[STM32F4] 不知道为什么串口中断进不去?
4403|13
 楼主| wenny0000 发表于 2013-12-21 10:22 | 显示全部楼层 |阅读模式
/*********COM 中断*********/
void COM3Init(u32 BaudRate)
          USART_InitTypeDef USART_InitStructure;
          RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);
          RCC_APB2PeriphClockCmd(RCC_APB1Periph_USART3, ENABLE);
          GPIO_PinAFConfig(GPIOB, GPIO_PinSource10, GPIO_AF_USART3);
          GPIO_PinAFConfig(GPIOB, GPIO_PinSource11, GPIO_AF_USART3);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10 | GPIO_Pin_11;
          GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;                   // 25M/50/100
          GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
          GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
          GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
          GPIO_Init(GPIOB, &GPIO_InitStructure);
          USART_InitStructure.USART_BaudRate =BaudRate;// BaudRate;   //波特率设置
          USART_InitStructure.USART_WordLength = USART_WordLength_8b;
          USART_InitStructure.USART_StopBits = USART_StopBits_1;
          USART_InitStructure.USART_Parity = USART_Parity_No;
          USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
          USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
          USART_Init(USART3, &USART_InitStructure);
          USART_Cmd(USART3, ENABLE);
          USART_ClearFlag(USART3, USART_FLAG_TC);
void NVIC_Config(void)
   NVIC_InitTypeDef NVIC_InitStructure;
   NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);                                  //嵌套优先级分组为1
   NVIC_InitStructure.NVIC_IRQChannel=USART3_IRQn;                            //嵌套通道为UART5_IRQn
   NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=0;      //抢占优先级为0
   NVIC_InitStructure.NVIC_IRQChannelSubPriority=0;                                //响应优先级为0
   NVIC_InitStructure.NVIC_IRQChannelCmd=ENABLE;                                   //通道中断使能
   NVIC_Init(&NVIC_InitStructure);
void USART3_IRQHandler(void)
        if(USART_GetITStatus(USART3,USART_IT_RXNE)!=RESET)//判断为接收中断
          { USART_SendData(USART1,USART_ReceiveData(USART3));//发送收到的数据
                想做个循环缓冲存储
         USART_ClearITPendingBit(USART3, USART_IT_RXNE);
int main(void)
        CQCom1.WrPos = CQCom1.RdPos;
        CQCom3.WrPos = CQCom3.RdPos;
        CQCom5.WrPos = CQCom5.RdPos;
        LED_Init();                                /*LED*************/
        COM1Init(115200*2);                /****COM1 for keyboad***************/
        COM3Init(115200*2);                /****COM2 for debug***************/
        NVIC_Config();
        printf("\n\r Usart1\n\r");                  // COM1 report
while(1)
                LEDOn(LED2);
                delay_ms(200);
                   delay_ms(200);
   } //end while
} //end main
 楼主| wenny0000 发表于 2013-12-21 10:27 | 显示全部楼层
串口COM1能够收到板子发出的“Usart1字符。但是COM3进不去中断,这是一个问题,没有搞明白。仔细研学了下相关例程,查看了启动文件,中断向量中有中断服务函数,是否STM系列的中断服务函数挂接就是这样就OK?其二串口的中断函数-接收也好-发送也好,进入中断后,是否就可以直接清除中断标志,有没有一个硬件自动清除的,比如当进入中断收读过接收FIFO并读完就自动清除中断标志呢?”
 楼主| wenny0000 发表于 2013-12-21 10:57 | 显示全部楼层
困扰了很久,不知道有什么技巧,刚刚入手自己研学中,希望大侠给点指导。。。
 楼主| wenny0000 发表于 2013-12-21 11:08 | 显示全部楼层
突然想到了个奇怪的问题,是否由于时钟问题。
板子采用了个20M的时钟,相关时钟处理如下:
/* #define VECT_TAB_SRAM */
#define VECT_TAB_OFFSET  0x00 /*!< Vector Table base offset field.
                                   This value must be a multiple of 0x200. */
/*---use extr source =20000000 */
/* PLL_VCO = (HSE_VALUE or HSI_VALUE / PLL_M) * PLL_N */
#define PLL_M      5
#define PLL_N      84
/* PLL_VCO =336M */
/* SYSCLK = PLL_VCO / PLL_P */
#define PLL_P      2
/* USB OTG FS, SDIO and RNG Clock =  PLL_VCO / PLLQ */
#define PLL_Q      7
在主函数中:
COM1Init(115200*2);
问题在于:最先使用COMM1Init(115200);初始化后,上位机按115200设置串口,COM1输出“Usart1”字符是不能正确接收的,当如此×2后,上位机在机设置成115200反而能正确接收。
那么是否意味着COM1的串口时钟设置有问题?
但是我在并没有判断接收数据的值,只要有数据有进中断就行。时钟问题最多是接收的数据解析出错而已。郁闷
 楼主| wenny0000 发表于 2013-12-21 11:14 | 显示全部楼层
在STM32F4XX_usart.c中关于串口BRR计算如下:
/*---------------------------- USART BRR Configuration -----------------------*/
  /* Configure the USART Baud Rate */
  RCC_GetClocksFreq(&RCC_ClocksStatus);
  if ((USARTx == USART1) || (USARTx == USART6))
    apbclock = RCC_ClocksStatus.PCLK2_Frequency;
  else
    apbclock = RCC_ClocksStatus.PCLK1_Frequency;
  /* Determine the integer part */
  if ((USARTx->CR1 & USART_CR1_OVER8) != 0)
    /* Integer part computing in case Oversampling mode is 8 Samples */
    integerdivider = ((25 * apbclock) / (2 * (USART_InitStruct->USART_BaudRate)));
  else /* if ((USARTx->CR1 & USART_CR1_OVER8) == 0) */
    /* Integer part computing in case Oversampling mode is 16 Samples */
    integerdivider = ((25 * apbclock) / (4 * (USART_InitStruct->USART_BaudRate)));
  tmpreg = (integerdivider / 100) << 4;
  /* Determine the fractional part */
  fractionaldivider = integerdivider - (100 * (tmpreg >> 4));
  /* Implement the fractional part in the register */
    tmpreg |= ((((fractionaldivider * 8) + 50) / 100)) & ((uint8_t)0x07);
    tmpreg |= ((((fractionaldivider * 16) + 50) / 100)) & ((uint8_t)0x0F);
  /* Write to USART BRR register */
  USARTx->BRR = (uint16_t)tmpreg;
其中:   integerdivider = ((25 * apbclock) / (4 * (USART_InitStruct->USART_BaudRate)));    中的25是否有特殊含义呢?没有看的太明白?
gaochy1126 发表于 2013-12-21 11:50 | 显示全部楼层
这个不需重映射吧。
你去掉AF这几条语句试试。
SLHSu37 发表于 2013-12-21 13:50 | 显示全部楼层
这是你复制到帖子里的时候复制错的还是你程序里就是这样写的?
用APB2的命令去开APB1设备的时钟,能好用?
我没搞过F4,不知道F4里串口接收中断在哪里开
接收标志位在中断里清,F1里是这么做的
评分
参与人数 1威望 +1 收起 理由
wenny0000 + 1 赞一个!
查看全部评分
 楼主| wenny0000 发表于 2013-12-21 15:47 | 显示全部楼层
找到问题了,谢谢大家:
问题结果如下:
在第二句,始能串口前,应该开放接收中断!!!
USART_ITConfig(USART1,USART_IT_RXNE,ENABLE);
哈哈
另外:
发送中断只有能在发送函数中进行设置。
 楼主| wenny0000 发表于 2013-12-21 15:55 | 显示全部楼层
这是你复制到帖子里的时候复制错的还是你程序里 ...
你说的是一个问题,AHB、APB时钟配置问题。感谢中,没有仔细看书,COPY例程没有搞明白,刚才根据你的指引看了看,你讲的是对的,谢谢哦。
虽然不是串口最终不能进去的原因,也很感谢
SLHSu37 发表于 2013-12-21 17:01 | 显示全部楼层
你说的是一个问题,AHB、APB时钟配置问题。感谢中,没有仔细看书,COPY例程没有搞明白,刚才根据你的指引 ...
没搞过F4,所以不知道串口中断在哪里开,之前也说过·
你的问题我遇到过,配置时钟出错,没开串口接收中断,仔细一点就好了
ABHK 发表于 2013-12-21 20:25 | 显示全部楼层
这个   应该还是时钟的问题   应该还是时钟分频  那里出了问题
 楼主| wenny0000 发表于 2013-12-22 09:42 | 显示全部楼层
关于串口中断的问题已经解决,如9楼所述。
新的问题是在是时钟问题,按 SLHSu37 的指导,修正了串口的时钟配置项:摘抄如下:
          USART_InitTypeDef USART_InitStructure;                                        //what's mean?
          RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3, ENABLE);
        USART_InitStructure.USART_BaudRate =BaudRate;// BaudRate;//波特率设置
        USART_ITConfig(USART3,USART_IT_RXNE,ENABLE);
结果:main中必须书写成:
        COM1Init(115200*2);
        COM3Init(115200/6);
相关串口才能正确的按照115200波特率与上位机串口进行通讯。
问题:我使用了20M外部时钟,并且
#define PLL_M      5
#define PLL_N      84
/* PLL_VCO =336M */
#define PLL_P      2
#define PLL_Q      7
串口的时钟出现问题在哪里呢?????????????????虽然能用但是没用搞明白,怪怪的。
 楼主| wenny0000 发表于 2013-12-24 10:06 | 显示全部楼层
查清楚了一半,COM1Init(115200*2);所有的串口如果要设置成115200,现在就是这样写。看起来是我的哪个地方的时钟搞小了。不纠结了。
