so8的芯片大家怎么拆的?
11028|30
原野之狼 发表于 2007-6-19 16:03 | 显示全部楼层
edanzg说的对,一把烙铁就行了。。。
dadodo 发表于 2007-6-20 13:29 | 显示全部楼层
基本功之一
搞电子的人,焊接是基本功之一
楼上的 发表于 2007-6-20 13:42 | 显示全部楼层
RE
一把普通的烙铁,10秒钟搞定.
twz8858877 发表于 2007-6-20 16:58 | 显示全部楼层
今天刚拆了一片ATT7025 QFP100封装的
一把烙铁,一根针,遗憾的是,没连线的焊盘掉了好几个。
ddb_21ic 发表于 2007-6-20 17:04 | 显示全部楼层
我手艺差,感觉两把烙铁好拆些
iC921 发表于 2007-6-20 19:02 | 显示全部楼层
搞不懂
什么是SO8封装。我查了ADI、TI,没看到。
TI:
Semiconductor Packaging Information by Type
Click on a Type to see more information on packaging codes under that Type.
TypePackage Designator Codes
BGAGDG, GDH, GDJ, GDP, GDQ, GDU, GDY, GEA, GFM, GFN, GFS, GFT, GFU, GFV, GFW, GFX, GFZ, GGB, GGC, GGD, GGE, GGF, GGH, GGM, GGN, GGP, GGQ, GGR, GGS, GGT, GGU, GGV, GHA, GHB, GHC, GHG, GHH, GHJ, GHQ, GHV, GHW, GHZ, GJE, GJG, GJJ, GJQ, GJY, GJZ, GKF, GKN, GKP, GKQ, GKV, GKZ, GLC, GLM, GLW, GND, GNH, GNP, GPG, GPV, GRH, GST, GVF, GVL, GVM, GVW, GWE, GWF, GWG, GWM, GWQ, GZA, GZG, GZY, SAE, ZAE, ZAH, ZAJ, ZAK, ZDH, ZDJ, ZDL, ZDP, ZDQ, ZDT, ZDU, ZDY, ZED, ZGU, ZRH, ZST, ZVA, ZVF, ZVL, ZVN, ZVW, ZWD, ZWF, ZWG, ZWM, ZWQ, ZWT, ZWV
BGA MICROSTARGGW, GHK, GKE, GPH, GZZ, ZGV, ZGW, ZHH, ZHK, ZHZ, ZKE, ZKF, ZPH, ZZA, ZZG, ZZZ
BQFPPQ
CBGAGLK, GNM
CDIPJ, JG, JK, JL, JNA, JNC, JND, JT, JW
CDIP BBJDE, JDG
CDIP SBJD, JDB, JDC, JDD, JDJ, JDK, JDL, JDM, JDN, JVA, JVB, JVD, JVE, JVF, JVG
CFPHBC, HFG, HFH, HFN, HFP, HS, HT, HV, U, W, WD, WN
CPGAGA-GB, GB, GF, GFA, GLA
DFPFT
DIP MODULEBAZ, BBQ, BCM, BET, BEW, EAN, EAP, EAQ, EAS, EAT, EAW, EAY, EAZ, EBN, EBP, EBQ, EBS, EBT, EBY, ECL, ECM, ECP, ECQ, EEP, EET, EEV, EEW, EGD, EGE, EGH, EGJ, EGK, EGL, EQA, EQC, EQD, EQE, EQF, EQG, EQH, EQJ, EQK, ERH, ERJ, ERK, ERL, ERM, ERN, ERP, ERQ, ERS, ERT, ERU, ERV, ERW, ERY, ERZ, EUF, EUG, EUH, EUJ, EUK, EUL, EUM, EUN, EUP, EUQ, EUS, EUT, EUU, EUV, EUW, EUY, EVD, EVE, EVF, EVG
DSBGAYEA, YEJ, YEP, YEQ, YET, YEU, YEV, YZA, YZB, YZC, YZF, YZH, YZP, YZQ, YZT, YZU, YZV
FC/CSPCLZ, GHL, GHS, GHT, GHU, GJC, GJT, GLD, GLF, GLP, GLS, GNY
FCBGAGDK, GDN, GDV, GDZ, GHY, GJH, GJL, GJU, GLT, GLZ, GNZ, GPN, GPP, GPU, GPW, GPY, GPZ, GTA, GTC, GTD, GTE, GTF, GTG, GTH, GTJ, GTK, GTL, GTM, GTN, GTP, GTQ, GTS, GTU, GTW, GTY, GTZ, ZDK, ZLZ, ZNZ, ZTS, ZTZ
FCLGAGVJ
FCPGAGAD
HLQFPPCA, PCB, PJP, VFD, VFP, VG
HQFPPBE, PCE
HSOPDDA, DTH, DTJ, DWD, DWP
HTQFPPAP, PBP, PFD, PFP, PGM, PGP, PGS, PHD, PHP, PJD, PJW, PKD, PLD, PMD, PND, PNP, PQD, PQP, PVD, PVP, PZD, PZF, PZP
HTSSOPDAD, DAP, DCA, DCP, DDP, DDV, DED, DFD, DGN, DGQ, DHD, PWD, PWP
HVQFPRCD, RCP
JLCCFJ
LCCCFD, FE, FK
LQFPPBK, PBL, PEU, PFA, PGE, PGF, PM, PN, PSF, PT, PTA, PZ, PZA, VF
PDIPN, NE, NSQ, NT, NTA, NTC, NTD, NTG, NVA, NVE, NVF, NVG, NVJ, NVL, NVM, NVP, NVQ, P
PFMDBX, KH, KTC, KTE, KTG, KTP, KTR, KTT, KTW, KV, KVC, KVT, KVU
PLCCFN
PLGAGGJ, GJF, GKT, GLQ, GPL
QFNRGA, RGC, RGE, RGF, RGJ, RGN, RGP, RGQ, RGT, RGV, RGW, RGY, RGZ, RHA, RHB, RHC, RHD, RHF, RHG, RHH, RHL, RHN, RHP, RHU, RSA, RSE, RSF, RTA, RTB, RTC, RTD, RTF, RTH, RTJ, RTM, RTQ, RTW, RTZ
QFPFR, PAF, PAK, PAL, PBM, PBR, PCM, PEG, PF, PFF, PG, PGJ, PH, PJ, PJM, PJS, PJU, PJY, RC
SIPEEN, PK
SIP MODULEEAA, EAC, EAD, EAF, EAH, EAJ, EAL, EAM, EAU, EBA, EBC, EBD, EBE, EBG, EBK, ECA, ECC, ECD, ECE, ECG, ECK, EDA, EDC, EDD, EDE, EDF, EDG, EDJ, EDK, EEA, EEC, EED, EEE, EEF, EEG, EEK, EEL, EEM, EEQ, EFA, EFC, EFD, EFF, EFH, EFJ, EFK, EFL, EFM, EFN, EFP, EFQ, EHA, EHC, EHD, EHE, EHF, EHG, EHH, EHJ, EHK, EHL, EJA, EJC, EJD, EJE, EJF, EJG, EJH, EJJ, EJK, EKA, EKC, EKD, EKE, EKF, EKG, EKH, ELA, ELC, ELD, ELF, ELG, ELH, ELJ, ELK, ELL, EMA, EMC, EMD, EME, EMF, EMG, ENA, ENC, END, ENE, ENF, ENG, ENH, ENJ, ENK, ENL, ENM, ENN, ENP, EPA, EPC, EPD, EPE, EPF, EPG, EPH, EPJ, EPK, EPL, EPM, EPN, EPP, EPQ, EPS, ERA, ERC, ERD, EVA, EVC
SOICD, DW
SONDRB, DRC, DRD, DRF, DRJ, DRK, DRM, DRN, DRP, DRV, DRY
SOPDBV, DBZ, DCK, DCW, DRL, DTA, DTE, DTL, DUA, DVA, DVB, DVK, DVL, DVM, DVP, DVQ, DVS, DWU, NS, PS
SSOPDB, DBQ, DCE, DCN, DCT, DCV, DKD, DL
TO/SOTDCQ, DCY, DDC, KC, KCS, LMC, LMD, LME, LMF, LP
TQFPPAG, PAH, PBS, PBT, PDS, PDT, PET, PFB, PFC, PGT, PJT, PZT, RFA
TSSOPDA, DAE, DBB, DBT, DGG, PW
TVSOPDGP, DGV, DJD
VFBGAGQC, GQE, GQL, GQN, GQS, GQV, GQW, GQY, GQZ, GRD, GRE, GRF, GRG, GSL, GSP, GXU, GXY, ZQC, ZQE, ZQL, ZQN, ZQS, ZQV, ZQW, ZQY, ZQZ, ZRC, ZRD, ZRE, ZRG, ZSL, ZSP, ZXU, ZXY
V**A GQM, GSC, GSD, GSQ, ZSQ
VQFPPZW, RCE
VSSOPDCU, DDU, DGK, DGS
XCEPTYEB, YEC, YED, YEF, YEG, YEH, YEK, YEL
ZIPSDZ
ZZ (BB)ZZ001, ZZ001-1, ZZ006, ZZ006-1, ZZ006-4, ZZ006-5, ZZ006-6, ZZ007, ZZ010, ZZ010-1, ZZ010-2, ZZ030, ZZ075, ZZ077, ZZ102, ZZ109, ZZ124, ZZ129, ZZ148, ZZ149, ZZ163, ZZ165, ZZ167, ZZ167-4, ZZ169, ZZ176, ZZ178, ZZ180, ZZ182, ZZ182-1, ZZ206, ZZ208, ZZ210, ZZ211, ZZ215, ZZ217, ZZ217-1, ZZ217-2, ZZ218, ZZ218-1, ZZ219, ZZ220, ZZ221, ZZ222, ZZ225, ZZ231, ZZ235, ZZ235-1, ZZ238, ZZ239, ZZ242, ZZ243, ZZ243-1, ZZ243-2, ZZ243-3, ZZ243-4, ZZ243-5, ZZ245, ZZ246, ZZ248, ZZ251, ZZ265, ZZ311, ZZ312, ZZ315, ZZ322, ZZ323, ZZ324, ZZ325, ZZ327, ZZ328, ZZ331, ZZ332, ZZ333, ZZ334, ZZ334-1, ZZ336, ZZ337, ZZ338, ZZ339, ZZ340, ZZ346, ZZ348, ZZ349, ZZ350, ZZ351, ZZ352, ZZ353, ZZ355, ZZ357, ZZ359, ZZ360, ZZ363, ZZ364, ZZ369
iC921 发表于 2007-6-20 19:03 | 显示全部楼层
http://www.analog.com/Analog_Root/Packages/Packages_Home/0,2299,1,00.html
http://www.ti.com/sc/docs/psheets/type/type.html
wjy1107 发表于 2007-6-20 19:08 | 显示全部楼层
用根细一点的针吧
这样一把烙铁就可以咯!
 楼主| 音乐乐乐 发表于 2007-6-20 20:05 | 显示全部楼层
哈,26楼,so8有的厂商叫sop8,有的叫soic8,有的叫so8
meloncui 发表于 2007-6-20 21:35 | 显示全部楼层
熟练了就好了!
