请教一个ds1302的问题,附带了C程序
1719|1
 楼主| liuw_zh 发表于 2007-7-9 10:37 | 显示全部楼层 |阅读模式
//--------------------------------------------------------------------<br />#define&nbsp;uchar&nbsp;unsigned&nbsp;char<br />#define&nbsp;uint&nbsp;&nbsp;unsigned&nbsp;int<br />#define&nbsp;success&nbsp;&nbsp;&nbsp;1<br />#define&nbsp;failure&nbsp;&nbsp;&nbsp;0<br /><br />sbit&nbsp;ACC0&nbsp;&nbsp;=&nbsp;ACC^0;<br />sbit&nbsp;ACC7&nbsp;&nbsp;=&nbsp;ACC^7;<br />typedef&nbsp;struct&nbsp;&nbsp;{<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;unsigned&nbsp;char&nbsp;second;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;unsigned&nbsp;char&nbsp;minute;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;unsigned&nbsp;char&nbsp;hour;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;unsigned&nbsp;char&nbsp;date;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;unsigned&nbsp;char&nbsp;month;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;unsigned&nbsp;char&nbsp;week;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;unsigned&nbsp;char&nbsp;year;<br />&nbsp;}&nbsp;TIME;<br />extern&nbsp;TIME&nbsp;idata&nbsp;g_time;<br />/*********************************************************************/<br />//&nbsp;当前时间格式为:&nbsp;秒&nbsp;分&nbsp;时&nbsp;日&nbsp;月&nbsp;星期&nbsp;年<br />uchar&nbsp;code&nbsp;time_init[]={0x40,0x04,0x16,0x09,0x02,0x04,0x06};<br />//--------------------------------------------------------------------<br />void&nbsp;init_ds1302(void)<br />{<br />&nbsp;&nbsp;&nbsp;T_RST&nbsp;=&nbsp;0;<br />&nbsp;&nbsp;&nbsp;T_CLK&nbsp;=&nbsp;0;<br />&nbsp;&nbsp;&nbsp;T_RST&nbsp;=&nbsp;1;<br />}<br />//--------------------------------------------------------------------<br />void&nbsp;stop_ds1302(void)<br />{<br />&nbsp;&nbsp;&nbsp;T_CLK&nbsp;=&nbsp;1;<br />&nbsp;&nbsp;&nbsp;T_RST&nbsp;=&nbsp;0;<br />}<br />//********************************************************************<br />void&nbsp;write_byte_ds1302(unsigned&nbsp;char&nbsp;l_data)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;//&nbsp;1100us<br />{<br />&nbsp;&nbsp;uchar&nbsp;i;<br />&nbsp;&nbsp;ACC&nbsp;=&nbsp;l_data;<br />&nbsp;&nbsp;for(i=8;&nbsp;i&gt0;&nbsp;i--)<br />&nbsp;&nbsp;&nbsp;&nbsp;{<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;T_IO&nbsp;&nbsp;=&nbsp;ACC0;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;T_CLK&nbsp;=&nbsp;1;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;T_CLK&nbsp;=&nbsp;0;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;ACC&nbsp;&nbsp;&nbsp;=&nbsp;ACC&nbsp;&gt&gt&nbsp;1;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;//&nbsp;2us<br />&nbsp;&nbsp;&nbsp;&nbsp;}<br />}<br />//********************************************************************<br />unsigned&nbsp;char&nbsp;read_byte_ds1302(void)<br />{<br />&nbsp;&nbsp;uchar&nbsp;i;<br />&nbsp;&nbsp;for(i=8;&nbsp;i&gt0;&nbsp;i--)<br />&nbsp;&nbsp;&nbsp;&nbsp;{<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;ACC&nbsp;&nbsp;&nbsp;=&nbsp;ACC&nbsp;&gt&gt&nbsp;1;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if(ACC&0x01)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;//&nbsp;2us<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;ACC&nbsp;|=&nbsp;0x80;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;//&nbsp;1us<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;ACC7&nbsp;&nbsp;=&nbsp;T_IO;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;//&nbsp;3us<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;T_CLK&nbsp;=&nbsp;1;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;T_CLK&nbsp;=&nbsp;0;<br />&nbsp;&nbsp;&nbsp;&nbsp;}<br />&nbsp;&nbsp;return&nbsp;ACC;<br />}<br />//-----------------------------------------------------------<br />void&nbsp;cancle_ds1302_wp(void)<br />{<br />&nbsp;&nbsp;&nbsp;init_ds1302();<br />&nbsp;&nbsp;&nbsp;write_byte_ds1302(0x8e);&nbsp;&nbsp;&nbsp;&nbsp;//&nbsp;地址,命令数?<br />&nbsp;&nbsp;&nbsp;write_byte_ds1302(0x00);&nbsp;&nbsp;&nbsp;&nbsp;//&nbsp;写1Byte?<br />&nbsp;&nbsp;&nbsp;stop_ds1302();<br />}<br />//-----------------------------------------------------------<br />void&nbsp;set_ds1302_wp(void)<br />{<br />&nbsp;&nbsp;&nbsp;init_ds1302();<br />&nbsp;&nbsp;&nbsp;write_byte_ds1302(0x8e);&nbsp;&nbsp;&nbsp;//&nbsp;地址,命令<br />&nbsp;&nbsp;&nbsp;write_byte_ds1302(0x80);&nbsp;&nbsp;&nbsp;//&nbsp;写1Byte数据<br />&nbsp;&nbsp;&nbsp;stop_ds1302();<br />}<br />//********************************************************************<br />void&nbsp;read_time_ds1302_burst(void)<br />{<br />&nbsp;&nbsp;init_ds1302();<br />&nbsp;&nbsp;write_byte_ds1302(0xbf);&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;//&nbsp;0xbf:时钟多字节读命令<br />&nbsp;&nbsp;g_time.second&nbsp;=&nbsp;read_byte_ds1302();<br />&nbsp;&nbsp;g_time.minute&nbsp;=&nbsp;read_byte_ds1302();<br />&nbsp;&nbsp;g_time.hour&nbsp;&nbsp;&nbsp;=&nbsp;read_byte_ds1302();<br />&nbsp;&nbsp;g_time.date&nbsp;&nbsp;&nbsp;=&nbsp;read_byte_ds1302();<br />&nbsp;&nbsp;g_time.month&nbsp;&nbsp;=&nbsp;read_byte_ds1302();<br />&nbsp;&nbsp;g_time.week&nbsp;&nbsp;&nbsp;=&nbsp;read_byte_ds1302();<br />&nbsp;&nbsp;g_time.year&nbsp;&nbsp;&nbsp;=&nbsp;read_byte_ds1302();<br />&nbsp;&nbsp;stop_ds1302();<br />}<br />/********************************************************************<br />*&nbsp;说明:&nbsp;先写地址,后写数据(时钟多字节方式)<br />*&nbsp;输入:&nbsp;pSecDa:&nbsp;时钟数据地址&nbsp;格式为:&nbsp;秒&nbsp;分&nbsp;时&nbsp;日&nbsp;月&nbsp;星期&nbsp;年&nbsp;控制<br />*&nbsp;7Byte&nbsp;(BCD码)&nbsp;&nbsp;+&nbsp;1Byte(控制字)<br />***********************************************************************/<br />void&nbsp;set_time_ds1302_burst(void&nbsp;&nbsp;*pSecDa)<br />{<br />&nbsp;&nbsp;uchar&nbsp;i;<br />&nbsp;&nbsp;cancle_ds1302_wp();<br />&nbsp;&nbsp;init_ds1302();<br />&nbsp;&nbsp;write_byte_ds1302(0xbe);&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;//&nbsp;0xbe:时钟多字节写命令<br />&nbsp;&nbsp;for(i=0;&nbsp;i&lt8;&nbsp;i++)<br />&nbsp;&nbsp;&nbsp;&nbsp;{<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;write_byte_ds1302(*(uchar*)pSecDa);<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;((uchar*)pSecDa)++;<br />&nbsp;&nbsp;&nbsp;&nbsp;}<br />&nbsp;&nbsp;stop_ds1302();<br />}<br />/********************************************************************<br />*&nbsp;说明:&nbsp;先写地址,后写命令/数据?<br />*&nbsp;Address:&nbsp;0&lt--&gt31<br />*&nbsp;Command&nbsp;=&nbsp;(1&nbsp;1&nbsp;x&nbsp;x&nbsp;x&nbsp;x&nbsp;x&nbsp;0)0xc0|(address&lt&lt1)<br />***********************************************************************/<br />void&nbsp;write_one_byte_ds1302(unsigned&nbsp;char&nbsp;Address,&nbsp;&nbsp;unsigned&nbsp;char&nbsp;Data)<br />{<br />&nbsp;&nbsp;&nbsp;&nbsp;cancle_ds1302_wp();<br />&nbsp;&nbsp;&nbsp;&nbsp;init_ds1302();<br />&nbsp;&nbsp;&nbsp;&nbsp;write_byte_ds1302(0xc0|(Address&lt&lt1));&nbsp;/*&nbsp;写地址,命令&nbsp;*/<br />&nbsp;&nbsp;&nbsp;&nbsp;write_byte_ds1302(Data);&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;/*&nbsp;写1Byte数据*/<br />&nbsp;&nbsp;&nbsp;&nbsp;stop_ds1302();<br />&nbsp;&nbsp;&nbsp;&nbsp;set_ds1302_wp();<br />}<br />/********************************************************************<br />*&nbsp;说明:&nbsp;先写地址,后读命令/数据<br />*&nbsp;Address:&nbsp;0&lt--&gt31<br />*&nbsp;1&nbsp;1&nbsp;x&nbsp;x&nbsp;x&nbsp;x&nbsp;x&nbsp;1<br />*&nbsp;Command&nbsp;=&nbsp;(1&nbsp;1&nbsp;x&nbsp;x&nbsp;x&nbsp;x&nbsp;x&nbsp;1)0xc1|(address&lt&lt1)<br />***********************************************************************/<br />unsigned&nbsp;char&nbsp;read_one_byte_ds1302(unsigned&nbsp;char&nbsp;Address)<br />{<br />&nbsp;&nbsp;&nbsp;&nbsp;unsigned&nbsp;char&nbsp;rtn_value;<br />&nbsp;&nbsp;&nbsp;&nbsp;if(Address&gt30)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Address&nbsp;-=&nbsp;30;<br />&nbsp;&nbsp;&nbsp;&nbsp;init_ds1302();<br />&nbsp;&nbsp;&nbsp;&nbsp;write_byte_ds1302(0xc1|(Address&lt&lt1));&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;/*&nbsp;写地址,命令&nbsp;*/<br />&nbsp;&nbsp;&nbsp;&nbsp;rtn_value&nbsp;=&nbsp;read_byte_ds1302();&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;/*&nbsp;读1Byte数据&nbsp;*/<br />&nbsp;&nbsp;&nbsp;&nbsp;stop_ds1302();<br />&nbsp;&nbsp;&nbsp;&nbsp;return(rtn_value);<br />}<br />/********************************************************<br />*&nbsp;说明:&nbsp;先写地址,后读命令/数据&nbsp;涓流充电]<br />*&nbsp;command&nbsp;0x90(write)&nbsp;&nbsp;0x91(read)<br />*&nbsp;&nbsp;&nbsp;tcs&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;ds&nbsp;ds&nbsp;rs&nbsp;rs<br />*&nbsp;(1&nbsp;0&nbsp;1&nbsp;0)&nbsp;&nbsp;0&nbsp;&nbsp;1&nbsp;&nbsp;&nbsp;0&nbsp;&nbsp;1&nbsp;&nbsp;0xa5&nbsp;&nbsp;Imax&nbsp;=&nbsp;(5-0.7)/2k&nbsp;=&nbsp;2.2MA<br />***********************************************************************/<br />//void&nbsp;trickle_ds1302(unsigned&nbsp;char&nbsp;ds,&nbsp;unsigned&nbsp;char&nbsp;rs)<br />void&nbsp;trickle_ds1302(void)<br />{<br />&nbsp;&nbsp;&nbsp;&nbsp;volatile&nbsp;&nbsp;uchar&nbsp;i;<br />&nbsp;&nbsp;&nbsp;&nbsp;cancle_ds1302_wp();<br />&nbsp;&nbsp;&nbsp;&nbsp;init_ds1302();<br />&nbsp;&nbsp;&nbsp;&nbsp;i=0;<br />&nbsp;&nbsp;&nbsp;&nbsp;write_byte_ds1302(0x90);&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;/*&nbsp;写地址,命令&nbsp;*/<br />&nbsp;&nbsp;&nbsp;&nbsp;//write_byte_ds1302(0xa0|((ds&0x03)&lt&lt2)|(rs&0x03));&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;/*&nbsp;读1Byte数据&nbsp;*/<br />&nbsp;&nbsp;&nbsp;&nbsp;i&nbsp;=&nbsp;1;<br />&nbsp;&nbsp;&nbsp;&nbsp;write_byte_ds1302(0xa5);&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;/*&nbsp;读1Byte数据&nbsp;*/<br />&nbsp;&nbsp;&nbsp;&nbsp;i&nbsp;=&nbsp;2;<br />&nbsp;&nbsp;&nbsp;&nbsp;stop_ds1302();<br />&nbsp;&nbsp;&nbsp;&nbsp;set_ds1302_wp();<br />}<br />/**********************************************************************<br />*&nbsp;说明:&nbsp;先写地址,后读命令/数据&nbsp;涓流充电]<br />*&nbsp;Imax&nbsp;=&nbsp;(5-0.7)/2k&nbsp;=&nbsp;2.2MA<br />***********************************************************************/<br />bit&nbsp;initiate_ds1302(void)<br />{<br />&nbsp;&nbsp;&nbsp;&nbsp;unsigned&nbsp;char&nbsp;&nbsp;value;<br />&nbsp;&nbsp;&nbsp;&nbsp;value&nbsp;=&nbsp;read_one_byte_ds1302(29);<br />&nbsp;&nbsp;&nbsp;&nbsp;if(value&nbsp;==&nbsp;0xaa)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;{<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;value&nbsp;=&nbsp;read_one_byte_ds1302(30);<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if(value&nbsp;==&nbsp;0x55)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;return&nbsp;(success);<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;}<br />&nbsp;&nbsp;&nbsp;&nbsp;cancle_ds1302_wp();<br />&nbsp;&nbsp;&nbsp;&nbsp;init_ds1302();<br />&nbsp;&nbsp;&nbsp;&nbsp;write_byte_ds1302(0x80);&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;//&nbsp;start&nbsp;clock&nbsp;&nbsp;&nbsp;&nbsp;(1)<br />&nbsp;&nbsp;&nbsp;&nbsp;write_byte_ds1302(0x00);<br />&nbsp;&nbsp;&nbsp;&nbsp;write_byte_ds1302(0x84);&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;//&nbsp;set&nbsp;&nbsp;&nbsp;pm&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(2)<br />&nbsp;&nbsp;&nbsp;&nbsp;write_byte_ds1302(0x00);<br />&nbsp;&nbsp;&nbsp;&nbsp;write_byte_ds1302(0x90);&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;//&nbsp;set&nbsp;trickle&nbsp;&nbsp;&nbsp;&nbsp;(3)<br />&nbsp;&nbsp;&nbsp;&nbsp;write_byte_ds1302(0xa5);<br />&nbsp;&nbsp;&nbsp;&nbsp;stop_ds1302();<br />&nbsp;&nbsp;&nbsp;&nbsp;set_ds1302_wp();<br />&nbsp;&nbsp;&nbsp;&nbsp;set_time_ds1302_burst(time_init);//&nbsp;initinal&nbsp;time&nbsp;&nbsp;(4)<br />&nbsp;&nbsp;&nbsp;&nbsp;write_one_byte_ds1302(29,0xaa);<br />&nbsp;&nbsp;&nbsp;&nbsp;write_one_byte_ds1302(30,0x55);<br />&nbsp;&nbsp;&nbsp;&nbsp;value&nbsp;=&nbsp;read_one_byte_ds1302(29);<br />&nbsp;&nbsp;&nbsp;&nbsp;if(value&nbsp;==&nbsp;0xaa)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;{<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;value&nbsp;=&nbsp;read_one_byte_ds1302(30);<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if(value&nbsp;==&nbsp;0x55)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;return&nbsp;(success);<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;else<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;return&nbsp;(failure);<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;}<br />&nbsp;&nbsp;&nbsp;&nbsp;else<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;return&nbsp;(failure);<br />}<br />//---------------------------------------------------------------------<br /><br />修改时间,我调用的是write_one_byte_ds1302(unsigned&nbsp;char&nbsp;Address,&nbsp;&nbsp;unsigned&nbsp;char&nbsp;Data);不知道对不对,如果我想修改年份&nbsp;Address&nbsp;应该是多少?实在不解,还望各位大虾指教!
dai_weis 发表于 2007-7-9 11:36 | 显示全部楼层
最新的数据手册有介绍
