| 首先,我的硬件没问题,我是在配置saa7113 ,急求解
 下面是我的程序
 library IEEE;
 use IEEE.STD_LOGIC_1164.ALL;
 use IEEE.STD_LOGIC_UNSIGNED.ALL;
 use IEEE.STD_LOGIC_ARITH.ALL;
 entity saa is
 port(
 clk_50m:in std_logic;
 rst:in std_logic;
 i2c_clk: inout std_logic;
 i2c_data:inout std_logic;
 saa7113_vpo:in std_logic_vector(7 downto 0);
 saa7113_v:in std_logic;
 saa7113_h:in std_logic;
 -- ack:out std_logic;
 saa7113_llc:in std_logic
 end saa;
 architecture Behavioral of saa is
 signal clk_div:integer range 0 to 249;
 signal clk_400k: std_logic:='0';
 type state is (i2c_wait,i2c_start,i2c_stop,i2c_write,i2c_idle);
 signal i2c_state:state:=i2c_wait;
 type write_state is (data,ack);
 signal inner_state:write_state:=data;
 signal cnt_bit:integer range 0 to 7;--字节计数
 signal shift:std_logic_vector(7 downto 0);
 signal cnt_data_w:integer range 0 to 33;
 signal cnt_idle:std_logic_vector(15 downto 0);
 signal cnt_delay:std_logic_vector(19 downto 0):=(others=>'0');
 SIGNAL phase0                   :  std_logic;
 SIGNAL phase1                   :  std_logic;
 SIGNAL phase2                   :  std_logic;
 SIGNAL phase3                   :  std_logic;
 signal shift_addr:std_logic;--shift table
 signal sda_buf:std_logic;
 signal scl_buf:std_logic;
 signal temp:std_logic;
 signal sda_valid:std_logic;
 type table_b is array(0 to 33) of std_logic_vector(7 downto 0);
 type table_a is array(0 to 25) of std_logic_vector(7 downto 0);
 signal table1:table_a:=((x"4a"),(x"01"),(x"08"),(x"c0"),(x"33"),(x"00"),(x"00"),(x"e0"),(x"0d"),(x"b8"),(x"01"),(x"80"),
 (x"47"),(x"40"),(x"00"),(x"01"),(x"2a"),(x"38"),(x"0c"),(x"e8"),(x"00"),(x"00"),
 (x"00"),(x"00"),(x"00"),(x"00"));
 signal table2:table_b:=((x"4a"),(x"40"),(x"02"),(x"ff"),(x"ff"),(x"ff"),(x"ff"),(x"ff"),(x"ff"),(x"ff"),(x"ff"),(x"ff"),
 (x"ff"),(x"ff"),(x"ff"),(x"ff"),(x"ff"),(x"ff"),(x"ff"),(x"ff"),(x"ff"),(x"ff"),
 (x"ff"),(x"ff"),(x"ff"),(x"ff"),(x"00"),(x"00"),(x"07"),(x"80"),(x"00"),(x"00"),
 (x"00"),(x"00"));
 begin
 --ack<=sdl_buf;
 temp<=sda_buf when (sda_valid)='1' else 'Z';
 i2c_data<=temp;
 i2c_clk<=scl_buf;
 PROCESS(clk_50m,rst)
 BEGIN
 IF (NOT rst = '1') THEN
 clk_div <= 0;
 phase0 <= '0';
 phase1 <= '0';
 phase2 <= '0';
 phase3 <= '0';
 ELSIF rising_edge(clk_50m)THEN
 IF (clk_div /= 249) THEN -- 125
 clk_div <= clk_div + 1;
 ELSE
 clk_div <= 0;
 END IF;
 case  clk_div is
 when 62    => phase1 <= '1';
 when 125    => phase2 <= '1';
 when 187   => phase3 <= '1';
 when 249   => phase0 <= '1';
 when others=>
 phase0 <= '0';
 phase1 <= '0';
 phase2 <= '0';
 phase3 <= '0';
 end case;
 END IF;
 END PROCESS;
 process(clk_50m,rst)
 begin
 if rst='0' then
 cnt_delay<=(others=>'0');
 elsif rising_edge(clk_50m) then
 if cnt_delay=800000  then
 if i2c_state=i2c_wait then
 end if;
 else
 cnt_delay<=cnt_delay+1;
 end if;
 end if;
 end process;
 process(rst,clk_50m)
 begin
 if rst='0' then
 sda_valid<='0';
 scl_buf<='1';
 sda_buf<='1';
 cnt_bit<=7;
 cnt_data_w<=0;
 cnt_idle<=(others=>'0');
 shift<=(others=>'0');
 shift_addr<='0';
 i2c_state<=i2c_wait;
 inner_state<=data;
 if i2c_state=i2c_idle then
 scl_buf<='1';
 else
 if phase0='1' then
 scl_buf<='1';
 else
 if phase2='1' then
 scl_buf<='0';
 end if;
 end if;
 end if;
 case i2c_state is
 when i2c_wait =>
 sda_valid<='0';
 i2c_state<=i2c_start;
 sda_valid<='1';
 sda_buf<='1';
 else
 end if;
 when i2c_start =>
 sda_valid<='1';
 if phase1='1' and sda_valid='1'then
 sda_buf<='0';
 shift<=x"4a";--4A slave address w  --4B slave address r
 end if;
 if phase3='1'and sda_buf='0' then
 i2c_state<=i2c_write;
 sda_buf<=shift(7);
 end if;
 cnt_data_w<=0;
 cnt_bit<=7;
 inner_state<=data;
 when i2c_write =>
 case inner_state is
 when data =>
 sda_valid<='1';
 if phase3='1' then
 if cnt_bit=0 then
 inner_state<=ack;
 cnt_data_w<=cnt_data_w+1;
 sda_valid <= '0';
 cnt_bit<=7;
 else
 sda_buf<=shift(cnt_bit-1);
 cnt_bit<=cnt_bit-1;
 inner_state<=data;
 end if;
 end if;
 when ack  =>
 sda_valid <= '0';
 if phase0='1' then
 sda_buf<=i2c_data;
 end if;
 if phase1='1'  then
 if sda_buf='1' then
 --i2c_state<=i2c_start;
 if shift_addr='0' then
 shift<=table1(cnt_data_w+1);
 else
 shift<=table2(cnt_data_w+1);
 end if;
 end if;
 end if;
 if phase3='1' then
 sda_valid<='1';
 cnt_bit<=7;
 if cnt_data_w=24 then -------
 cnt_data_w<=0;
 i2c_state<=i2c_stop;
 sda_buf <= '0';
 inner_state<=data;
 else
 inner_state<=data;
 sda_buf<=shift(7);
 end if;
 else
 if cnt_data_w=33 then -------
 cnt_data_w<=0;
 sda_buf <= '0';
 inner_state<=data;
 else
 inner_state<=data;
 sda_buf<=shift(7);
 end if;
 end if;
 end if;
 end case;
 when i2c_stop=>
 sda_valid<='1';
 IF (phase0 = '1') THEN
 sda_buf <= '0';
 END IF;
 IF (phase1 = '1') THEN
 sda_buf <= '1';
 END IF;
 IF (phase3 = '1') THEN
 if shift_addr='1'then
 i2c_state<=i2c_idle;
 shift_addr<='0';
 else
 shift_addr<='1';
 end if;
 END IF;
 when  i2c_idle=>
 sda_valid<='0';
 cnt_bit<=7;
 if cnt_idle=553 then
 else
 cnt_idle<=cnt_idle+1;
 end if;
 cnt_data_w<=0;
 end case;
 end if;
 end process;
 end Behavioral;
