那位做过at45db161d
2217|1
 楼主| chuandaoxy 发表于 2009-5-26 23:53 | 显示全部楼层 |阅读模式
下面的代码,是从c++的代码转化过来的
#include <reg51.h>
#define    uint                     unsigned int
#define    uchar                    unsigned char
#define AT45DB161D_READ_MANUFACTURER_AND_DEVICE_ID 0x9F
 struct ATD45DB161D_ID
   uint     manufacturer;
   uint     device[2];
   uint     extendedInfoLength;
void ReadManufacturerAndDeviceID(struct ATD45DB161D_ID *id);
unsigned char SPI_HostReadByte(void)
    unsigned char i,rByte=0;
    for(i=0;i<8;i++){
        SPI_SCK=0;
        SPI_SCK=1;
        rByte<<=1;
        rByte|=SPI_SO;
    return rByte;
void SPI_HostWriteByte(unsigned char wByte)
    unsigned char i;
    for(i=0;i<8;i++){
        if((wByte<<i)&0x80){SPI_SI=1;}
        else{SPI_SI=0;}
        SPI_SCK=0;
        SPI_SCK=1;
   SPI_CS=1;
   SPI_CS=0;
   SPI_HostWriteByte(0x9f);
   id->manufacturer = SPI_HostReadByte();
   SPI_HostWriteByte(0xff);
   id->device[0] = SPI_HostReadByte();
   id->device[1] = SPI_HostReadByte();
   id->extendedInfoLength = SPI_HostReadByte();
ReadManufacturerAndDeviceID(struct  ATD45DB161D_ID *id)这个函数只能读出厂家id;1f,而容量id,无法读出,错在那呢
结构体里定义的变量都是uint型,改称uchar才能读出厂家id;1f,这是为啥?
mxh0506 发表于 2009-5-27 14:53 | 显示全部楼层
改成下面这样:
   SPI_CS=1;
   SPI_CS=0;
