急求!!!!!!!
1026|0
 楼主| ai0096 发表于 2013-3-27 20:49 | 显示全部楼层 |阅读模式
程序不知道怎么回事。,,设置p2=0X90,输出却是C0 C0 D0 D0 C0 D0 D0 C0 D0 D0
#include <reg51.h>
#include <intrins.h>
#define uchar  unsigned char
#define uint unsigned int
uchar re_data[20];
uchar count=0;
uchar count1=0;
uchar i;
uchar j;
bit flag_1s=0;
void ser() interrupt 4
                if(RI)
                {       RI=0;
                        re_data[i++]=SBUF;
void timer0() interrupt 1                //定时器0中断子程序
        TH0=0x4C;                //赋初值50ms,作为基准值
        TL0=0x00;
        count++;
        //if(count==40)
        if(count==10)
          count=0;
         if(count1==8)
          count1=0;
          flag_1s=1;
          count1++;
/*************串口初始化****************/
void serial_init()
        SCON=0X50;
        EA=1;
        ES=0;
        PS=1;
        TH1=0XFD;
        TL1=0XFD;
        ET1=0;
        TR1=1;
void chushihua(void)
   TL0=0x00;
   ET0=1;
   TR0=1;
void Main()
   TMOD=0x21;
   serial_init();
   chushihua();
   P2=0X90;
   while(1)
      if(flag_1s==1)
           TR0=0;
           j=P2;
           SBUF=j;
           while(!TI);
           TI=0;
           flag_1s=0;
           TR0=1;
