大虾急救 max192
2196|2
 楼主| 52mcu 发表于 2008-3-17 21:33 | 显示全部楼层 |阅读模式
AD, dc, TE, code, ADC
如下程序怎么也读不到ad转换的结果。请大虾拔刀相助 提供一个max192和单片机的接口例程
int ReadMax192Ad(unsigned  char channel) //channel [0--7]
   unsigned char CtrByte;//START SEL2 SEL1 SEL0 UNI/BIP  SGL/DIF  PD1 PD0
   int adcode=0;
   CtrByte=0x8e;
   CtrByte=(CtrByte&~(0x7<<4))|(channel<<4);
   CS_MAX192=0;   //chip enable
   DelayUs(180);      //delay
   SPIRW(CtrByte);
   DelayUs(40);
   adcode=SPIRW(0x00)<<3;
    DelayUs(40);
   adcode=adcode+SPIRW(0x00)>>5;
   DelayUs(180);
   CS_MAX192=1;//chip disable
   return adcode;
 楼主| 52mcu 发表于 2008-3-25 21:39 | 显示全部楼层
如下程序也不行,急啊
int ReadMax192Adc(unsigned  char channel) //channel [0--7]
   unsigned char CtlByte;//START SEL2 SEL1 SEL0 UNI/BIP  SGL/DIF  PD1 PD0
   int adcode=0;
   unsigned char BitCounter;
   CtlByte=0x8f;
   CtlByte=(CtlByte&~(0x7<<4))|(channel<<4); //MAX192控制字
   CS_MAX192=1;
   PCLK =0;
   PDATA_OUT=0;
   //PDATA_IN=1;
  for (BitCounter=0;BitCounter<8;BitCounter++)  //发送MAX192控制字
    PDATA_OUT=(CtlByte & 0x80)==0?0:1;
    CtlByte  <<= 1;
    DelayUs(14);
    PCLK=1; //1
    DelayUs(14);
    PCLK=0;//0
  //DelayMs(2);
   DelayUs(24)
  PCLK =1;
  PDATA_OUT=0;
 for (BitCounter=0;BitCounter<8;BitCounter++)  //读高八位A/D转换结果
    PCLK=0; //0
    DelayUs(14);
    PCLK=1; //1
    DelayUs(14);
    adcode <<= 1;
    if(PDATA_IN ) adcode |= 0x01;
 for (BitCounter=0;BitCounter<8;BitCounter++) //读底八位A/D转换结果
    PCLK=0;
    DelayUs(14);
    PCLK=1;
    DelayUs(14);
    adcode <<= 1;
  adcode>>=5;  //得到10位 A/D转换结果
  DelayUs(18);
   return adcode;
ayb_ice 发表于 2008-3-26 12:00 | 显示全部楼层
多看DATASHEET...
