#C 程序 是用来做数字电压表的 哪位大神帮着找找错误吧 谢啦
1422|1
 楼主| cai11235 发表于 2013-5-26 12:14 | 显示全部楼层 |阅读模式
#include "reg51.h"
#include "intrins.h"
#define   ad_con       P2
#define   addata       P0
#define   Disdata      P1
#define uchar unsigned char
#define unit unsigned int
sbit     ALE=P2^3;
sbit     START=P2^4;
sbit     OE=P2^5;
sbit     EOC=P3^7;
uchar code dis_7[11]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x77};
char code  scan_con[4]={0xFE,0xFD,0xFB,0xF7};
char data  ad_data[8]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
char data  dis[5]={0x00,0x00,0x00,0x00,0x00};
delay1ms(unit t)
unit i,j;
for(i=0;i<t;i++)
    for(j=0;j<120;j++)
scan()
uchar k,n;
unit h;
dis[3]=0x00;
for(n=0;n<8;n++)
dis[2]=ad_data[n]/100;
dis[4]=ad_data[n]%100;
dis[1]=dis[4]/10;
dis[0]=dis[4]%10;
for(h=0;h<500;h++)
  for(k=0;k<4;k++)
   Disdata=dis_7[dis[k]];P3=scan_con[k];delay1ms(1);P3=0xFF;
  dis[3]++;
test()
char m;
char s=0x00;
ad_con=s;
for(m=0;m<8;m++)
  ALE=1;_nop_();_nop_();ALE=0;
  START=1;_nop_();_nop_();START=0;
  _nop_();_nop_();_nop_();_nop_();
  while(EOC==0);
  OE=1;ad_data[m]=addata;OE=0;s++;ad_con=s;
ad_con=0x00;
main()
P0=0xFF;
P2=0x00;
P1=0xFF;
P3=0xFF;
while(1)
  scan();
  test();
dirtwillfly 发表于 2013-5-26 12:56 | 显示全部楼层
一句注释也没有~~
改错题
