有大侠用过motorola68000系列的cpu吗?
3456|14
 楼主| edanzg 发表于 2007-11-24 12:20 | 显示全部楼层 |阅读模式
这款cpu能否用来做10MHz以内的信号的FFT处理?
hq_y 发表于 2007-11-24 12:31 | 显示全部楼层
没有用过,但是觉得fft貌似dsp比较省心
 楼主| edanzg 发表于 2007-11-24 13:25 | 显示全部楼层
我看到一款老掉牙的示波器用68000的cpu处理信号,
想买来拆开看看。
ayb_ice 发表于 2007-11-24 13:30 | 显示全部楼层
可能不够
hq_y 发表于 2007-11-24 13:31 | 显示全部楼层
没有必要嘛
相关链接:http://www.okdsp.com/
hq_y 发表于 2007-11-24 13:32 | 显示全部楼层
我觉得你结合你现在的行业和工作学习mcu以及别的相关的外
上手比较快一点
 楼主| edanzg 发表于 2007-11-24 14:08 | 显示全部楼层
呵呵,这次主要是观摩,
感觉我们国家在这方面与国外的差距太大了!
以现在的材料和器件人家都做几十甚至几百GigaHz的示波器了!
The 9400A has been built around the powerful 68000 microprocessor which
is used by the unit to perform  computations  and control oscilloscope
operation.
 楼主| edanzg 发表于 2007-11-24 14:12 | 显示全部楼层
差距不只一点点啊,(示波器是Lecroy的)
ADCs and  Memories
2.3
The 9400A’s  two identical  input  channels  are equipped  with a
I00 megasample/second (megasample/sec), 8-bit ADC and a 32 kiloword
acquisition memory (See Figure 2.1). This dual ADC architecture ensures
absolute amplitude and phase correlation, maximum ADC performance for
both single and dual channel acquisition modes, large record lengths
and high time resolution.
The 9400A’s two 32K acquisition memories simplify transient capture by
providing very long waveform records that capture waveform features
even when trigger timing is uncertain. In addition, very accurate time
measurement is made possible by a digitally controlled zoom providing
an expansion factor of up to I00 times the time base speed.
The  9400A  oscilloscope  is  capable  of  acquiring  and  storing  repetitive
signals  at  a  Random  Interleaved  Sampling  rate  of  5  gigasamples/second
(gigasamples/sec).  An  exclusive  high-precision  time  digitizing
technique  enables  measurement  of  repetitive  signals  to  a  bandwidth  of
175  MHz at  an  effective  measuring  interval  of  200  psec.
 楼主| edanzg 发表于 2007-11-24 14:34 | 显示全部楼层
谢谢6楼老H的建议,
其实我所处的行业与这些相差比较远,关注这些是兴趣爱好的原因,可惜现在每天都为了养家糊口而奔波劳累, 可怜我空有一腔热血啊。。
hq_y 发表于 2007-11-24 14:37 | 显示全部楼层
哈哈,专注
 楼主| edanzg 发表于 2007-11-24 14:48 | 显示全部楼层
呵呵,无奈啊~~
ayb_ice 发表于 2007-11-24 15:07 | 显示全部楼层
回7L:有几十,几百GHZ的示波器吗
 楼主| edanzg 发表于 2007-11-24 16:24 | 显示全部楼层
看看这个链接,真怀疑人家是怎么做出来的,
 楼主| edanzg 发表于 2007-11-24 16:33 | 显示全部楼层
再看看Textronix的,再次强调差距啊,
huangqi412 发表于 2007-11-24 17:27 | 显示全部楼层
真是~~~~~
