[国产单片机] STC单片机PCA中断测低电平时间乱跑的问题
2987|10
 楼主| xiao20041128 发表于 2013-7-18 10:54 | 显示全部楼层 |阅读模式
三个通道测低电平时间,方法是开PCA边沿中断,上下降沿时间互减,但测试中一个方波进来,上升沿中断22次,下降沿中断居然有600多次
到底什么问题,搞了几天都不行!!!!
还有设置PCA中断优先级会导致中断时死机,真是无语了!
只开了PCA中断,其他中断全关
PCA初始化程序如下:
//PCA中断  相关功能中文手册316页
CCON = 0;                       //Initial PCA control register
    CR = 0;
CF = 0;                                //PCA timer stop running
    CCF0 = 0;                                //Clear CF flag
    CCF1 = 0;                                //Clear all module interrupt flag
CCF2 = 0;
    CL = 0;                         //Reset PCA base timer
    CH = 0;
    CMOD = 0x01;                    //Set PCA timer clock source as Fosc/12
//    CMOD = 0x00;                                //Enable PCA timer overflow interrupt
    CCAPM0 = 0x31;                  //PCA module-0 capture by a negative tigger on CEX0(P3.7) and enable PCA interrupt
CCAPM1 = 0x31;                  //PCA1
CCAPM2 = 0x31;                  //PCA2  跳变边沿中断
EPCAI = 1;      //PCA MODEL INT EN
// IP  |= 0x00;    //中断优先级设置会引起死机!!!!!
// IPH |= 0x40;
// IP  = 0x40;
// IPH = 0x40;         //PCA中断最高优先级
// Delay( 10 );
CR = 1;                         //PCA timer start run
EA  = 1;      //总中断
PCA中断程序:
void PCA_isr() interrupt 6 using 1
        unsigned int buf;
        if( CF )
                CF = 0;
        //        CL = 0;
        //        CH = 0;
                if( Timing[0] )
                        PCACount[0]++;
                if( Timing[1] )
                        PCACount[1]++;
                if( Timing[2] )
                        PCACount[2]++;
    //测量方式,下降沿记录一次定时器值,溢出中断检查计数中的的Count加1
        if( CCF0 )                                                         //PCA0中断
                CCF0 = 0;
                buf = CCAP0H;
                buf <<= 8;
                buf += CCAP0L;
        //        CCAPM0 = 0x31;
                if( PCA0 )                                                 //上升沿
                //        TimeCount[0] = (65536*PCACount[0] + buf-BufTimer[0])/100;
                        TimeCount[0]++;
                        Timing[0]         = 0;
                        PCACount[0] = 0;
                        CCAPM0 = 0x11;
                else if( !PCA0 )                                                           //下降沿
                        TimeCount[1]++;                        Timing[0] = 1;
                        BufTimer[0] = buf;
                        CCAPM0 = 0x21; //开启上升沿中断
        if( CCF1 )
                CCF1 = 0;
                buf = CCAP1H;
                buf <<= 8;
                buf += CCAP1L;
        //        CCAPM1 = 0x31;
                if( PCA1 )                                                 //上升沿
                //        TimeCount[1] = (65536*PCACount[1] + buf-BufTimer[1])/100;
                        Timing[1]         = 0;
                        PCACount[1] = 0;
                        CCAPM1 = 0x11;
                else if( !PCA1 )                                                          //下降沿
                        TimeCount[1]++;
                        Timing[1] = 1;
                        BufTimer[1] = buf;
                        CCAPM1 = 0x21;
        if( CCF2 )
                CCF2 = 0;         //Clear interrupt flag
                buf = CCAP2H;
                buf <<= 8;
                buf += CCAP2L;
        //        CCAPM2 = 0x31;
                if( PCA2 )                                                 //上升沿
                        TimeCount[2] = (65536*PCACount[2] + buf-BufTimer[2])/100;
                        Timing[2]         = 0;
                        PCACount[2] = 0;
                        CCAPM2 = 0x11;
                else if( !PCA2 )                                                          //下降沿
                        Timing[2] = 1;
                        BufTimer[2] = buf;
                        CCAPM2 = 0x21;
测试中TimeCount[1]次数是TimeCount[0]的30多倍,按照正常方波进来不可能的。10Hz方波进来TimeCount[0]的值是对的!
 楼主| xiao20041128 发表于 2013-7-18 10:55 | 显示全部楼层
端口的头文件
sbit PCA0      =   P3^7;
sbit PCA1      =   P3^5;
sbit PCA2      =   P2^0;
ayb_ice 发表于 2013-7-18 11:37 | 显示全部楼层
你这中断处理时间过长,
但不一定是问题所在地
评分
参与人数 1威望 +1 收起 理由
xiao20041128 + 1 问题已经解决,就不鄙视国产了.
查看全部评分
强烈建议中断只记录数据,处理放在主循环中
ayb_ice 发表于 2013-7-18 11:39 | 显示全部楼层
这个算式可能溢出的风险
 楼主| xiao20041128 发表于 2013-7-19 08:49 | 显示全部楼层
测试的时候只加了CCF1的中断,其他两个没有加信号,所有时间应该不是问题!
 楼主| xiao20041128 发表于 2013-7-19 08:50 | 显示全部楼层
STC只是垃圾货,一堆BUG的芯片,技术支持还装B,说没时间
 楼主| xiao20041128 发表于 2013-7-19 08:56 | 显示全部楼层
如此国货如何才能做好?
gx_huang 发表于 2013-7-19 09:30 | 显示全部楼层
先检查自己的程序问题吧。
99.9%是你自己的问题。
 楼主| xiao20041128 发表于 2013-12-22 14:58 | 显示全部楼层
确实是单片机有问题,不过可以在中断中再加个软件处理,过滤掉不必要的中断
由于乱进中断,所以测试结果有一点误差,不大
McuPlayer 发表于 2013-12-22 16:11 | 显示全部楼层
你测试用的低电平宽度是多少?用示波器抓一下看看
