#include "inc/hw_ints.h"
#include "inc/hw_memmap.h"
#include "inc/hw_types.h"
#include "gpio.h"
#include "sysctl.h"
#define PINS GPIO_PIN_0
void delay(int d)
for(;d;--d);
void SysCtlClockSet(unsigned long ulConfig)
void SysCtlPeripheralEnable (unsigned long ulPeripheral)
void GPIODirModeSet(unsigned long ulPort,unsigned char ucPins,unsigned long ulPinIO)
void GPIOPinWrite(unsigned long ulPort, unsigned char ucPins, unsigned char ucVal)
int main(void)
unsigned int i;
SysCtlClockSet(SYSCTL_SYSDIV_1|SYSCTL_USE_OSC|SYSCTL_OSC_MAIN|SYSCTL_XTAL_6MHZ);//直接使用外部晶振
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOD);//使能GPIO的PA模块
GPIODirModeSet(GPIO_PORTD_BASE,PINS,GPIO_DIR_MODE_OUT);//设置PD0输出
for(i=0;i<10;i++);
GPIOPinWrite(GPIO_PORTD_BASE,PINS,~PINS);//置PD0低电平
delay(20000);
GPIOPinWrite(GPIO_PORTD_BASE,PINS,PINS);//置PD0高电平
delay(20000);
SysCtlClockSet(SYSCTL_SYSDIV_1|SYSCTL_USE_PLL|SYSCTL_OSC_MAIN|SYSCTL_XTAL_6MHZ);//使用PLL
for(i=0;i<10;i++)
{GPIOPinWrite(GPIO_PORTD_BASE,PINS,PINS);
delay(20000);
delay(20000);
return 0;
用的CCSV5 编译时没问题 DEBUG时就出现CORTEX_M3_0: GEL Output:
Memory Map Initialization Complete
CORTEX_M3_0: GEL Output: Watchdog Timer Enabled
CORTEX_M3_0: GEL Output: UARTs Enabled
CORTEX_M3_0: Flash Programmer: Timed out while writing to Flash memory
CORTEX_M3_0: Trouble Writing Memory Block at 0x0 on Page 0 of Length 0x3b0
CORTEX_M3_0: GEL: File: F:\xuzhetao\CCS\LAB2\Debug\LAB2.out: Load failed. |
