USB转串口一般都应用于哪一方面
1935|3
yqzz163|  楼主 | 2013-8-19 17:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
你好陌生人| | 2013-9-13 20:04 | 只看该作者
MAXIM的MAX3232
江宇平99999| | 2013-9-16 17:32 | 只看该作者
(1) easy to use. For many applications, all they need is a way to communicate between PC and the board with a reasonable throughput. And make it as a virtual COM port will make the job a lot easier
(2) FTDI has provided a full set of solution to do this. Its chip is very flexible, which can be configured for a wide variety of interfaces (CPU/UART/FIFO etc)
(3) FTDI has also provided a full set of driver and software along with the chip, make the adoption smooth
(4) for prototype, FTDI has a wide range of eval board and dev-board ready for use.
(5) Its cost is low compared to a full-blown USB controller, like those from Cypress
gxs64| | 2013-9-18 09:23 | 只看该作者
FTDI的东西贵
