- // MSP430F552x Demo - ADC12, Sample A0, Set P1.0 if A0 > 0.5*AVcc
- // Description: A single sample is made on A0 with reference to AVcc.
- // Software sets ADC12SC to start sample and conversion - ADC12SC
- // automatically cleared at EOC. ADC12 internal oscillator times sample (16x)
- // and conversion. In Mainloop MSP430 waits in LPM0 to save power until ADC12
- // conversion complete, ADC12_ISR will force exit from LPM0 in Mainloop on
- // reti. If A0 > 0.5*AVcc, P1.0 set, else reset.
- // MSP430F552x
- // --|RST |
- // Vin -->|P6.0/CB0/A0 P1.0|--> LED
- // Bhargavi Nisarga
- // Texas Instruments Inc.
- // April 2009
- // Built with CCSv4 and IAR Embedded Workbench Version: 4.21
- #include <msp430f5529.h>
- void main(void)
- WDTCTL = WDTPW + WDTHOLD; // Stop WDT
- ADC12CTL0 = ADC12SHT02 + ADC12ON; // Sampling time, ADC12 on
- ADC12CTL1 = ADC12SHP; // Use sampling timer
- ADC12IE = 0x01; // Enable interrupt
- ADC12CTL0 |= ADC12ENC;
- P6SEL |= 0x01; // P6.0 ADC option select
- P1DIR |= 0x01; // P1.0 output
- while (1)
- ADC12CTL0 |= ADC12SC; // Start sampling/conversion
- __bis_SR_register(LPM0_bits + GIE); // LPM0, ADC12_ISR will force exit
- __no_operation(); // For debugger
- #pragma vector = ADC12_VECTOR
- __interrupt void ADC12_ISR(void)
- switch(__even_in_range(ADC12IV,34))
- case 0: break; // Vector 0: No interrupt
- case 2: break; // Vector 2: ADC overflow
- case 4: break; // Vector 4: ADC timing overflow
- case 6: // Vector 6: ADC12IFG0
- if (ADC12MEM0 >= 0x7ff) // ADC12MEM = A0 > 0.5AVcc?
- P1OUT |= BIT0; // P1.0 = 1
- else
- P1OUT &= ~BIT0; // P1.0 = 0
- __bic_SR_register_on_exit(LPM0_bits); // Exit active CPU
- case 8: break; // Vector 8: ADC12IFG1
- case 10: break; // Vector 10: ADC12IFG2
- case 12: break; // Vector 12: ADC12IFG3
- case 14: break; // Vector 14: ADC12IFG4
- case 16: break; // Vector 16: ADC12IFG5
- case 18: break; // Vector 18: ADC12IFG6
- case 20: break; // Vector 20: ADC12IFG7
- case 22: break; // Vector 22: ADC12IFG8
- case 24: break; // Vector 24: ADC12IFG9
- case 26: break; // Vector 26: ADC12IFG10
- case 28: break; // Vector 28: ADC12IFG11
- case 30: break; // Vector 30: ADC12IFG12
- case 32: break; // Vector 32: ADC12IFG13
- case 34: break; // Vector 34: ADC12IFG14
- default: break;
自改程序部分:
主程序
- #include <stdint.h>
- #include "msp430.h"
- #include "HAL_PMM.h"
- #include "HAL_UCS.h"
- #include "HAL_Board.h"
- #include "HAL_Buttons.h"
- #include "HAL_Cma3000.h"
- #include "HAL_Dogs102x6.h"
- #include "HAL_Menu.h"
- #include "HAL_Wheel.h"
- #include "LPM.h"
- #include "PMM.h"
- #include "lab2.h"
- uint16_t timeoutCounter;
- void main(void)
- uint8_t contrast = *((unsigned char *)contrastSetpointAddress); //读取FLASH中对比度值
- uint8_t brightness = *((unsigned char *)brightnessSetpointAddress); //读取FLASH中背光值
- // Initialize accelerometer offset from flash
- Cma3000_setAccel_offset(*((unsigned char *)accelXcalibrationAddress), //初始化加速度偏移量
- *((unsigned char *)accelYcalibrationAddress),
- *((unsigned char *)accelZcalibrationAddress));
- // Stop WDT
- WDTCTL = WDTPW + WDTHOLD; //关闭看门狗
- // Basic GPIO initialization
- Board_init(); //初始化GPIO
- // Set Vcore to accomodate for max. allowed system speed
- SetVCore(3); //设VCore为最大
- // Use 32.768kHz XTAL as reference
- LFXT_Start(XT1DRIVE_0); //利用LFXT1(32.768kHZ)作为时钟参考
- // Set system clock to max (25MHz)
- Init_FLL_Settle(25000, 762); //利用FLL(锁频环)将系统时钟设为最大25MHZ
- SFRIFG1 = 0; //清中断标志
- SFRIE1 |= OFIE; //使能晶振失效中断
- // Globally enable interrupts
- __enable_interrupt(); //使能全局中断
- // Setup real time clock
- //SetupRTC(); //设置实时时钟
- // Set up LCD
- Dogs102x6_init(); //初始化LCD
- Dogs102x6_backlightInit(); //背光初始化
- // Contrast not programed in Flash Yet
- if (contrast == 0xFF) //若当前FLASH中无对比度值,则将对比度值设为11(默认)
- // Set Default Contrast
- contrast = 11;
- // Brightness not programed in Flash Yet
- if (brightness == 0xFF) //若当前FLASH中无背光值,则将背光值设为11(默认)
- // Set Default Brightness
- brightness = 11;
- Dogs102x6_setBacklight(brightness); //设置初始背光值
- Dogs102x6_setContrast(contrast); //设置初始对比度值
- Dogs102x6_clearScreen(); //清屏
- // Set up wheel
- Wheel_init(); //初始化齿轮电位计
- Buttons_init(BUTTON_ALL); //初始化按键
- Buttons_interruptEnable(BUTTON_ALL); //使能所有按键中断
- buttonsPressed = 0; //键值清零
- // Display TI **
- // Wait for button press
- // buttonsPressed = 0;
- //显示文字说明:
- Dogs102x6_stringDraw(3, 0, " Welcome to ", DOGS102x6_DRAW_NORMAL);
- Dogs102x6_stringDraw(4, 0, " MSP-EXP430F5529 ", DOGS102x6_DRAW_NORMAL);
- Dogs102x6_stringDraw(6, 0, "Wait for a moment", DOGS102x6_DRAW_INVERT);
- Dogs102x6_stringDraw(7, 0, "or press S1 | S2 ", DOGS102x6_DRAW_INVERT);
- while (!buttonsPressed) //等待按键被按下,或者超时退出等待
- for (timeoutCounter = 0; timeoutCounter < 0xFFFF; timeoutCounter++)
- if (buttonsPressed)
- break;
- __delay_cycles(2000);
- //Timeout break
- break;
- // 主循环
- while (1)
- lab2(); //试验二程序
lab2
- #include "Clock.h"
- #include "LPM.h"
- #include "Random.h"
- #include "PMM.h"
- #include "Demo_Cube.h"
- #include "CTS_Layer.h"
- #include "stdlib.h"
- #include "lab2.h"
- static const char *const capMenuText[] = {
- "==LAB2:Cap App===",
- "1. CapLED ",
- "2. CapDemo ",
- "3. Simon",
- char *itoa(int, char *, int);
- // Forward Declared Function
- void CapLED(void);
- void CapDemo(void);
- void simon(void);
- void lab2(void)
- uint8_t selection = 0;
- Dogs102x6_stringDraw(7, 0, "*S1=Enter S2=Esc*", DOGS102x6_DRAW_NORMAL);
- selection = Menu_active((char **)capMenuText, 1);
- if (buttonsPressed & BUTTON_S2);
- else
- switch (selection)
- case 1: CapLED(); break; //触摸滑块演示实验程序
- //触摸按键柱形图演示实验程序
- //Simon游戏实验程序
- default: break;
- void CapLED(void)
- Board_ledOff(LED_ALL); //关闭所有LED
- Dogs102x6_stringDraw(1, 0, " Slide Finger on ", DOGS102x6_DRAW_NORMAL);
- Dogs102x6_stringDraw(2, 0, " Touch Pads ", DOGS102x6_DRAW_NORMAL);
- while (!(buttonsPressed & BUTTON_S2)) //S2按键按下退出程序
- while (1)
- else
- default: break;
谢谢各位了先
