[STM32] 求助STM32读写NAND只能成功1Page
3112|3
 楼主| chinavbs 发表于 2013-11-15 08:36 | 显示全部楼层 |阅读模式
第一页数据对的,第二页内容就不对了 NAND 型号是K9F1G08 已改成大页驱动
//头文件FSMC_NAND.H
#ifndef __FSMC_NAND_H
#define __FSMC_NAND_H
#define     __IO    volatile
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x_lib.h"
/* Exported types ------------------------------------------------------------*/
typedef unsigned short int  uint16_t;
typedef unsigned char       uint8_t;
typedef unsigned int        uint32_t;
typedef struct
uint8_t Maker_ID;
uint8_t Device_ID;
uint8_t Third_ID;
uint8_t Fourth_ID;
}NAND_IDTypeDef;
typedef struct
uint16_t Zone;
uint16_t Block;
uint16_t Page;
} NAND_ADDRESS;
/* Exported constants --------------------------------------------------------*/
/* NAND Area definitionfor STM3210E-EVAL Board RevD */
#define CMD_AREA (uint32_t)(1<<16)/* A16 = CLEhigh */
#define ADDR_AREA (uint32_t)(1<<17)/* A17 = ALE high */
#define DATA_AREA ((uint32_t)0x00000000)
/* FSMC NAND MEMORY command */
#define NAND_CMD_AREA_A ((uint8_t)0x00)
#define NAND_CMD_AREA_B ((uint8_t)0x01)
#define NAND_CMD_AREA_C ((uint8_t)0x50)
#define NAND_CMD_AREA_TRUE1 ((uint8_t)0x30)
#define NAND_CMD_WRITE0 ((uint8_t)0x80)
#define NAND_CMD_WRITE_TRUE1 ((uint8_t)0x10)
#define NAND_CMD_ERASE0 ((uint8_t)0x60)
#define NAND_CMD_ERASE1 ((uint8_t)0xD0)
#define NAND_CMD_READID ((uint8_t)0x90)
#define NAND_CMD_STATUS ((uint8_t)0x70)
#define NAND_CMD_LOCK_STATUS ((uint8_t)0x7A)
#define NAND_CMD_RESET ((uint8_t)0xFF)
/* NAND memory status */
#define NAND_VALID_ADDRESS ((uint32_t)0x00000100)
#define NAND_INVALID_ADDRESS ((uint32_t)0x00000200)
#define NAND_TIMEOUT_ERROR ((uint32_t)0x00000400)
#define NAND_BUSY ((uint32_t)0x00000000)
#define NAND_ERROR ((uint32_t)0x00000001)
#define NAND_READY ((uint32_t)0x00000040)
#define NAND_PAGE_SIZE ((uint16_t)0x0800) /* 2048 bytes per page w/o Spare Area */
#define NAND_BLOCK_SIZE ((uint16_t)0x0040) /* 64x2048 bytes pages per block */
#define NAND_ZONE_SIZE ((uint16_t)0x0400) /* 1024 Block per zone */
#define NAND_SPARE_AREA_SIZE ((uint16_t)0x0040) /* last 64 bytes as spare area */
#define NAND_MAX_ZONE ((uint16_t)0x0001) /* 1 zones of 1024 block */
/* FSMC NAND memory address computation */
#define ADDR_1st_CYCLE(ADDR) (uint8_t)((ADDR)& 0xFF) /* 1st addressing cycle */
#define ADDR_2nd_CYCLE(ADDR) (uint8_t)(((ADDR)& 0xFF00) >> 8) /* 2nd addressing cycle */
#define ADDR_3rd_CYCLE(ADDR) (uint8_t)(((ADDR)& 0xFF0000) >> 16) /* 3rd addressing cycle */
#define ADDR_4th_CYCLE(ADDR) (uint8_t)(((ADDR)& 0xFF000000) >> 24) /* 4th addressing cycle */
void FSMC_NAND_Init(void);
void FSMC_NAND_ReadID(NAND_IDTypeDef* NAND_ID);
uint32_t FSMC_NAND_WriteSmallPage(uint8_t  *pBuffer, NAND_ADDRESS Address, uint32_t  NumPageToWrite);
uint32_t FSMC_NAND_ReadSmallPage (uint8_t *pBuffer, NAND_ADDRESS Address, uint32_t NumPageToRead);
u32 FSMC_NAND_WriteSpareArea(u8 *pBuffer, NAND_ADDRESS Address, u32 NumSpareAreaTowrite);
u32 FSMC_NAND_ReadSpareArea(u8 *pBuffer, NAND_ADDRESS Address, u32 NumSpareAreaToRead);
uint32_t FSMC_NAND_EraseBlock(NAND_ADDRESS Address);
u32 FSMC_NAND_Reset(void);
uint32_t FSMC_NAND_GetStatus(void);
uint32_t FSMC_NAND_ReadStatus(void);
uint32_t FSMC_NAND_AddressIncrement(NAND_ADDRESS* Address);
#endif /* __FSMC_NAND_H */
/******************* (C) COPYRIGHT 2008 STMicroelectronics *****END OF FILE****/
 楼主| chinavbs 发表于 2013-11-15 08:37 | 显示全部楼层
//fsmc_nand.c
#include "fsmc_nand.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
#define FSMC_Bank_NAND     FSMC_Bank2_NAND
#define Bank_NAND_ADDR     Bank2_NAND_ADDR
#define Bank2_NAND_ADDR    ((uint32_t)0x70000000)
/* Private macro -------------------------------------------------------------*/
#define ROW_ADDRESS (Address.Page + (Address.Block + (Address.Zone * NAND_ZONE_SIZE)) * NAND_BLOCK_SIZE)
#include "stm32f10x_it.h"
/*volatile unsigned long time_delay;
void delay_us(volatile unsigned long nus)
        if(Systick_Config(SystemFrequency/1000000))
                while(1);
        time_delay=nus;
        while(time_delay);
        SysTick->CTRL=0x00;
        SysTick->VAL=0x00;
/* Private variables ---------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
* Function Name  : FSMC_NAND_Init
* Description    : Configures the FSMC and GPIOs to interface with the NAND memory.
*                  This function must be called before any write/read operation
*                  on the NAND.
* Input          : None
* Output         : None
* Return         : None
  FSMC_NANDInitTypeDef FSMC_NANDInitStructure;
  FSMC_NAND_PCCARDTimingInitTypeDef  p;
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE |
                         RCC_APB2Periph_GPIOF | RCC_APB2Periph_GPIOG, ENABLE);
/*-- GPIO Configuration ------------------------------------------------------*/
/* CLE, ALE, D0->D3, NOE, NWE and NCE2  NAND pin configuration  */
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_14 | GPIO_Pin_15 |
                                 GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_4 | GPIO_Pin_5 |
                                 GPIO_Pin_7;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
/* D4->D7 NAND pin configuration  */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10;
  GPIO_Init(GPIOE, &GPIO_InitStructure);
/* NWAIT NAND pin configuration */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
/* INT2 NAND pin configuration */
  GPIO_Init(GPIOG, &GPIO_InitStructure);
  /*-- FSMC Configuration ------------------------------------------------------*/
  p.FSMC_SetupTime = 0x1;
  p.FSMC_WaitSetupTime = 0x3;
  p.FSMC_HoldSetupTime = 0x2;
  p.FSMC_HiZSetupTime = 0x1;
  FSMC_NANDInitStructure.FSMC_Bank = FSMC_Bank2_NAND;
  FSMC_NANDInitStructure.FSMC_Waitfeature = FSMC_Waitfeature_Enable;
  FSMC_NANDInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_8b;
  FSMC_NANDInitStructure.FSMC_ECC = FSMC_ECC_Enable;
  FSMC_NANDInitStructure.FSMC_ECCPageSize = FSMC_ECCPageSize_2048Bytes;
  FSMC_NANDInitStructure.FSMC_AddressLowMapping = FSMC_AddressLowMapping_Direct;
  FSMC_NANDInitStructure.FSMC_TCLRSetupTime = 0x00;
  FSMC_NANDInitStructure.FSMC_TARSetupTime = 0x00;
  FSMC_NANDInitStructure.FSMC_CommonSpaceTimingStruct = &p;
  FSMC_NANDInitStructure.FSMC_AttributeSpaceTimingStruct = &p;
  FSMC_NANDInit(&FSMC_NANDInitStructure);
  /* FSMC NAND Bank Cmd Test */
  FSMC_NANDCmd(FSMC_Bank2_NAND, ENABLE);
* Function Name  : FSMC_NAND_ReadID
* Description    : Reads NAND memory's ID.
* Input          : - NAND_ID: pointer to a NAND_IDTypeDef structure which will hold
*                    the Manufacturer and Device ID.
* Output         : None
* Return         : None
   uint32_t data = 0;
  /*!< Send Command to the command area */
  *(__IO uint8_t *)(Bank_NAND_ADDR | CMD_AREA) = 0x90;
  *(__IO uint8_t *)(Bank_NAND_ADDR | ADDR_AREA) = 0x00;
   /*!< Sequence to read ID from NAND flash */
   data = *(__IO uint32_t *)(Bank_NAND_ADDR | DATA_AREA);
   NAND_ID->Maker_ID   = ADDR_1st_CYCLE (data);//四个周期读取四个ID
   NAND_ID->Device_ID  = ADDR_2nd_CYCLE (data);
   NAND_ID->Third_ID   = ADDR_3rd_CYCLE (data);
   NAND_ID->Fourth_ID  = ADDR_4th_CYCLE (data);
* Function Name  : FSMC_NAND_WriteSmallPage
* Description    : This routine is for writing one or several 512 Bytes Page size.
* Input          : - pBuffer: pointer on the Buffer containing data to be written
*                  - Address: First page address
*                  - NumPageToWrite: Number of page to write
* Output         : None
* Return         : New status of the NAND operation. This parameter can be:
*                   - NAND_TIMEOUT_ERROR: when the previous operation generate
*                     a Timeout error
*                   - NAND_READY: when memory is ready for the next operation
*                  And the new status of the increment address operation. It can be:
*                  - NAND_VALID_ADDRESS: When the new address is valid address
*                  - NAND_INVALID_ADDRESS: When the new address is invalid address
  uint32_t index = 0x00, numpagewritten = 0x00, addressstatus = NAND_VALID_ADDRESS;
  uint32_t status = NAND_READY, size = 0x00;
  while((NumPageToWrite != 0x00) && (addressstatus == NAND_VALID_ADDRESS) && (status == NAND_READY))
    /* Page write command and address */
    *(__IO uint8_t *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_AREA_A;
    *(__IO uint8_t *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_WRITE0;
    *(__IO uint8_t *)(Bank_NAND_ADDR | ADDR_AREA) = ADDR_1st_CYCLE(ROW_ADDRESS); //
    *(__IO uint8_t *)(Bank_NAND_ADDR | ADDR_AREA) = ADDR_2nd_CYCLE(ROW_ADDRESS); //
    *(__IO uint8_t *)(Bank_NAND_ADDR | ADDR_AREA) = ADDR_3rd_CYCLE(ROW_ADDRESS); //更改
    *(__IO uint8_t *)(Bank_NAND_ADDR | ADDR_AREA) = ADDR_4th_CYCLE(ROW_ADDRESS); //
    /* Calculate the size */
    size = NAND_PAGE_SIZE + (NAND_PAGE_SIZE * numpagewritten);
    /* Write data */
    for(; index < size; index++)
      *(__IO uint8_t *)(Bank_NAND_ADDR | DATA_AREA) = pBuffer[index];
    *(__IO uint8_t *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_WRITE_TRUE1;
    /* Check status for successful operation */
    status = FSMC_NAND_GetStatus();
    if(status == NAND_READY)
      numpagewritten++;
      NumPageToWrite--;
      /* Calculate Next small page Address */
      addressstatus = FSMC_NAND_AddressIncrement(&Address);
  return (status | addressstatus);
* Function Name  : FSMC_NAND_ReadSmallPage
* Description    : This routine is for sequential read from one or several
*                  512 Bytes Page size.
* Input          : - pBuffer: pointer on the Buffer to fill
*                  - NumPageToRead: Number of page to read
* Output         : None
*                     a Timeout error
void delay_us(u16 time)
        u16 i=0;
        while(time--)
                i=10;
                while(i--);
uint32_t FSMC_NAND_ReadSmallPage(uint8_t *pBuffer, NAND_ADDRESS Address, uint32_t  NumPageToRead)
  uint32_t index = 0x00, numpageread = 0x00, addressstatus = NAND_VALID_ADDRESS;
  while((NumPageToRead != 0x0) && (addressstatus == NAND_VALID_ADDRESS))
    /* Page Read command and page address */
    *(__IO uint8_t *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_AREA_A; //地址
    *(__IO uint8_t *)(Bank_NAND_ADDR | ADDR_AREA) = 0x00;  //命令
    *(__IO uint8_t *)(Bank_NAND_ADDR | ADDR_AREA) = ADDR_2nd_CYCLE(ROW_ADDRESS); //访问地址
    *(__IO uint8_t *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_AREA_TRUE1;  //命令
        delay_us(15);
    size = NAND_PAGE_SIZE + (NAND_PAGE_SIZE * numpageread);
    /* Get Data into Buffer */
    for(index=0x00; index < size; index++)
      pBuffer[index]= *(__IO uint8_t *)(Bank_NAND_ADDR | DATA_AREA);
    numpageread++;
    NumPageToRead--;
    /* Calculate page address */
* Function Name  : FSMC_NAND_WriteSpareArea
* Description    : This routine write the spare area information for the specified
*                  pages addresses.
*                  - NumSpareAreaTowrite: Number of Spare Area to write
* Output         : None
*                     a Timeout error
  u32 index = 0x00, numsparesreawritten = 0x00, addressstatus = NAND_VALID_ADDRESS;
  u32 status = NAND_READY, size = 0x00;
  while((NumSpareAreaTowrite != 0x00) && (addressstatus == NAND_VALID_ADDRESS) && (status == NAND_READY))
    /* Page write Spare area command and address */
    *(vu8 *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_AREA_C;
    *(vu8 *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_WRITE0;
    *(vu8 *)(Bank_NAND_ADDR | ADDR_AREA) = 0x00;
    *(vu8 *)(Bank_NAND_ADDR | ADDR_AREA) = ADDR_1st_CYCLE(ROW_ADDRESS);
    *(vu8 *)(Bank_NAND_ADDR | ADDR_AREA) = ADDR_2nd_CYCLE(ROW_ADDRESS);
    *(vu8 *)(Bank_NAND_ADDR | ADDR_AREA) = ADDR_3rd_CYCLE(ROW_ADDRESS);
    size = NAND_SPARE_AREA_SIZE + (NAND_SPARE_AREA_SIZE * numsparesreawritten);
    /* Write the data */
      *(vu8 *)(Bank_NAND_ADDR | DATA_AREA) = pBuffer[index];
    *(vu8 *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_WRITE_TRUE1;
      numsparesreawritten++;
      NumSpareAreaTowrite--;
      /* Calculate Next page Address */
* Function Name  : FSMC_NAND_ReadSpareArea
* Description    : This routine read the spare area information from the specified
*                  pages addresses.
*                  - NumSpareAreaToRead: Number of Spare Area to read
* Output         : None
*                     a Timeout error
  u32 numsparearearead = 0x00, index = 0x00, addressstatus = NAND_VALID_ADDRESS;
  while((NumSpareAreaToRead != 0x0) && (addressstatus == NAND_VALID_ADDRESS))
    *(vu8 *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_AREA_TRUE1;
    /* Data Read */
    size = NAND_SPARE_AREA_SIZE +  (NAND_SPARE_AREA_SIZE * numsparearearead);
    for ( ;index < size; index++)
      pBuffer[index] = *(vu8 *)(Bank_NAND_ADDR | DATA_AREA);
    numsparearearead++;
    NumSpareAreaToRead--;
* Function Name  : FSMC_NAND_EraseBlock
* Description    : This routine erase complete block from NAND FLASH
* Input          : - Address: Any address into block to be erased
* Output         : None
*                     a Timeout error
  *(__IO uint8_t *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_ERASE0;
  *(__IO uint8_t *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_ERASE1;
  return (FSMC_NAND_GetStatus());
* Function Name  : FSMC_NAND_Reset
* Description    : This routine reset the NAND FLASH
* Input          : None
* Output         : None
* Return         : NAND_READY
  *(vu8 *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_RESET;
  return (NAND_READY);
* Function Name  : FSMC_NAND_GetStatus
* Description    : Get the NAND operation status
* Input          : None
* Output         : None
*                     a Timeout error
  __IO uint32_t timeout = 0x1000000, status = NAND_READY;
  status = FSMC_NAND_ReadStatus();
  /* Wait for a NAND operation to complete or a TIMEOUT to occur */
  while ((status != NAND_READY) &&( timeout != 0x00))
     timeout --;
  if(timeout == 0x00)
    status =  NAND_TIMEOUT_ERROR;
  /* Return the operation status */
  return (status);
* Function Name  : FSMC_NAND_ReadStatus
* Description    : Reads the NAND memory status using the Read status command
* Input          : None
* Output         : None
* Return         : The status of the NAND memory. This parameter can be:
*                   - NAND_BUSY: when memory is busy
*                   - NAND_ERROR: when the previous operation gererates error
  uint32_t data = 0x00, status = NAND_BUSY;
  /* Read status operation ------------------------------------ */
  *(__IO uint8_t *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_STATUS;
  data = *(__IO uint8_t *)(Bank_NAND_ADDR);
  if((data & NAND_ERROR) == NAND_ERROR)
    status = NAND_ERROR;
  else if((data & NAND_READY) == NAND_READY)
  else
    status = NAND_BUSY;
  return (status);
* Function Name  : NAND_AddressIncrement
* Description    : Increment the NAND memory address
* Input          : - Address: address to be incremented.
* Output         : None
* Return         : The new status of the increment address operation. It can be:
  uint32_t status = NAND_VALID_ADDRESS;
  Address->Page++;
  if(Address->Page == NAND_BLOCK_SIZE)
    Address->Page = 0;
    Address->Block++;
    if(Address->Block == NAND_ZONE_SIZE)
      Address->Block = 0;
      Address->Zone++;
      if(Address->Zone == NAND_MAX_ZONE)
        status = NAND_INVALID_ADDRESS;
  return (status);
 楼主| chinavbs 发表于 2013-11-15 08:39 | 显示全部楼层
* File Name          : main.c
* Author             : POWER AVR
* Date First Issued  : 08/08/2008
* Description        : Main program body
#include <stdio.h>
#define BUFFER_SIZE  0x800
uint8_t  lastblock=10,Flag=0x0,BUF[2][BUFFER_SIZE];//声明全局变量,此处不能够赋值
u16 PageNumber=0,RXId=0x0,WId=0x0,USART_RX_STA=0x0;//声明全局变量,此处不能够赋值
NAND_IDTypeDef NAND_ID;
NAND_ADDRESS WriteReadAddr;
ErrorStatus HSEStartUpStatus;
__IO uint32_t    status= 0,status1=0;
void RCC_Configuration(void);
void NVIC_Configuration(void);
void GPIO_Configuration(void);
void USART_Configuration(void);
* Function Name  : main
* Description    : Main program.
* Input          : None
* Output         : None
* Return         : None
int main(void)
        uint16_t i=0,h=0;
#ifdef DEBUG
  debug();
#endif
  /* Configure the system clocks */
  RCC_Configuration();
  /* NVIC Configuration */
  NVIC_Configuration();
  /* Configure the GPIOs */
  GPIO_Configuration();
  /* Configure the USART1 */
  USART_Configuration();
   /* PF.06, PF.07 and PF.08  config to drive LD1, LD2 and LD3 *****************/
  /* Enable GPIOF clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOF, ENABLE);
  /* Configure PF.06, PF.07 and PF.08 as Output push-pull */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7 | GPIO_Pin_8;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init(GPIOF, &GPIO_InitStructure);
  GPIO_SetBits(GPIOF,GPIO_Pin_6 | GPIO_Pin_7 | GPIO_Pin_8);
  /* Enable the FSMC Clock */
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_FSMC, ENABLE);
  FSMC_NAND_Init();
  /* NAND read ID command */
  FSMC_NAND_ReadID(&NAND_ID);
  printf("\r\n Start \r\n");
  while(1)
    if (Flag==1)
        {        Flag=0;
            GPIO_ResetBits(GPIOF, GPIO_Pin_7);
        h=PageNumber/64;
                i=PageNumber-(PageNumber*h);
            WriteReadAddr.Zone = 0x00;
            WriteReadAddr.Block = h;
                WriteReadAddr.Page = i;
                if(lastblock!=h)
                        lastblock=h;
                        //GPIO_ResetBits(GPIOF, GPIO_Pin_6);
                        status = FSMC_NAND_EraseBlock(WriteReadAddr);
                        //printf("Erase %d: %d \r\n",status);
                        //GPIO_SetBits(GPIOF, GPIO_Pin_6);
            WriteReadAddr.Page = 0;
                status1 = FSMC_NAND_WriteSmallPage(BUF[0], WriteReadAddr, 1);
            WriteReadAddr.Page = 1;
                status1 = FSMC_NAND_WriteSmallPage(BUF[1], WriteReadAddr, 1);
                //printf("%d,%d\r\n",status,status1);
                PageNumber++;
                if(PageNumber==2048)
                printf("\r\n Ok \r\n");
                GPIO_SetBits(GPIOF, GPIO_Pin_7);
#ifdef  DEBUG
* Function Name  : assert_failed
* Description    : Reports the name of the source file and the source line number
*                  where the assert error has occurred.
* Input          : - file: pointer to the source file name
*                  - line: assert error line source number
* Output         : None
* Return         : None
void assert_failed(u8* file, u32 line)
  /* User can add his own implementation to report the file name and line number */
  printf("\n\r Wrong parameter value detected on\r\n");
  printf("       file  %s\r\n", file);
  printf("       line  %d\r\n", line);
  /* Infinite loop */
  /* while (1)
#endif
* Function Name  : RCC_Configuration
* Description    : Configures the different system clocks.
* Input          : None
* Output         : None
* Return         : None
  /* RCC system reset(for debug purpose) */
  RCC_DeInit();
  /* Enable HSE */
  RCC_HSEConfig(RCC_HSE_ON);
  /* Wait till HSE is ready */
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if(HSEStartUpStatus == SUCCESS)
    /* HCLK = SYSCLK */
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    /* PCLK2 = HCLK */
    RCC_PCLK2Config(RCC_HCLK_Div1);
    /* PCLK1 = HCLK/2 */
    RCC_PCLK1Config(RCC_HCLK_Div2);
    /* Flash 2 wait state */
    FLASH_SetLatency(FLASH_Latency_2);
    /* Enable Prefetch Buffer */
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    /* PLLCLK = 8MHz * 9 = 72 MHz */
    RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);
    /* Wait till PLL is ready */
    while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
    /* Select PLL as system clock source */
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    /* Wait till PLL is used as system clock source */
    while(RCC_GetSYSCLKSource() != 0x08)
  /* Enable USART1 and GPIOA clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_GPIOA, ENABLE);
* Function Name  : NVIC_Configuration
* Description    : Configures Vector Table base location.
* Input          : None
* Output         : None
* Return         : None
  NVIC_InitTypeDef NVIC_InitStructure;
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);//选择分组方式0
  NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQChannel;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
* Function Name  : GPIO_Configuration
* Description    : Configures the different GPIO ports.
* Input          : None
* Output         : None
* Return         : None
  /* Configure USART1 Tx (PA.09) as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  /* Configure USART1 Rx (PA.10) as input floating */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
* Function Name  : USART_Configuration
* Description    : Configures the USART1.
* Input          : None
* Output         : None
* Return         : None
  USART_InitTypeDef USART_InitStructure;
  USART_ClockInitTypeDef  USART_ClockInitStructure;
/* USART1 configuration -----------------------------------------------
  /* USART1 configured as follow:
        - BaudRate = 115200 baud
        - Word Length = 8 Bits
        - One Stop Bit
        - No parity
        - Hardware flow control disabled (RTS and CTS signals)
        - Receive and transmit enabled
        - USART Clock disabled
        - USART CPOL: Clock is active low
        - USART CPHA: Data is captured on the middle
        - USART LastBit: The clock pulse of the last data bit is not
output to
                         the SCLK pin
USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
/* Configure the USART1 synchronous paramters */
USART_ClockInit(USART1, &USART_ClockInitStructure);
USART_InitStructure.USART_BaudRate = 9600;
USART_InitStructure.USART_WordLength = USART_WordLength_8b;
USART_InitStructure.USART_StopBits = USART_StopBits_1;
USART_InitStructure.USART_Parity = USART_Parity_No ;
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
/* Configure USART1 basic and asynchronous paramters */
USART_Init(USART1, &USART_InitStructure);
  /* Enable USART1 */
USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
USART_Cmd(USART1, ENABLE);
* Function Name  : fputc
* Description    : Retargets the C library printf function to the USART.
* Input          : None
* Output         : None
* Return         : None
int fputc(int ch, FILE *f)
  /* Place your implementation of fputc here */
  /* e.g. write a character to the USART */
  USART_SendData(USART1, (u8) ch);
  /* Loop until the end of transmission */
  while(USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET)
  return ch;
/******************* (C) COPYRIGHT 2007 STMicroelectronics *****END OF FILE****/
mfktuu 发表于 2013-11-20 15:28 | 显示全部楼层
我的哥哥,建议看数据手册,比你发真些代码强多了
