5.1奉献: N bytes BIN2BCD (N<=200) 51 ASM代码
3266|8
 楼主| dengm 发表于 2009-5-4 18:58 | 显示全部楼层 |阅读模式
;SUB_BIN2BCD_N:
      ;  "二百五" 算法        DengMiao 2009-05-04 GuangZhou
      ;  Input:     @R0:  Input Bin data (LSB)
      ;              A:   BYTES of INPUT
      ;             @R1:  Output BCD Data (LSB)
      ;  Output:    @R1: Output BCD Data (LSB)
      ;             @R0: Output BCD Data (MSB)
      ;              A:  BYTES OF OUTPUT
      ;             R5:  BYTES OF OUTPUT
      ;  使用:  R0..R7, A, B, C,AC,OV,F0   Stack:2 bytes
      ;    Code:243 bytes  周期: 200 bytes 0ffh 时, 559,379周期
       InputBIN   EQU 8H  ;    200 BYTES  .... 8 TO 207  (08H to 0CFH)
       InputLen   EQU 200 ; 200 Bytes
       OutputBCD  EQU 8H  ;    241 BYTES  .....8 TO 248  (08H to 0f8h)
       STACK      EQU 249 ;      7 BYTES .. 249 TO 255  (0F9H to 0ffh)
       ORG 000H
         AJMP START
       ORG 80H
START:
        MOV SP, #(STACK-1)
        CLR A
        MOV PSW, A
        MOV R0, A
CLR_RAM:
          MOV @R0, A
          ;      MOV A, #0AAH     ; FOR TEST
        DJNZ R0, CLR_RAM
; TEST DATA INPUT:   200 Bytes 0ffh
        MOV R0, #InputBin
        MOV R2, #InputLen
        MOV A, #0FFH   ; 200 BYTES 0FFH
LLLP_R2:
          MOV @R0, A
          INC R0
        DJNZ R2, LLLP_R2
; CALL SUB
        MOV R0, #InputBin
        MOV A,  #InputLen
        MOV R1, #OutputBCD
        ACALL SUB_BIN2BCD_N
L_STOP:
        SJMP L_STOP ;$
   ORG 100H
SUB_BIN2BCD_N:
      ;  "二百五" 算法        DengMiao 2009-05-01 GuangZhou
      ;              A:   BYTES of INPUT
      ;    Code:242 bytes  周期: 200bytes 0ffh==559,379周期
      ACALL  BIN2BCD_BYTE_NUM  ; A == BCD LEN  R6==BIN_LEN
      MOV R5, A      ; BCD LEN
      MOV R2, A      ; R2: BCD LEN
      MOV A, R6
      XCH A, R1      ; R1: BIN LEN
      MOV R7, A      ; R1_BAK
      SUBB A, R0
      JZ L_R0_EQ_R1
        MOV A, R7
        JNC L_R1_GT_R0
           MOV R1, A
           MOV A, R6
           MOV R3, A
LP_R3_COPY:
             MOV A, @R0
             MOV @R1, A
             INC R0
             INC R1
           DJNZ R3, LP_R3_COPY
           SJMP L_R0_EQ_R1
L_R1_GT_R0:
           ADD A, R1
           XCH A,  R1
           MOV R3, A
           ADD A, R0
           MOV R0, A
LP_R3_COPY_V:
             DEC R0
             DEC R1
             MOV A, @R0
             MOV @R1, A
           DJNZ R3, LP_R3_COPY_V
L_R0_EQ_R1:
       MOV A, R7
       ADD A, R6
       MOV  R0, A
       MOV A, R2
       SUBB A, R6
       MOV R3, A
LP_R3_CPY:
         MOV @R0,#0
         INC R0
      DJNZ R3, LP_R3_CPY
      MOV A, R7
      MOV R1, A
      MOV A, R2
      RR A
      ANL A, #07FH
      MOV R3, A
LP_R3_SWAP:
        DEC R0
        MOV  A, @R1
        XCH A, @R0
        MOV @R1, A
        INC R1
      DJNZ R3, LP_R3_SWAP
; R7 -- BCD START
; R2 -- BCD LEN   R6 -- BIN LEN
     MOV A, R7
     MOV R0, A
     ADD A, R2
     SUBB A, R6
     MOV R7, A
;   R0 -- BCD START
;   R7 -- BIN START   R6 -- BIN LEN
     CLR F0
     MOV R4, #0FFH
     DEC R6
LP_R6:  ;<<<<===============
       MOV R2, #0
LP_R6B:
       MOV A, R6
       MOV R3, A
       MOV A, R7
       INC R7
       MOV R1, A
       CLR A
       XCH A, @R1
       INC R1
       JNZ LP_R3B2
         CJNE R6, #1, $ + 5
           SJMP LP_R3B2
           DJNZ R6, LP_R6B
           ;====================SJMP $
LP_R3B:
      XCH A, @R1
      INC R1
LP_R3B2:
      ; (R2 and 3):00    * 250
      ;           A:@R1  *   1
        MOV @R0, A    ;
        MOV B, #6
        MUL AB
        ADD A, @R1
        XCH A, B
        ADDC A, #0
        MOV @R1, A
        ADD A, @R1
        ADD A, @R1
        RLC A
        ADD A, B
        JNC $ + 5
          ADD A, #6
          INC @R1
        ;             @R0 * 250  @R1 *250 :A * 1
        XCH A, @R1
        ADD A, @R0    ; @R1 * 1  C:A * 250
        XCH A, R2
        ORL A, #11111100B
        ADDC A, #0
        MOV B, A
        JNC L_NB2
          MOV A, R1
LP_CA:
          DEC R1
          XCH A, @R1
          ADDC A, #0
          XCH A, @R1
       JC LP_CA
       MOV R1, A
L_NB2:
       MOV A, R2
       MOV C, B.0
       RRC A
       MOV C, B.1
       RRC A
     DJNZ R3, LP_R3B
     XCH A, @R1
     MOV B, R2
    ; (B AND 3) * 250 + A*1
    ANL B, #3 ; B * 250 + A
    ACALL SUB_999
   DJNZ R6, LP_R6
 ;----------------LP_R6_EXIT
   MOV A, @R1
   MOV B, R6
   ACALL SUB_999
   MOV A, R1
   XRL A, R0
   JNZ L_EXIT_A
     MOV A, R4
     MOV @R0, A
     INC R0
L_EXIT_A:
   DEC R0
   MOV A, R1
   INC A
   SUBB A, R5
   MOV R1, A
   MOV A, R5
   RET
BIN2BCD_BYTE_NUM:
     ; INPUT:  A   == BIN BYTE NUM
     ; OUTPUT: R6  == BIN BYTE NUM
     ;          A  == BCD BYTE NUM
     MOV R6, A     ;      K = I * 84&  (256 * 16)
                   ;      K = (I + K)  5 + I + 1
     MOV B, #84
     MUL AB
     MOV A, #5
     XCH A, B
     ANL A, #0F0H
     SWAP A
     ADD A, R6
     DIV AB
     ADD A, R6
     INC A
     RET
SUB_999:
    ; B * 250 + A * 1
    MOV R3, A
    MOV A, #25
    MUL AB
    XCH A, R3
    MOV B, #10
    DIV AB     ; B * 1
    ADD A, R3
    MOV R3, B   ; R3 * 1
    MOV B, #10
    DIV AB
    CJNE A, #10, L_NE10C
L_EQ10C:
        INC @R1
        MOV A, @R1
        DEC R1
      JZ L_EQ10C
      CLR A
L_NE10C:
             ; R3 * 1  B*10 A*100
    JBC F0, L_F0_1C
      SETB F0
      CJNE R4, #0FFH, L_R4_NE255C
        MOV R4, A
        SJMP L_R4_NE255BC
L_R4_NE255C:
        XCH A, R4
        MOV @R0, A
        INC R0
L_R4_NE255BC:
        MOV A, B
        SWAP A
        ADD A, R3
        MOV @R0, A
        INC R0
        RET ; R5:R4 BCD  C = 0
L_F0_1C:
       SWAP A
       ADD A, B
       XCH A, R4
       SWAP A
       ADD A, R3
       SWAP A
       MOV @R0, A
       INC R0
     RET
     END
atuz 发表于 2009-5-4 20:14 | 显示全部楼层
看不懂,呵呵
ljm810010 发表于 2009-5-4 23:13 | 显示全部楼层
也看不懂,不过还是要顶......
 楼主| dengm 发表于 2009-5-5 22:25 | 显示全部楼层
有一个bug, 已debug
Cortex-M0 发表于 2011-9-3 18:01 | 显示全部楼层
写的羼利,学习了~~~
highgear 发表于 2011-9-4 10:15 | 显示全部楼层
虽然用不着,还是顶一顶。
Cortex-M0 发表于 2011-10-9 07:37 | 显示全部楼层
俺也用不着,但邓喵老师的思路非常羼利~~~
邓喵老师的250算法,已想不出用什么词赞美了。
ayb_ice 发表于 2011-10-9 08:13 | 显示全部楼层
不知完整测试过没有
Cortex-M0 发表于 2011-10-9 08:53 | 显示全部楼层
俺测试过,算法巧妙,结果完全正确~~~
