我的STM32核心板升级到F4了(目前可以运行u-boot)
2718|0
 楼主| 不爱说话 发表于 2013-5-8 17:25 | 显示全部楼层 |阅读模式
年初做的这个可以跑uCLinux的STM32核心板用的是STM32F103ZET6(https://bbs.21ic.com/icview-434231-1-1.html),当时已经考虑到了兼容F2,F4系列的设计。
一直没有什么时间,最近焊了一块用STM32F407ZET6的板子出来,除了MCU其他 和之前的板子一样。现在已经可以运行u-boot,并可以下载,烧写文件到NOR FLASH了,只是uCLinux还一直没编译好,一直有问题。先放上u-boot的log给大家看看
U-Boot 2010.03 (May 6 2013 - 16:17:18)
CPU  : STM32F4 (Cortex-M4)
Freqs: SYSCLK=168MHz,HCLK=168MHz,PCLK1=42MHz,PCLK2=84MHz
Board: STM3240G-EVAL board + STM-MEM add-on,Rev 2.A
DRAM:   4 MB
Flash:  8 MB
In:    serial
Out:   serial
Err:   serial
Hit any key to stop autoboot:  5  4  3  0
STM3240G-EVAL> help
?       - alias for 'help'
base    - print or set address offset
bdinfo  - print Board Info structure
bootm   - boot application image from memory
cmp     - memory compare
coninfo - print console devices and information
cp      - memory copy
cptf    - copy memory buffer to internal Flash of Cortex-M3
crc32   - checksum calculation
erase   - erase FLASH memory
flinfo  - print FLASH memory information
go      - start application at address 'addr'
help    - print command description/usage
loadb   - load binary file over serial line (kermit mode)
loady   - load binary file over serial line (ymodem mode)
loop    - infinite loop on address range
md      - memory display
mm      - memory modify (auto-incrementing address)
mtest   - simple RAM read/write test
mw      - memory write (fill)
nm      - memory modify (constant address)
printenv- print environment variables
protect - enable or disable FLASH write protection
reset   - Perform RESET of the CPU
run     - run commands in an environment variable
saveenv - save environment variables to persistent storage
setenv  - set environment variables
version - print monitor version
STM3240G-EVAL>
个人签名:飞翼电子工作室 http://shop68798667.taobao.com/
115
