STM32 Time1的PWM输出问题。
5806|3
 楼主| 206022219002 发表于 2013-8-2 09:47 | 显示全部楼层 |阅读模式
我想用定时器1的PA.8输出占空比为50%,频率为500K的方波信号。结果我按下面的配置,500K的信号是出来了,但出几个方波接着就一个宽一点的低电平,不正常。这是怎么回事?是我的配置哪里有问题吗?
//¶¨Ê±Æ÷2ÅäÖÃ
void SetupTIMBASE(void)
  TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  //ÅäÖÃϵͳʱÖÓ10MS
  /* TIM2 clock enable */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);                 //ʹÄܶ¨Ê±Æ÷2Ä£¿éʱÖÓ(¶¨Ê±Æ÷2µÄʱÖÓÔÚAPB1µÄ36M×ÜÏßÉÏ)
  /* Time base configuration */
  TIM_TimeBaseStructure.TIM_Period = 20000;                             //Èç¹ûCCRx>=APR,ÔòFREquency=TIM2CLK/APR          1M/20000=50HZ
  TIM_TimeBaseStructure.TIM_Prescaler = 35;                             //TIM2CLK/£¨35+1£©=1MHz                                           1000 000 /20000
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;                              //²»·ÖƵ
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;    //¼ÆÊýģʽÏòÉÏ
  TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  /* TIM IT enable */
  TIM_ITConfig(TIM2, TIM_IT_Update, ENABLE);     //ʹÄÜÖжÏ
  /* TIM2 enable counter */
  TIM_Cmd(TIM2, ENABLE);                               //ʹÄÜTIM2Ä£¿é
//Çý¶¯²½½øµç»ú»òÕßËÅ·þµç»úµÄÂö³åÊä³öPWM³õʼ»¯
void Time1_pwm_setup(void)
  TIM_OCInitTypeDef  TIM_OCInitStructure;
  TIM_BDTRInitTypeDef  TIM_BDTRInitStructure;
  GPIO_InitTypeDef  GPIO_InitStructure;
  /* TIM1, GPIOA clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1 | RCC_APB2Periph_GPIOA, ENABLE);
  /* GPIOA Configuration: Channel 1 Output */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
//51200*3000/60=2.56MHz           ×î´óϸ·ÖµÄʱºò51200¸öÂö³åһȦ£¬ÉèÖÃ×î¸ß3000תÿ·ÖÖÓµÄ×î¸ß£Ð£×£ÍƵÂÊ
//10000*3000/60=500K       ×î´óϸ·ÖµÄʱºò10000¸öÂö³åһȦ£¬ÉèÖÃ×î¸ß3000תÿ·ÖÖÓµÄ×î¸ß£Ð£×£ÍƵÂÊ
//1/500K=2uS
//72MHzÏÂ144¸öÂö³åΪȡ·´Ò»´ÎΪ500K
  /* TIM1 Peripheral Configuration */
  TIM_DeInit(TIM1);
  /* Time Base configuration */
  TIM_TimeBaseStructure.TIM_Prescaler = 0x00;                         //Ô¤·ÖƵ72M£¯500K=144
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;         //ÏòÉϼÆÊý
  TIM_TimeBaseStructure.TIM_Period = 143;                             //Ô¤×°ÔØÖµ
  TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;      //²»·ÖƵ
  TIM_TimeBaseStructure.TIM_RepetitionCounter = 0x0;
  TIM_TimeBaseInit(TIM1,&TIM_TimeBaseStructure);          //¸ù¾ÝTIM_TIMBaseInitStruct ÖÐÖ¸¶¨µÄ²ÎÊý³õʼ»¯ TIM1 µÄʱ¼ä»ùÊýµ¥Î»
  /* Channel 1, 2,3 and 4 Configuration in PWM mode */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;                     //TIM1Âö³å¿í¶Èµ÷ÖÆÄ£Ê½ 2
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;   //ʹÄÜÊä³ö±È½Ï״̬
  TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable; //ʹÄÜÊä³ö±È½ÏN ״̬
  TIM_OCInitStructure.TIM_Pulse = 71;                                                           //ÉèÖÃÁË´ý×°Èë²¶»ñ±È½Ï¼Ä´æÆ÷µÄÂö³åÖµ¡£ËüµÄȡֵ±ØÐëÔÚ0x0000 ºÍ0xFFFFÖ®¼ä¡£
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;               //TIM1Êä³ö±È½Ï¼«ÐÔµÍ
  TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low;      //TIM1Êä³ö±È½Ï N ¼«ÐԵ͠
  TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;            //µ±MOE=0ÉèÖà TIM1Êä³ö±È½Ï¿ÕÏÐ״̬
  TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;   //µ±MOE=0ÖØÖà TIM1Êä³ö±È½Ï N ¿ÕÏÐ״̬
  TIM_OC1Init(TIM1,&TIM_OCInitStructure);             //¸ù¾ÝTIM_OCInitStructÖÐÖ¸¶¨µÄ²ÎÊý³õʼ»¯ TIM1ͨµÀ1
  /* Automatic Output enable, Break, dead time and lock configuration*/
  TIM_BDTRInitStructure.TIM_OSSRState = TIM_OSSRState_Enable;           //ʹÄÜTIM1 OSSR״̬
  TIM_BDTRInitStructure.TIM_OSSIState = TIM_OSSIState_Enable;           //ʹÄÜTIM1 OSSI ״̬
  TIM_BDTRInitStructure.TIM_LOCKLevel = TIM_LOCKLevel_1;                      //ʹÓÃËøµçƽ1
  TIM_BDTRInitStructure.TIM_DeadTime = 0x75;                                                   //Ö¸¶¨ÁËÊä³ö´ò¿ªºÍ¹Ø±Õ״̬֮¼äµÄÑÓʱ¡£
  TIM_BDTRInitStructure.TIM_Break = TIM_Break_Enable;                               //ʹÄÜTIM1ɲ³µÊäÈë
  TIM_BDTRInitStructure.TIM_BreakPolarity = TIM_BreakPolarity_High;       //TIM1ɲ³µÊäÈë¹Ü½Å¼«ÐÔ¸ß
  TIM_BDTRInitStructure.TIM_AutomaticOutput = TIM_AutomaticOutput_Enable; //×Ô¶¯Êä³ö¹¦ÄÜʹÄÜ
  TIM_BDTRConfig(TIM1,&TIM_BDTRInitStructure);           //ÉèÖÃɲ³µÌØÐÔ£¬ËÀÇøÊ±¼ä£¬Ëøµçƽ£¬OSSI£¬OSSR ״̬ºÍAOE£¨×Ô¶¯Êä³öʹÄÜ£©
  /* TIM1 counter enable */
  TIM_Cmd(TIM1,ENABLE);
  /* Main Output Enable */
  TIM_CtrlPWMOutputs(TIM1,ENABLE);
 楼主| 206022219002 发表于 2013-8-2 09:48 | 显示全部楼层
这是写的代码
outstanding 发表于 2013-8-2 12:50 | 显示全部楼层
  最好贴关键的部分。太长了,上班没有空看
伊泽瑞拉 发表于 2014-5-12 10:39 | 显示全部楼层
按自己程序一步步走一遍    就可以查出来问题在哪    可能是数据设置的问题
