菜农早上作检讨---论斗私批修
5071|20
 楼主| hotpower 发表于 2008-7-24 07:57 | 显示全部楼层 |阅读模式
tc, COM, TE, ST, dc
匠人说俺忽悠,实属不是~~~
若俺发布源码,确实是浪费"人才"~~~因为肯定很多人要看"天书".
不信帖几句:
typedef struct
    unsigned int CommPort;
    int        Panel;
    int        Control;
    void   *Data;
}HotCommBindCtrlStruct, *HotCommBindCtrlStructPtr;
typedef int  (CVICALLBACK *HotCommBindCtrlCallbackPtr) (int Panel, int Control, int Event, void *BindCtrlPtr, int EventData1, int EventData2);
typedef struct
    HotCommBindCtrlStruct BindContrlArray[HotCommSystemBindCtrlMaxCount];
    int     BindCount;//实际绑定个数
    int     BindMaxCount;//最大绑定个数
}HotCommSystemBindCtrl;
typedef interface IHotComm_CtrlBind IHotComm_CtrlBind;
typedef struct IHotComm_CtrlBindVtbl
    BEGIN_INTERFACE
    HRESULT (CVIFUNC *GetSystemCtrlBindCount)(int Panel, int Control, int * Count, int * MaxCount);
    HRESULT (CVIFUNC *HotComm_SystemCtrlPasswordBindInit) (void);
    END_INTERFACE
} IHotComm_CtrlBindVtbl;
    CONST_VTBL struct IHotComm_CtrlBindVtbl *lpVtbl;
    HotCommSystemBindCtrl IHotCommSystemBindCtrl;
    HotComm将采用COM接口技术对HotComm进行再封装
HRESULT CVIFUNC HotCommInterfaceInit (void)
    HRESULT __result = S_FALSE;
    IHotCommCtrlBind.lpVtbl = (CONST_VTBL struct IHotComm_CtrlBindVtbl *)malloc (sizeof(IHotComm_CtrlBindVtbl));
    if (IHotCommCtrlBind.lpVtbl)
        IHotCommCtrlBind.IHotCommSystemBindCtrl.BindCount = 0;
        IHotCommCtrlBind.IHotCommSystemBindCtrl.BindMaxCount = HotCommSystemBindCtrlMaxCount;
        IHotCommCtrlBind.lpVtbl->GetSystemCtrlBindCount = HotComm_GetSystemCtrlPassword;
        __result = S_OK;
    return __result;
HRESULT CVIFUNC HotCommInterfaceQuit (void)
    free (IHotCommCtrlBind.lpVtbl);
    __result = S_OK;
    return __result;
void CVIFUNC SystemInit(void)
    HotCommInterfaceInit ();
    TabpanelInit();
//进入后将TAB隐藏并设置密码,前这为TAB,后者是激活密码需要点击的控件,一般用图片之类的控件覆盖.
    HotComm_BindSystemCtrlPassword (TabpanelHandle4, TABPANEL_4_Password, "250");
    HotComm_BindSystemCtrlPassword (TabpanelHandle5, TABPANEL_5_Password, "250");
//    HotComm_BindSystemTabsPassword (panelHandle, PANEL_MAINTAB, TabpanelHandle5, TABPANEL_5_Password, "250");
    UartInit();
    TaskInit();
    TestInit();
    HotCommInterfaceQuit ();
HRESULT CVIFUNC HotComm_BindSystemCtrlPassword (int Panel, int Control, const char *Password)
    HRESULT __result;
    int Count;
    int MaxCount;
    __result = IHotCommCtrlBind.lpVtbl->GetSystemCtrlBindCount (Panel, Control, &Count, &MaxCount);
    if (__result == S_OK)//
        IHotCommCtrlBind.IHotCommSystemBindCtrl.BindContrlArray[Count].Panel = Panel;
        IHotCommCtrlBind.IHotCommSystemBindCtrl.BindContrlArray[Count].Control = Control;
        SetCtrlAttribute (Panel, Control, ATTR_CALLBACK_FUNCTION_POINTER, (HotCommBindCtrlCallbackPtr)HotComm_SystemCtrlPassword);//
        SetCtrlAttribute (Panel, Control, ATTR_CALLBACK_DATA, (HotCommBindCtrlStructPtr)&IHotCommCtrlBind.IHotCommSystemBindCtrl.BindContrlArray[Count]);//
        IHotCommCtrlBind.IHotCommSystemBindCtrl.BindCount ++;
        __result = S_OK;//控件被成功绑定
    return  __result;
//HotComm系统内部回调函数!!!(不对外)
int CVICALLBACK HotComm_SystemCtrlPassword (int Panel, int Control, int Event,
        HotCommBindCtrlStruct *BindCtrlPtr, int EventData1, int EventData2)
    switch (Event)
        case EVENT_LEFT_CLICK:
            if ((Panel == BindCtrlPtr->Panel) && (Control == BindCtrlPtr->Control))//已绑定
                SetCtrlAttribute (Panel, Control, ATTR_VISIBLE, 0);//不可视
            break;
    return 0;
 楼主| hotpower 发表于 2008-7-24 07:58 | 显示全部楼层
先上班占沙发~~~
发表于 2008-7-24 08:05 | 显示全部楼层
板凳...其实把软件做好,不公布源码也不错啊.
把使用说明写详细就好...
辛苦啊....
zjh006 发表于 2008-7-24 08:31 | 显示全部楼层
公布了也看不懂
huangqi412 发表于 2008-7-24 08:42 | 显示全部楼层
老hot还是发布一个体验版,让大家尝尝新鲜蔬菜吧.
你这东西没几个人看的懂哇.
蔬菜大家都吃的懂
hbicecream 发表于 2008-7-24 08:52 | 显示全部楼层
要是做平台的都这么写程序,那就。。。。
sz_kd 发表于 2008-7-24 09:22 | 显示全部楼层
呵呵,我看不懂~~~~~~~~~~~~~~~~~~
djyos 发表于 2008-7-24 09:42 | 显示全部楼层
先准备好再下锅好点
洗干净,切好,备油盐酱醋,再检查一下,都齐了,再点火、下锅,这叫炒菜。
若没准备好就点火,就不是炒菜而是炒作了。
djyos 发表于 2008-7-24 09:50 | 显示全部楼层
本来想做螃蟹的
    我以前写过一个需要用串口的小程序,现在想用,却不知所踪,估计是不小心删掉了。不得不重编,看到老菜大作,本来想做一回螃蟹,可怎么也看不懂,到老菜的blog里找也看不懂,只好做了罢。
    在我眼里,高质量的软件,在业内人士眼里肯定是看得懂的。
程序匠人 发表于 2008-7-24 10:01 | 显示全部楼层
哈哈,一石头激起三尺浪,一浪更比一浪浪!
huangqi412 发表于 2008-7-24 10:35 | 显示全部楼层
老hot就先给个体验版,大家评一下吧.
sodwell 发表于 2008-7-24 10:54 | 显示全部楼层
re
要是HOT大叔能已这样的写法写10W行的C程序(非C++),那就厉害了
gyt 发表于 2008-7-24 12:13 | 显示全部楼层
谢谢分享
icecut 发表于 2008-7-24 12:28 | 显示全部楼层
强悍
typedef
我都晕了
再添加一个自动发送的正则表达式解析吧.
哈哈,到时候发协议就直接设定就ok了
 楼主| hotpower 发表于 2008-7-24 13:25 | 显示全部楼层
实际代码早有所公开~~~
 楼主| hotpower 发表于 2008-7-24 13:30 | 显示全部楼层
回14楼:最终在命令窗口嵌入C编译器,像VB一样运行
哈哈~~~只要俺还有力气~~~
迷糊一下,2点给地主干活~~~
walnutcy 发表于 2008-7-24 19:56 | 显示全部楼层
先出个1.0版本体验下,再炒作吧,
huangqi412 发表于 2008-7-24 20:03 | 显示全部楼层
找到老hot错别字两个,嘿嘿.
开发过程 发表于 2008-7-25 08:30 | 显示全部楼层
看到毛主席,俺心里发毛,
 楼主| hotpower 发表于 2008-8-1 02:21 | 显示全部楼层
俺先对付阶级敌人后再搞个体验版的接受攻击~~~
1.加入了串口自动识别:
2.注册要回邮件:
3.**串口状态:
4.托盘更正规方便(双击图标显示和隐藏):
5.多实例运行提示:
因为这次要和阶级敌人战斗,所以要搞正规战~~~
