++)
    file_pos += fclusters.number;
  /* convert absolute cluster value in byte position */
  file_pos *= SECTOR_SIZE * fat_cluster_size;
  if ((fat_fchain_nb_clust != 0) && ( fat_fclust_byte_count % (fat_cluster_size * SECTOR_SIZE) == 0))
    file_pos += (fat_cluster_size * SECTOR_SIZE);
  else
    ((Byte*)&fat_fclust_byte_count)[0] &= fat_cluster_mask;
    file_pos += fat_fclust_byte_count;        /* offset in cluster */
  /* Check range value */
  if (((file_pos + offset) < 0) ||
      ((file_pos + offset) > fat_cache.current.size.l))
    return KO;                              /* out of file limits */
  file_pos += offset;    /* new position */
  /* Calculate byte position in cluster */
  ((Byte*)&fat_fclust_byte_count)[1] = ((Byte*)&file_pos)[3];
  ((Byte*)&fat_fclust_byte_count)[0] = ((Byte*)&file_pos)[2];
  /* Calculate the absolute cluster position */
  cluster_offset = file_pos / (SECTOR_SIZE * fat_cluster_size);
  fat_fchain_index = 0;                     /* reset fragment number */
  /* Determinate the index for the chain cluster */
  while (cluster_offset >= fclusters[fat_fchain_index].number)
    cluster_offset -= fclusters[fat_fchain_index].number;
    fat_fchain_index++;                     /* ome more fragment */
  /* Determinate the cluster offset value for the selected index */
  fat_fchain_nb_clust = cluster_offset;
  /* Determinate the sector offset value in the selected cluster */
  sector_offset = (fat_fclust_byte_count  & ((fat_cluster_size * SECTOR_SIZE) - 1)) / SECTOR_SIZE;
  /* seek into sector */
  byte_offset = file_pos % SECTOR_SIZE;
  /* re-open file in read or write mode */
  if (fat_open_mode == READ)
    Hard_read_close();                      /* close  reading */
    Hard_read_open(((Uint32)(fclusters[fat_fchain_index].cluster + fat_fchain_nb_clust) * fat_cluster_size)
                   + sector_offset + fat_ptr_data);
    if ((fat_fchain_nb_clust != 0) || (sector_offset != 0) || (byte_offset != 0))
    { /* if no offset, nb_clust incremented in fgetc() function */
      fat_fchain_nb_clust++;                /* one-based variable */
    while (byte_offset != 0)
      Hard_read_byte();                     /* dummy read */
      byte_offset--;
  else
    Hard_write_close();                     /* close writing */
    Hard_write_open(((Uint32)(fclusters[fat_fchain_index].cluster + fat_fchain_nb_clust) * fat_cluster_size)
    if (byte_offset != 0)
    { /* if no offset, nb_clust incremented in fputc() function */
    fat_file_size.l += offset;                      /* Update byte position in write mode */
    if ((((Byte*)&fat_fclust_byte_count)[1] == 0x00) &&
      ((((Byte*)&fat_fclust_byte_count)[0] & fat_cluster_mask) == 0x00))
      if ((fclusters[fat_fchain_index].number == fat_fchain_nb_clust) && (fat_fchain_index == fat_last_clust_index))
        flag_end_disk_file = TRUE;
      else
        flag_end_disk_file = FALSE;
  return OK;
 楼主| szhgx26 发表于 2007-8-23 09:25 | 显示全部楼层
