STM32 USART1 波特率
1719|4
 楼主| m__dd 发表于 2013-10-28 17:53 | 显示全部楼层 |阅读模式
我用的STM32F101 主频36M AHB1 36M    设置波特率19200     BRR值为0X753:117+3/16 = 117.1875也正确,
可是输出不对,用示波器测量一位50us,也就是接近20K/s,整整大了10倍,怎么回事?求解!
 楼主| m__dd 发表于 2013-10-28 17:55 | 显示全部楼层
下面是时钟配置代码:红色部分标识
void RCC_Configuration(void)
  ErrorStatus HSEStartUpStatus;
  /* RCC system reset(for debug purpose) */
  RCC_DeInit();
  /* Enable HSE */
  RCC_HSEConfig(RCC_HSE_ON);//RCC_HSE_ON——HSE晶振打开(ON)
  /* Wait till HSE is ready */
  HSEStartUpStatus = RCC_WaitForHSEStartUp();//等待HSE起振
  if(HSEStartUpStatus == SUCCESS)
    /* HCLK = SYSCLK */
    RCC_HCLKConfig(RCC_SYSCLK_Div1); //RCC_SYSCLK_Div1——AHB时钟=系统时钟
    /* PCLK2 = HCLK */
    RCC_PCLK2Config(RCC_HCLK_Div1); //RCC_HCLK_Div1——APB2时钟=HCLK
    /* PCLK1 = HCLK/2 */
    RCC_PCLK1Config(RCC_HCLK_Div1);//RCC_HCLK_Div2——APB1时钟=HCLK/1
    /* Flash 2 wait state */
    FLASH_SetLatency(FLASH_Latency_2);//FLASH_Latency_2 2延时周期
    /* Enable Prefetch Buffer */
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);//预取指缓存使能
    /* PLLCLK = 4MHz * 9 = 36 MHz */
    RCC_PLLConfig(RCC_PLLSource_HSE_Div2, RCC_PLLMul_9);//设置时钟源及倍频系数,PLL的输入时钟=HSE时钟频率;RCC_PLLMul_9——PLL输入时钟x9
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);
    /* Wait till PLL is ready */
    while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
    /* Select PLL as system clock source */
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);//RCC_SYSCLKSource_PLLCLK——选择PLL作为系统时钟
    /* Wait till PLL is used as system clock source */
    while(RCC_GetSYSCLKSource()!= 0x08);//0x08:PLL作为系统时钟
 楼主| m__dd 发表于 2013-10-28 17:57 | 显示全部楼层
USART1配置:
void HW_USART1_Configuration()
    unsigned int temp = 0;
    USART_InitTypeDef USART_InitStructure;
    /* USART1 configuration */
    USART_InitStructure.USART_BaudRate = 19200;
    USART_InitStructure.USART_WordLength = USART_WordLength_8b;
    USART_InitStructure.USART_StopBits = USART_StopBits_1;
    USART_InitStructure.USART_Parity = USART_Parity_No;
    USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
    USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
    /* Configure USART1 */
    USART_Init(USART1, &USART_InitStructure);
    /* Enable USART1 Receive interrupts */
    USART_ClearITPendingBit(USART1,USART1_IRQn);
    USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
    /* Enable the USART1 */
    USART_Cmd(USART1, ENABLE);
管脚配置:
void HW_USART1_GPIO_Configuration(void)
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO|RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1, ENABLE);
    /* GPIOA/ USART1 */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;                    //USART1 TX
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;         //复用推挽输出
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;                    //USART1 RX
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;   //复用开漏输入
    //GPIO_PinRemapConfig(GPIO_Remap_USART1, ENABLE);
bobo5650 发表于 2013-10-28 17:58 | 显示全部楼层
19200跟20K,不是差不多吗?怎么是10倍了?
 楼主| m__dd 发表于 2013-10-28 21:16 | 显示全部楼层
好吧!我可以去死了
