AARGB0~AARGB3是什么寄存器
2387|1
 楼主| zdhlixiang2006 发表于 2013-1-23 20:39 | 显示全部楼层 |阅读模式
最近在看PIC18的UCOSII移植范例,原作者Nathan Brown写的堆栈初始化函数OSTaskStkInit里面涉及到了PIC18XXXX的寄存器操作,涉及到了4个寄存器AARGB0~AARGB3,可是我在PIC的datasheet上根本搜索不到与之相关的任何内容,这个是怎么回事呢?原代码如下,请看蓝色字体的部分,PIC没这个寄存器啊
OS_STK *OSTaskStkInit (void (*task)(void *pd), void *pdata, OS_STK *ptos, INT16U opt)
    OS_STK *stk;
    stk     = ptos;                     // local pointer to our new proccess stack
    *stk++  = (OS_STK)*(((INT8U*)&pdata));  // data being passed
    *stk++  = (OS_STK)*(((INT8U*)&pdata)+1);
    *stk++  = 0xFF;                     // <-- FSR1 Pointer position on function call.
    *stk++  = 0x1A;                     // STATUS register
    *stk++  = 0x1B;                     // BSR register
    *stk++  = 0x1C;                     // W register
    *stk++  = 0x1D;                     // FSR0L register
    *stk++  = 0x1E;                     // FSR0H register
    *stk++  = 0x1F;                     // FSR2L register
    *stk++  = 0x2A;                     // FSR2H register
    *stk++  = 0x2B;                     // TBLPTRL Prog Mem Table Pointer Upper
    *stk++  = 0x2C;                     // TBLPTRH Prog Mem Table Pointer High
    *stk++  = 0x2D;                     // TBLPTRU Prog Mem Table Pointer Low
    *stk++  = 0x2E;                     // PRODL Product Reg high
    *stk++  = 0x2F;                     // PRODH Product Reg low
    *stk++  = 0x3A;                                                // AARGB3
    *stk++  = 0x3B;                                                // AARGB2
    *stk++  = 0x3C;                                                // AARGB1
    *stk++  = 0x3D;                                                // AARGB0
 楼主| zdhlixiang2006 发表于 2013-1-25 10:00 | 显示全部楼层
这个没人见过吗
个人签名:沐浴着XX的春风,义无反顾游荡在马勒戈壁
21
