求助!!
2161|0
lianyj0302|  楼主 | 2007-4-4 17:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
ST, ic, logic, ce, se
请帮帮我,这个程序有一个错误,请大侠帮我改改这个用MAX+plusII仿真谢谢!!library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity countrl is
    port(
        CLR: in std_logic;
        Fa: IN std_logic;
        Fb: in std_logic;
        Tp:in std_logic;
        Tt: buffer std_logic;
        phasen:out std_logic
end;
architecture behav of countrl is
signal phas: std_logic;
begin
    process(Tp,CLR,Fa)
    begin
        if CLR='1' then Tt<='0';
        elsif Fa'event and Fa='1' then
            Tt<=Tp;
        end if;
        end process;
    process(fa,fb,clr)
    begin
        if clr='1' then phas<='0';
        else phas<=    fa xor fb    ;
        end if;
        end process;
     phasen<=Tt and phas;
    end behav;
        end if;
        end process;
    process(fa,fb,clr)
    begin
        end if;
        end process;
    end behav;
