【在线等!】ARM 硬件重定向printf问题
2337|3
arm_debug_yj|  楼主 | 2013-6-16 11:10 | 显示全部楼层 回帖奖励 |倒序浏览 |阅读模式
【问题描述】ARM硬件重定向后,单个用底层IO函数SendChar(ch)连续输出字符都可以,用printf("abcdefgh\n"),只打印出了ab,请问高人是什么问题啊,在线等,跪求解决方法!!
【代码】
#include "../../common/drivers.h"
#pragma import(__use_no_semihosting_swi)
  external functions
struct __FILE
      int32 handle;                 // Add whatever you need here
FILE __stdout;
FILE __stdin;
  SendChar
  Write character to Serial Port.
int SendChar (int ch)  {
  //while (UARTGetLineStatus(g_pUART0, UART_标志寄存器_THR_EMPTY) == RESET);
  UARTSendData(g_pUART0, (uint8)(ch & 0xFF));
  return (ch);
  GetKey
  Read character to Serial Port.
int32 GetKey (void)  {
  while (UARTGetLineStatus(g_pUART0, UART_标志寄存器_DATA_READY) == RESET);
  return ((int)UARTRecvData(g_pUART0));
  fputc
int fputc(int ch, FILE *f) {
  return (SendChar(ch));
  fgetc
int fgetc(FILE *f) {
  return (SendChar(GetKey()));
  _ttywrch
void _ttywrch(int ch) {
SendChar (ch);
  ferror
int32 ferror(FILE *f) {
                              // Your implementation of ferror
  return EOF;
  _sys_exit
void _sys_exit(int return_code) {
label:  goto label;           // endless loop
arm_debug_yj|  楼主 | 2013-6-18 12:31 | 显示全部楼层
jamsan 发表于 2013-6-17 09:00
为何把  //while (UARTGetLineStatus(g_pUART0, UART_标志寄存器_THR_EMPTY) == RESET);这一句注掉?在发送 ...
是这个问题
