[应用方案] 基于M0516的SPI驱动的10X7段共阳数码管的TM1668驱动程序
7380|13
 楼主| 缥缈九哥 发表于 2013-12-9 12:19 | 显示全部楼层 |阅读模式
测试了一个用M0516的SPI驱动TM1668驱动的10个7段数码管驱动,需要做行列段的转换驱动表,请同行们指正。
源码:/******************************************************************************
* @file     tM1668.c
* @brief    The Driver code for 10 7-Segment-Digital LED
* @version  1.0.0
* @date     06, december 2013
* @note
* Copyright (C) 2000-2013 PM9GZY by yuanxihua@21cn.com. All rights reserved.
/* Includes ------------------------------------------------------------------*/
#include <stdio.h>
#include <string.h>
#include "M051Series.h"
#include "rfid.h"
//make by yuanxihua@21cn.com
____________________________________________
|        M0517LBN                                          TM1668                |
|        P14        SPISS0                ---->                STB                        |
|        P15        MOSI0                 ---->                DIO                        |
|        P16        MISO0                 <----                DIO                        |
|        P17        SCLK0                ---->                CLK                        |
|___________________________________________|
//const unsigned char  TM1668_7X8_CODE[]={0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07, 0x7F, 0x6F, 0x77, 0X7F, 0x39, 0x3F, 0x79, 0x71};/* 0 1 2 3 4 5 6 7 8 9 A B C D E F */
const unsigned short int TM1668_10X7_CODE[]={0xffed,0x2f9f,0x2ffb,0x7b6d,0xfd45,0xff71,0xcf7c};
void SPI0_Init(void);
void SPI0_Write_Byte(uint8_t data);
void TM1668_Init(void){SPI0_Init();}
void TM1668_Read_Key(uint8_t *key);
void TM1668_Write_ADDR_INC(uint8_t *data);
void TM1668_DISPLAY(uint8_t *led);
void TM1668_Number(uint32_t data1,uint32_t data2);
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Set P1.4, P1.5, P1.6, P1.7 for SPI0 */
    SYS->P1_MFP = SYS_MFP_P14_SPISS0 | SYS_MFP_P15_MOSI_0 | SYS_MFP_P16_MISO_0 | SYS_MFP_P17_SPICLK0;
    /* Configure SPI0 as a master, clock idle high, rising clock edge Tx, rising edge Rx and 8-bit LSB transaction */
    SPI0->CNTRL = SPI_CNTRL_MASTER_MODE | SPI_CNTRL_CLK_IDLE_HIGH | SPI_CNTRL_TX_RISING |
                                  SPI_CNTRL_RX_RISING   | SPI_CNTRL_LSB_FIRST     | SPI_CNTRL_TX_BIT_LEN(8);
        /* SPI_SSR setting to force SPI master SS signal to high by software */
        SPI0->SSR = SPI_SSR_SW_SS_PIN_HIGH;
        /* Disable the automatic slave select function of the user-specified SPI port */
        _SPI_DISABLE_HW_AUTO_SLAVE_SELECT(SPI0);
    /* Set IP clock divider. SPI clock rate = HCLK / ((1+1)*2) = 12MHz */
    SPI0->DIVIDER = (SPI0->DIVIDER & (~SPI_DIVIDER_DIVIDER_Msk)) | SPI_DIVIDER_DIV(1);
        /* Clear Tx register of SPI1 to avoid send non-zero data to Master. Just for safe. */
    _SPI_WRITE_TX_BUFFER0(SPI1, 0);
        /* Lock protected registers */
    SYS_LockReg();
        //片选脚设为低电平状态
        SPI0->SSR = SPI_SSR_SW_SS_PIN_LOW;
        //发送数据
        _SPI_WRITE_TX_BUFFER0(SPI0, data);_SPI_SET_GO(SPI0);
        //等待发送数据完毕
        while(_SPI_GET_BUSY_STATUS(SPI0)){;}
        //片选脚设为高电平状态
        //片选脚设为低电平状态
        //Command1: 数据读写设置命令
        //发送数据
        _SPI_WRITE_TX_BUFFER0(SPI0, 0x42);_SPI_SET_GO(SPI0); //读键扫数据
        //等待发送数据完毕
        //配置MOSI为高阻输入的AIN口
        SYS->P1_MFP = SYS_MFP_P15_AIN5;
    for(uint8_t i=0;i<5;i++)
                SYS->P1_MFP = SYS_MFP_P15_MOSI_0;
                //发送数据
                _SPI_WRITE_TX_BUFFER0(SPI0, 0xff);_SPI_SET_GO(SPI0);
                //等待发送数据完毕
                //读取数据
                 key=_SPI_GET_RX0_DATA(SPI0);
        //配置P15为MOSI口
        //片选脚设为高电平状态
        //Command1: 显示模式设置命令
        SPI0_Write_Byte(0x03);//显示模式:7位10段
        //Command2: 数据读写设置命令
        SPI0_Write_Byte(0x40);//写数据到显示寄存器
    //片选脚设为低电平状态
        //Command3: 显示地址设置命令
        _SPI_WRITE_TX_BUFFER0(SPI0, 0xC0);_SPI_SET_GO(SPI0);//显示地址=0X00
    //等待传送退出
        for(uint32_t i=0;i<14;i++)//Data1~n: 显示数据,以Command3指定的地址为起始地址(最多14 bytes)
                //发送数据
                //等待发送数据完毕
        //片选脚设为高电平状态
        //Command4: 显示控制命令
        SPI0_Write_Byte(0x88);//显示开,亮度脉冲宽度为1/16:0x88,设置脉冲宽度为14/16:0x8F
        uint16_t TM1668[7],*code=(uint16_t*)TM1668_10X7_CODE;
        memset(TM1668,0,sizeof(TM1668));
//        for(uint8_t i=0;i<10;i++){DBG_PRINTF("led[%d]=%d\n\r",i,led);}
        for(uint8_t i=0;i<10;i++){for(uint8_t j=0;j<7;j++){TM1668[j]|=((led>0xf)?0:(code[j]>>led)&1)<<i;}}
        TM1668_Write_ADDR_INC((uint8_t *)(&TM1668[0]));
        uint8_t led[10],*p=&led[3],*q=&led[9];
        if((data1>9999)||(data2>999999)) return;
        memset(led,' ',sizeof(led));led[3]=led[9]=0;
        for(uint32_t i=data1;i!=0;i/=10){*p--=i%10;}
        for(uint32_t i=data2;i!=0;i/=10){*q--=i%10;}
        TM1668_DISPLAY(led);
void TM1668_Test(void)
        uint8_t i=0;
        TM1668_Init();
/*    while(1)
                //SPI0_Write_Byte(0x55);
                if(++i>9)i=0;
                uint32_t data0=i*10+i,data1=data0*100+data0,data2=data1*100+data0;
                DBG_PRINTF("*** 9G-M0517LBN V1.00 %04d %06d...\n\r",data1,data2);
                TM1668_Number(data1,data2);
                for(uint16_t i=0;i<500;i++){SYS_SysTickDelay(1000);}
        i=i;
        uint32_t j=0,k=0;
    while(1)
                if(j++>9999){j=0;} if(k++>999999)k=0;
                DBG_PRINTF("*** 9G-M0517LBN V1.00 %04d %06d...\n\r",j,k);
                TM1668_Number(j,k);
//                for(uint16_t i=0;i<100;i++){SYS_SysTickDelay(1000);}
}//缥缈九哥测试通过
niuyaliang 发表于 2013-12-13 22:16 | 显示全部楼层
虽然没用过,还是给九哥顶起
ZG11211 发表于 2013-12-14 13:39 | 显示全部楼层
顶九哥,前阵子无聊我也仿制了一个电子看板,用了4片TM1638,是8X8的驱动
zxf0168 发表于 2013-12-15 16:56 | 显示全部楼层
你的电子看板很给力啊:lol
ZG11211 发表于 2013-12-15 22:11 | 显示全部楼层
:lol                    ..             :lol
 楼主| 缥缈九哥 发表于 2013-12-16 15:39 | 显示全部楼层
zxf0168 发表于 2013-12-16 23:21 | 显示全部楼层
九哥,你的表情是故意插入的么
 楼主| 缥缈九哥 发表于 2013-12-20 02:46 | 显示全部楼层
不是故意的。发代码不会发,得请教一下如何禁止表情了。
niuyaliang 发表于 2014-4-14 14:49 | 显示全部楼层
给九哥顶起
szjosun 发表于 2014-4-28 08:28 | 显示全部楼层
顶起!
lzyyoumuren 发表于 2014-12-27 16:55 | 显示全部楼层
 楼主| 缥缈九哥 发表于 2016-4-19 22:01 | 显示全部楼层
734774645 发表于 2016-4-20 23:10 | 显示全部楼层
工作不养闲人,团队不养懒人。赚不到钱赚知识,赚不到知识赚经历,赚不到经历赚阅历,让人迷茫的原因只有一个,那就是本该拼搏的年纪,却想得太多,做的太少
个人签名:童时不懂世事艰,笑谈学成锦衣还。岁月无声已先过,男儿有泪空自弹。    莫待沾霜愁上发,须嬴吐气喜开颜。拼搏半年誓如愿,不到长城心不甘。
67
