DA所用为AD5662,官方给的一段程序为
- * Function: AD5662_reg_write
- * Description: writes to the AD5662 via the SPI port.
- P1.4->SCLK,P1.6->DIN,P2.5->/SYNC
- void AD5662_reg_write(unsigned int Mode, unsigned int RegisterData)
- unsigned int ControlValue = 0;
- unsigned int i = 0;
- //Create the 24-bit
- ControlValue = (Mode << 16) | RegisterData;
- SET_CS();
- CLR_SCL();
- delay(3);
- CLR_CS(); //bring CS low
- delay(3);
- //Write out the control word
- for(i=0; i<24; i++)
- SET_SCL();
- if(0x800000 == (ControlValue & 0x800000))
- SET_SDO(); //Send one to SDO pin
- else
- CLR_SDO(); //Send zero to SDO pin
- delay(3);
- CLR_SCL();
- delay(3);
- ControlValue <<= 1; //Rotate data
- SET_CS(); //bring CS high again
移植到PIC16F1936后的代码为
- //************************DA写数据程序***********************************************
- * Description: 输入参数为选通的通道号码,进行的模式,写入的数据
- void AD5662_reg_write(unsigned int En_DA_Num, unsigned long Mode, unsigned long RegisterData)
- unsigned long ControlValue = 0;
- ControlValue = (Mode << 16)| RegisterData;
- SET_CS();//片选位拉高
- CLR_SCL();//时钟拉高
- delayR();//延时
- delayR();//延时
- delayR();//延时
- switch(En_DA_Num)//根据使能的口,拉低片选位,使数据有效
- case 1: CLR_CS1(); break;
- case 2: CLR_CS2(); break;
- case 3: CLR_CS3(); break;
- case 4: CLR_CS4(); break;
- case 5: CLR_CS5(); break;
- case 6: CLR_CS6(); break;
- case 7: CLR_CS7(); break;
- default: SET_CS(); break;//如果都不是,Y1-Y7都关闭,此时无法写入数据
- delayR();//延时
- SET_SCL();//时钟拉高
- if(0x800000 == (ControlValue & 0x800000))//发送数据
- else
- delayR();//数据保持
- CLR_SCL();//时钟拉低
- delayR();//数据保持
- delayR();//数据保持
- SET_CS();//把片选位拉高
- delayR();//数据保持
- void delayR()//延时1us,16MHZ
- NOP();NOP();NOP();NOP();
只修改延时函数,但是DA结果无输出,官方的程序应该也是没错的,那么移植过程哪里出错了呢?
