28027驱动LCD12864的问题
1641|3
 楼主| teabottle 发表于 2013-10-31 00:12 | 显示全部楼层 |阅读模式
现在用F28027驱动12864,按照时序进行编程,实在找不到问题,但是就是不能显示,求大家帮帮忙看一下,谢谢了
#include<DSP28x_Project.h>
#define CS GpioDataRegs.GPADAT.bit.GPIO5
#define SID GpioDataRegs.GPADAT.bit.GPIO6
#define CLK GpioDataRegs.GPADAT.bit.GPIO7
void Gpio_Init(void)
                        EALLOW;
                        GpioCtrlRegs.GPAPUD.all=0xFF;
                        GpioCtrlRegs.GPAMUX1.all = 0x00000000;  // All GPIO
                        GpioCtrlRegs.GPAMUX2.all = 0x00000000;  // All GPIO
                        GpioCtrlRegs.GPBMUX1.all = 0x00000000;  // All GPIO
                        GpioCtrlRegs.GPADIR.all = 0xFFFFFFFF;   // All outputs
                        GpioCtrlRegs.GPBDIR.all = 0x0000000F;   // All outputs
                        EDIS;
void delay(int n)
                        while(n--);
void Sendbyte(unsigned char bytes) //发送一个字节
                 unsigned char i;
                 for(i=0;i<8;i++)
                                 CLK=1;
                                 SID=bytes&0x80; //取出最高位
                                 CLK=0;
                                 bytes<<=1; //左移
void write_com(unsigned char com)
                CS=1;
                Sendbyte(0xf8);
                Sendbyte(com&0xf0);
                Sendbyte((com&0x0f)<<4);
                CS=0;
                delay(0xff);
void write_data(unsigned char dat)
                CS=1;
                Sendbyte(0xfa);
                Sendbyte(dat&0xf0);
                Sendbyte((dat&0x0f)<<4);
                CS=0;
                delay(0xff);
void LCD_Init(void)
                  write_com(0x01);
                  write_com(0x30);
                  write_com(0x0c);
                  write_com(0x06);
                  write_com(0x02);
void main(void)
                        InitSysCtrl();                               //        In this function watchdog is disabled
                    DINT;                                                        //Disable interrupts,this has been done in the "InitPieCtrl();"function
                         InitPieCtrl();                                        //Initial PIE,in this function,interrupts are disabled,Clear all PIEIER registers,Clear all PIEIFR registers
                         IER = 0x0000;
                         IFR = 0x0000;
                         InitPieVectTable();                                //Initialize the PIEvectable,let the interrupts point to their own ISR
                         Gpio_Init();                                                //Gpio initial function
                        LCD_Init();
                        write_com(0x80);
                        write_data(0x02);
                        write_data(0x02);
                        write_data(0x02);
                        while(1);
huangfeng33 发表于 2013-10-31 20:44 | 显示全部楼层
12864有串行和并行两种模式,接口不同,程序也不一样
zhangmangui 发表于 2013-10-31 22:34 | 显示全部楼层
要不先用并行的控制试试   就是配置IO口和设置延时
先看看串行数据波形是否有输出  还有调节一下12864的背光
