有高手知道wg2002安装,解密的流程吗?
3433|0
 楼主| kingor_888 发表于 2007-4-9 18:19 | 显示全部楼层 |阅读模式
谢谢!<br />在xp里面可以用吗?<br />我在mentor但faq中看到:<br />//=============<br /><br />Hi&nbsp;all,<br /><br />I'm&nbsp;using&nbsp;Design&nbsp;Capture&nbsp;WG2004&nbsp;but&nbsp;after&nbsp;re-installing&nbsp;I&nbsp;get&nbsp;the&nbsp;error:&nbsp;&quot;could&nbsp;not&nbsp;process&nbsp;Design&nbsp;Capture&nbsp;product&nbsp;registry&nbsp;<br /><br />data&nbsp;-&nbsp;VBDC&quot;.&nbsp;I&nbsp;get&nbsp;the&nbsp;error&nbsp;after&nbsp;starting&nbsp;up&nbsp;Design&nbsp;Capture&nbsp;but&nbsp;I&nbsp;can&nbsp;open&nbsp;a&nbsp;schematic.&nbsp;When&nbsp;I&nbsp;try&nbsp;to&nbsp;start&nbsp;Design&nbsp;Capture&nbsp;<br /><br />from&nbsp;Expedition&nbsp;PCB,&nbsp;Design&nbsp;Capture&nbsp;<br />crashes.<br />Can&nbsp;anyone&nbsp;help&nbsp;me&nbsp;to&nbsp;fix&nbsp;this&nbsp;error.<br /><br />Best&nbsp;regards&nbsp;<br />Jack&nbsp;<br /><br /><br /><br /><br /><br />Jack,<br /><br />I&nbsp;have&nbsp;found&nbsp;that&nbsp;if&nbsp;you&nbsp;are&nbsp;using&nbsp;Windows&nbsp;XP&nbsp;you&nbsp;have&nbsp;to&nbsp;register&nbsp;the&nbsp;VBDC&nbsp;structure&nbsp;file.&nbsp;It&nbsp;is&nbsp;located&nbsp;in&nbsp;the&nbsp;'Shared'&nbsp;<br /><br />directory&nbsp;under&nbsp;your&nbsp;default&nbsp;Mentor&nbsp;directory.<br /><br />Select&nbsp;'RUN'<br /><br />type:&nbsp;regsvr32&nbsp;C:\(default&nbsp;mentor&nbsp;directory)\shared\vbdcstructsrvr40.dll<br /><br />Select&nbsp;OK.<br /><br />Example:&nbsp;regsvr32&nbsp;C:\mentor\shared\vbdcstructsrvr40.dll&nbsp;<br />//=============<br /><br />不知道是否有用?
