[AVR单片机] mega16+25lc256读不出数据
2287|14
 楼主| jiongeyes 发表于 2013-6-4 15:09 | 显示全部楼层 |阅读模式
#include<iom16v.h>
#define BAUD 9600               //波特率采用9600ps
#define CRYSTAL 8000000           //系统时钟8MHz
#define BAUD_SETTING (unsigned char)((unsigned long)CRYSTAL/(16*(unsigned long)BAUD)-1)  // 设置波特率
#define BAUD_H (unsigned char)(BAUD_SETTING>>8)
#define BAUD_L (unsigned char)(BAUD_SETTING)
#define _nop()   #asm("nop")
#define LED_COM  PORTD ^= (1<<PD5)
//25LC256//////////////////////
#define WRSR     0x01    //写状态寄存器
#define WRITE    0x02    //写命令
#define READ     0x03    //读命令
#define WRDI     0x04    //写禁止
#define RDSR     0x05    //读状态寄存器
#define WREN     0x06    //写允许
//PORTB////////////////////////
#define WP       3
#define SS       4
#define MOSI     5
#define MISO     6
#define SCK      7
//PORTD////////////////////////
#define EN_485   4
#define RUN      5
void  delay(unsigned char k) //延时ms
    unsigned char j;
        for (;k>0;k--)
           for(j=220;j>0;j--)
            _nop();
            _nop();
            _nop();
            _nop();
            _nop();
            _nop();
            _nop();
            _nop();
            _nop();
            _nop();
////////////////RS232////////////////////
void USART_Init()           //232波特率初始化
    UBRRH = BAUD_H;
    UBRRL = BAUD_L;
    UCSRB |= (1<<RXEN)|(1<<TXEN);            //接收器与发送器使能
    UCSRC = (1<<URSEL)|(1<<UCSZ0)|(1<<UCSZ1);        //设置帧格式:8个数据位,1个停止位
///////////////458发送///////////////////
void UART_TX485( unsigned char data )
    PORTD |= (1<<EN_485);
    delay(2);
    while ( !( UCSRA & (1<<UDRE)) );
    UDR = data;
    while(!(UCSRA & (1<<UDRE)));
    delay(4);
    PORTD &= ~(1<<EN_485);                          // 将数据放入缓冲器,发送数据
/////////////////SPI 主机设置//////////////////////////////
void SPI_MasterInit(void)
    DDRB |= (1<<SS)|(1<<MOSI)|(1<<SCK);
    PORTB |= (1<<SS);
    SPCR = (1<<SPE)|(1<<MSTR);// 设置为主机模式,使能SPI,时钟为fosc/4
////////////////////SPI发送////////////////
void SPI_TX(unsigned char cdata)
    SPDR = cdata;
    while(!(SPSR & (1<<SPIF)));
//SPI读
unsigned char SPIRead(unsigned int SpiAddress)
    unsigned char i,add_H,add_L;
    add_H = SpiAddress >> 8;
    add_L = SpiAddress & 0x00FF;
    PORTB &= ~(1<<SS);
        SPI_TX(READ);
    SPI_TX(add_H);
    SPI_TX(add_L);
    SPI_TX(0xFF);
    i = SPDR;
        PORTB |= (1<<SS);
    return i;
//SPI写
void SPIWrite(unsigned int SpiAddress,unsigned char edata)//*ramadr,unsigned char width)
    PORTB &= ~(1<<SS);
    SPI_TX(WREN);   //写使能
    PORTB |= (1<<SS);//锁存写使能命令
        delay(50);
    add_L = SpiAddress && 0x00FF;
    PORTB &= ~(1<<SS);
    SPI_TX(WRITE);
        SPI_TX(add_H);
    SPI_TX(add_L);
    SPI_TX(edata);
        PORTB |= (1<<SS);
//端口初始化///////////////////////////
void PORT_Init()
    DDRB = 0x00;
    DDRB |= (1<<WP);
    DDRD |= (1<<EN_485)|(1<<RUN);
    PORTD |= (1<<RUN);
    PORTB |= (1<<WP);   //低电平为写保护,高电平写使能允许
//主程序////////////////////////
void main(void)
    unsigned char temp,i;
    i = 0x43;
    SREG = 0x00;
    USART_Init();
    SPI_MasterInit();
    PORT_Init();
    SREG = 0x80;
    while(1)
        SPIWrite(0x0001,i);
        _nop();
        _nop();
        delay(200);
        temp = SPIRead(0x0001);
        _nop();
        _nop();
        delay(5);
        UCSRB &= ~(1<<RXCIE);
        _nop();
        UART_TX485(temp);
        _nop();
        UCSRB |= (1<<RXCIE);
        UART_TX485(0x45);
        _nop();
        _nop();
用cvavr2.03.4写的程序
是不是初始化时要发WRSR命令,写状态寄存,然后写入0X02
麻烦各位看看是否我程序有什么地方错了吗,i=0X43但不管怎么样,写进去, 读出来的永远都是00
huangxz 发表于 2013-6-4 18:58 | 显示全部楼层
拿示波器看一下吧,这类芯片也就时序对了数据肯定是对的
评分
参与人数 1威望 +6 收起 理由
qin552011373 + 6 很给力!
查看全部评分
qin552011373 发表于 2013-6-4 21:03 | 显示全部楼层
示波器应该够呛吧  是不是要用逻辑分析仪了
huangxz 发表于 2013-6-4 22:12 | 显示全部楼层
:lol逻辑分析仪也是可以的,比如40多块钱那种的就很好用
 楼主| jiongeyes 发表于 2013-6-5 09:01 | 显示全部楼层
两者都没有,有没有推荐一款便宜好用的
qin552011373 发表于 2013-6-5 09:26 | 显示全部楼层
40?
qin552011373 发表于 2013-6-5 09:27 | 显示全部楼层
两者都没有,有没有推荐一款便宜好用的
让楼上推荐一下吧
qin552011373 发表于 2013-6-5 09:29 | 显示全部楼层
40的有哪个牌子的?自己做的吗?
huangxz 发表于 2013-6-5 09:45 | 显示全部楼层
40的有哪个牌子的?自己做的吗?
叫saleae8可以测八通道,宝宝上很多的
qin552011373 发表于 2013-6-5 15:22 | 显示全部楼层
好心动
gdxizhilang 发表于 2013-6-5 15:33 | 显示全部楼层
先用单步调,看看到哪里出问题了。
gdxizhilang 发表于 2013-6-5 15:35 | 显示全部楼层
调程序,要慢慢来,一步一步的,我最早什么仪器也没有,自己摸索出来的。
评分
参与人数 1威望 +6 收起 理由
查看全部评分
 楼主| jiongeyes 发表于 2013-6-5 17:12 | 显示全部楼层
调程序,要慢慢来,一步一步的,我最早什么仪器也没有,自己摸索出来的。 ...
我是怀疑我的程序是否有错,我也调过一步一步调,到了写WREN,然后RDSR读出来寄存器WEL位总是0,没有置1
不明白是怎么回事
qin552011373 发表于 2013-6-6 13:56 | 显示全部楼层
基本都是自己头脑里先运行一下的
gdxizhilang 发表于 2013-6-6 14:47 | 显示全部楼层
关键还是要多读手册,有时候有些状态位写1的时候是清空,读得时候就是0啊。
真正弄懂了手册才行。
