#include <m8c.h>        // part specific constants and macros
#include "PSoCAPI.h"    // PSoC API definitions for all User Modules
void delay(unsigned int x)
   while(x--);
void main()
while(1)
   PRT0DR=0x00;
   delay(5000);
    PRT0DR=0x01;
    }// Insert your main routine code here.
结果编译后,总是输出这样的结果(看不懂咋回事,这应该是和程序的语法错误没关系的,因为我拿过师兄的程序试过,也是这样)
Generating source code for Device Configuration...
The source code has been generated successfully
Compiling...
creating project.mk
./main.c
!E D:\psoc\tools\InvalidCompilerLicense.txt(0): ...Operation terminated. Compiler License invalid or not accessible
D:\psoc\tools\make: *** [obj/main.o] Error -1
main.o - 2 error(s) 0 warning(s) |
