ADS1271应用?
3692|4
zw9882|  楼主 | 2007-8-26 20:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
gjg191| | 2007-8-27 08:22 | 只看该作者
dd
In addition to controlling synchronization, the
SYNC/PDWN pin also serves as the control for
Power-Down mode and offset calibration. To enter this
mode, hold the SYNC/PDWN pin low for at least 219 CLK
periods. While in Power-Down mode, both the analog and
digital circuitry are completely deactivated. The digital
inputs are internally disabled so that is not necessary to
shut down CLK and SCLK. To exit Power-Down mode,
return SYNC/PDWN high on the rising edge of CLK.
zw9882|  楼主 | 2007-8-27 09:36 | 只看该作者
EEEEEEEEEE
English,English,English,English,English,
please Chinese,Chinese.......
gjg191| | 2007-8-27 09:57 | 只看该作者
dd
我晕啊!自己用金山翻译啊!!不懂的地方再问.
zw9882|  楼主 | 2007-8-27 10:02 | 只看该作者
问问
gjg191 你用过这个片子吗?
sclk 是输入到ads1271 还是由ADS1271输出的?
