28335测试超声波遇到的问题
2055|3
 楼主| someontime 发表于 2013-5-29 23:32 | 显示全部楼层 |阅读模式
在CCS4.1环境下编译与链接生成的文件。源码和项目文件见附件。
给超声波模块给的Trig引脚10us的高电平,用PIE中断捕获Echo引脚的高电平持续时间,最后用串口输出结果。
编译能通过,但是程序运行之后,不论距离障碍物有多远,每次超声波输出的值都相同。觉得问题有可能出在时钟。请大侠不吝赐教,谢谢!
主函数:
#include "DSP28x_Project.h"     // Device Headerfile and Examples Include File
#include "systimer.h"
#define          LED1        GpioDataRegs.GPBDAT.bit.GPIO60
#define          LED2        GpioDataRegs.GPBDAT.bit.GPIO61
#define   Trig  GpioDataRegs.GPADAT.bit.GPIO12
#define   Echo  GpioDataRegs.GPADAT.bit.GPIO13
interrupt void xint2_isr(void);
void scic_echoback_init(void);
void scic_fifo_init(void);
void scic_xmit(int a);
void scic_msg(char *msg);
void InitLED(void);
void Init_ultrasonic(void);
Uint32 begin_time=0;
Uint32 over_time=0;
Uint32 period=0;
float displacement=0.0;
Uint32 H_displacement=0;
Uint32 L_displacement=0;
Uint16 flag=0;
void main(void)
   char *msg;
// Step 1. Initialize System Control:
// PLL, WatchDog, enable Peripheral Clocks
// This example function is found in the DSP2833x_SysCtrl.c file.
   InitSysCtrl();
// Step 2. Initalize GPIO:
// This example function is found in the DSP2833x_Gpio.c file and
// illustrates how to set the GPIO to it's default state.
// InitGpio();  // Skipped for this example
   InitScicGpio();
// Step 3. Clear all interrupts and initialize PIE vector table:
// Disable CPU interrupts
   DINT;
// Initialize the PIE control registers to their default state.
// The default state is all PIE interrupts disabled and flags
// are cleared.
// This function is found in the DSP2833x_PieCtrl.c file.
   InitPieCtrl();
// Disable CPU interrupts and clear all CPU interrupt flags:
   IER = 0x0000;
   IFR = 0x0000;
   InitPieVectTable();
   EALLOW;        // This is needed to write to EALLOW protected registers
   PieVectTable.XINT2 = &xint2_isr;
   EDIS;   // This is needed to disable write to EALLOW protected registers
// Interrupts that are used in this example are re-mapped to
// ISR functions found within this file.
// Step 4. Initialize the Device Peripheral. This function can be
//         found in DSP2833x_CpuTimers.c
   InitCpuTimers();   // For this example, only initialize the Cpu Timers
   InitSystimer(&CpuTimer1);   //初始化CPUTimer1
// To ensure precise timing, use write-only instructions to write to the entire register. Therefore, if any
// of the configuration bits are changed in ConfigCpuTimer and InitCpuTimers (in DSP2833x_CpuTimers.h), the
// below settings must also be updated.
   StartCpuTimer1();
// Step 5. User specific code, enable interrupts:
   PieCtrlRegs.PIECTRL.bit.ENPIE = 1;          // Enable the PIE block
   PieCtrlRegs.PIEIER1.bit.INTx5 = 1;          // Enable PIE Gropu 1 INT2
   IER |= M_INT1;
// Enable global Interrupts and higher priority real-time debug events:
   EINT;   // Enable Global interrupt INTM
//  ERTM;   // Enable Global realtime interrupt DBGM
   scic_fifo_init();           // Initialize the SCI FIFO
   scic_echoback_init();  // Initalize SCI for echoback
//   msg = "\r\n\n\nHello\0";
//   scic_msg(msg);
   InitLED();
   Init_ultrasonic();
   LED1=0;
   LED2=1;
   Trig=0;
// Step 6. IDLE loop. Just sit and loop forever (optional):
   for(;;)
             Trig=1;
             DELAY_US(10);
             Trig=0;
/*             while(1)
                     if(Echo==1)
                             //begin_time=CpuTimer1Regs.PRD.all;
                             //StartCpuTimer1();
                             begin_time=CpuTimer1Regs.TIM.all;
                             flag=1;
                             break;
                     if(flag==1&&Echo==0)
                             //StopCpuTimer1();
                             over_time=CpuTimer1Regs.TIM.all;
                             period=begin_time-over_time;
                             displacement=340*period*100/1000/2;
                      H_displacement=(displacement>>16);
                      L_displacement=displacement;
                      scic_xmit(H_displacement>>8);
                      scic_xmit(H_displacement);
                      scic_xmit(L_displacement>>8);
                      scic_xmit(L_displacement);
                       flag=0;
      break;
   //period=begin_time-over_time;
   displacement=170*period*0.00667*1000;
   H_displacement=((int)displacement>>16);
   L_displacement=(int)displacement;
void scic_echoback_init()
    // Note: Clocks were turned on to the SCIA peripheral
    // in the InitSysCtrl() function
         ScicRegs.SCICCR.all =0x0007;   // 1 stop bit,  No loopback
                                   // No parity,8 char bits,
                                   // async mode, idle-line protocol
        ScicRegs.SCICTL1.all =0x0003;  // enable TX, RX, internal SCICLK,
                                   // Disable RX ERR, SLEEP, TXWAKE
        ScicRegs.SCICTL2.all =0x0003;
        ScicRegs.SCICTL2.bit.TXINTENA = 1;
        ScicRegs.SCICTL2.bit.RXBKINTENA =1;
        #if (CPU_FRQ_150MHZ)
              ScicRegs.SCIHBAUD    =0x0001;  // 9600 baud @LSPCLK = 37.5MHz.
              ScicRegs.SCILBAUD    =0x00E7;
        #endif
        #if (CPU_FRQ_100MHZ)
      ScicRegs.SCIHBAUD    =0x0001;  // 9600 baud @LSPCLK = 20MHz.
      ScicRegs.SCILBAUD    =0x0044;
        #endif
        ScicRegs.SCICTL1.all =0x0023;  // Relinquish SCI from Reset
// Transmit a character from the SCI
    while (ScicRegs.SCIFFTX.bit.TXFFST != 0) {}
    ScicRegs.SCITXBUF=a;
void scic_msg(char * msg)
    int i;
    i = 0;
    while(msg != '\0')
        scic_xmit(msg);
        i++;
// Initalize the SCI FIFO
void scic_fifo_init()
    ScicRegs.SCIFFTX.all=0xE040;
    ScicRegs.SCIFFRX.all=0x204f;
    ScicRegs.SCIFFCT.all=0x0;
void InitLED(void)
   EALLOW;
   GpioCtrlRegs.GPBMUX2.bit.GPIO60 = 0; // GPIO60 = GPIO60
   GpioCtrlRegs.GPBDIR.bit.GPIO60 = 1;
   GpioCtrlRegs.GPBMUX2.bit.GPIO61 = 0; // GPIO61 = GPIO61
   GpioCtrlRegs.GPBDIR.bit.GPIO61 = 1;
   EDIS;
        EALLOW;
        GpioCtrlRegs.GPAMUX1.bit.GPIO12 = 0; // GPIO12 = GPIO12
         GpioCtrlRegs.GPADIR.bit.GPIO12 = 1;  //  Output
         GpioCtrlRegs.GPAMUX1.bit.GPIO13 = 0; // GPIO13 = GPIO13
         GpioCtrlRegs.GPADIR.bit.GPIO13 = 0; // Input
         GpioCtrlRegs.GPAQSEL1.bit.GPIO13 = 0;        // XINT2 Synch to SYSCLKOUT only
         EDIS;
         EALLOW;
           GpioIntRegs.GPIOXINT2SEL.bit.GPIOSEL = 13;   // XINT2 is GPIO13
           EDIS;
           EALLOW;
           XIntruptRegs.XINT2CR.bit.POLARITY = 3;      //Rising & Falling edge interrupt
           XIntruptRegs.XINT2CR.bit.ENABLE =1;         //Enable Xint2
           EDIS;
        LED1=~LED1;
        if(flag==0)
                //StartCpuTimer1();
                     flag=1;
                     LED2=~LED2;
                     PieCtrlRegs.PIEACK.all = PIEACK_GROUP1;
        else
                //StopCpuTimer1();
                     //displacement=340*period*100/1000/2;
                     flag=0;
                     LED2=~LED2;
zhangmangui 发表于 2013-5-30 10:39 | 显示全部楼层
时钟设置在这个函数里面啊 InitSysCtrl();
还有各个模块时钟的使能  忘了在那个函数里面   你可以去找找
zx12305656 发表于 2019-3-2 20:36 | 显示全部楼层
你好楼主解决了吗,能看看吗
