1.44寸TFT彩屏显示图片、字符串程序、51C语言,任何单片机可
7095|8
 楼主| fmzhangpei241 发表于 2014-2-12 21:00 | 显示全部楼层 |阅读模式
1.44寸TFT彩屏显示图片、字符串程序、51C语言,任何单片机可以驱动
/* 测试单片机 STC12LE5A60S2 晶振 33MHZ */
/* http:tftmcutaobao.com               */
#include<reg51.h>
#include<absacc.h>
#include<intrins.h>
#include<string.h>
#define uchar unsigned char
#define uint unsigned int
sbit cs        =P0^0;         //片选
sbit rs        =P0^2;         //数据/命令切换
sbit sda       =P1^5;         //数据
sbit scl       =P1^7;         //时钟
sbit reset     =P0^1;         //复位
sbit ConAdd    =P3^1;
sbit ConSub    =P3^0;
sbit PAUSE     =P3^3;
sbit Type      =P3^5; //0-成品检测,1-半成品检测
sbit Mtp       =P3^2;  //MTP Burn
uchar code map1[];
uchar code map2[];
uchar bdata bitdata;
sbit bit7=bitdata^7;
sbit bit6=bitdata^6;
sbit bit5=bitdata^5;
sbit bit4=bitdata^4;
sbit bit3=bitdata^3;
sbit bit2=bitdata^2;
sbit bit1=bitdata^1;
sbit bit0=bitdata^0;
void  OTP_Program();
void  delay(uint t);
void  Contrast_Adjust();
uchar code Zk_ASCII8X16[];
void Display_Desc();
void Output_Pixel(uint x,uint y);
void Display_ASCII8X16(uint x0,uint y0,uchar *s);
void Test_FinshGoods();
void Test_HalfFinshGoods();
void EEPROM_ERASE();
void EEPROM_Writing();
void delay(uint time)
uint i,j;
  for(i=0;i<time;i++)
   for(j=0;j<250;j++);
void Pause() interrupt 2
    delay(100);
    while(!PAUSE);
    delay(100);
    while(PAUSE);
    delay(100);
    while(!PAUSE);
    delay(100);
void LCD_CtrlWrite_IC(uchar c)
bitdata=c;
cs=0;
rs=0;
sda=bit7;scl=0;scl=1;
sda=bit6;scl=0;scl=1;
sda=bit5;scl=0;scl=1;
sda=bit4;scl=0;scl=1;
sda=bit3;scl=0;scl=1;
sda=bit2;scl=0;scl=1;
sda=bit1;scl=0;scl=1;
sda=bit0;scl=0;scl=1;
cs=1;
void  LCD_DataWrite_IC(uchar d)
bitdata=d;
cs=0;
rs=1;
cs=1;
void LCD_DataWrite(uchar LCD_DataH,uchar LCD_DataL)
LCD_DataWrite_IC(LCD_DataH);
LCD_DataWrite_IC(LCD_DataL);
void  write_command(uchar c)
bitdata=c;
cs=0;
rs=0;
cs=1;
void  write_data(uchar d)
bitdata=d;
cs=0;
rs=1;
cs=1;
void Reset()
    reset=0;
    delay(100);
    reset=1;
    delay(100);
void lcd_initial()
   reset=0;
   delay(100);
   reset=1;
   delay(100);
//-------------------Software Reset-------------------------------//
    write_command(0x11); //Exit Sleep
        delay(20);
        write_command(0x26); //Set Default Gamma
        write_data(0x04);
        write_command(0xB1);//Set Frame Rate
        write_data(0x0e);
        write_data(0x10);
        write_command(0xC0); //Set VRH1[4:0] & VC[2:0] for VCI1 & GVDD
        write_data(0x08);
        write_data(0x00);
        write_command(0xC1); //Set BT[2:0] for AVDD & VCL & VGH & VGL
        write_data(0x05);
        write_command(0xC5); //Set VMH[6:0] & VML[6:0] for VOMH & VCOML
        write_data(0x38);
        write_data(0x40);
        write_command(0x3a); //Set Color Format
        write_data(0x05);
        write_command(0x36); //RGB
        write_data(0xc8);
        write_command(0x2A); //Set Column Address
        write_data(0x00);
        write_data(0x00);
        write_data(0x00);
        write_data(0x7F);
        write_command(0x2B); //Set Page Address
        write_data(0x00);
        write_data(0x00);
        write_data(0x00);
        write_data(0x7F);
        write_command(0xB4);
        write_data(0x00);
        write_command(0xf2); //Enable Gamma bit
        write_data(0x01);
        write_command(0xE0);
        write_data(0x3f);//p1
        write_data(0x22);//p2
        write_data(0x20);//p3
        write_data(0x30);//p4
        write_data(0x29);//p5
        write_data(0x0c);//p6
        write_data(0x4e);//p7
        write_data(0xb7);//p8
        write_data(0x3c);//p9
        write_data(0x19);//p10
        write_data(0x22);//p11
        write_data(0x1e);//p12
        write_data(0x02);//p13
        write_data(0x01);//p14
        write_data(0x00);//p15
        write_command(0xE1);
        write_data(0x1b);//p2
        write_data(0x1f);//p3
        write_data(0x0f);//p4
        write_data(0x16);//p5
        write_data(0x13);//p6
        write_data(0x31);//p7
        write_data(0x84);//p8
        write_data(0x43);//p9
        write_data(0x06);//p10
        write_data(0x1d);//p11
        write_data(0x21);//p12
        write_data(0x3d);//p13
        write_data(0x3e);//p14
        write_data(0x3f);//p15
        write_command(0x29); // Display On
        write_command(0x2C);
void  RamAdressSet()
   write_data(0x00);
   write_data(0x00);
   write_data(0x00);
   write_data(0x7f);
   write_data(0x00);
   write_data(0x00);
   write_data(0x00);
   write_data(0x9f);
void PutPixel(uint x_start,uint y_start,uint color)
        LCD_CtrlWrite_IC(0x2a);
        LCD_DataWrite_IC(x_start);
        LCD_DataWrite_IC(0x5f);
        LCD_CtrlWrite_IC(0x2b);
        LCD_DataWrite_IC(y_start+0x34);
        LCD_DataWrite_IC(0x7F);
        LCD_CtrlWrite_IC(0x2c);
        LCD_DataWrite_IC(color>>8);
        LCD_DataWrite_IC(color&0xff);
void RedLine()
        uchar i=0,j=0;
        i=66;   // 11格灰阶
        for(j=0;j<16;j++)
                PutPixel(i,j,0xf800);
void dsp_single_colour(DH,DL)
uchar i,j;
//RamAdressSet();
for (i=0;i<128;i++)
    for (j=0;j<128;j++)
        LCD_DataWrite(DH,DL);
void Display_Desc()
    Display_ASCII8X16(1,10,"tftmcu.taobao.com");
    Display_ASCII8X16(1,22,"Pro: Zhang Pei");
    Display_ASCII8X16(1,34,"Dots:128*128");
    Display_ASCII8X16(1,46,"IC:  ILI9163C");
    Display_ASCII8X16(1,58,"VA:  33 o'clock");
    Display_ASCII8X16(1,70,"2013.11.05");
    LCD_CtrlWrite_IC(0x2A);  //Column Address Set        ****
        LCD_DataWrite_IC(x);//xsh
        LCD_DataWrite_IC(x);//xsl
        LCD_CtrlWrite_IC(0x2B);//Row Address Set             ****
        LCD_DataWrite_IC(y);//ysl
        LCD_DataWrite(0xf8,0x00);
    RamAdressSet();
        int i,j,k,x,y,xx;
        unsigned char qm;
        long int ulOffset;
        char  ywbuf[32],temp[2];
        for(i = 0; i<strlen((char*)s);i++)
                if(((unsigned char)(*(s+i))) >= 161)
                        temp[0] = *(s+i);
                        temp[1] = '\0';
                        return;
                else
                        qm = *(s+i);
                        ulOffset = (long int)(qm) * 16;
            for (j = 0; j < 16; j ++)
                                ywbuf[j]=Zk_ASCII8X16[ulOffset+j];
            for(y = 0;y < 16;y++)
                          for(x=0;x<8;x++)
                        k=x % 8;
                                          if(ywbuf[y]&(0x80 >> k))
                                                  xx=x0+x+i*8;
                                            Output_Pixel(xx,y+y0);
main()
        lcd_initial();
    //dsp_single_colour(0xff,0xff); //清屏
        dsp_single_colour(0x00,0x1f);//蓝色背景
    Display_Desc();               //版本
    delay(500);
    while(1);
uchar code Zk_ASCII8X16[]=
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x18,0x08,0xc8,0x08,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x7f,0x60,0x60,0x60,0x60,0x60,0x60,0x60,0x60,0xe0,
  0x60,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x18,0x18,0x10,
  0x10,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x08,0x08,0x08,0x0c,0x0c,0x0c,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x6c,0x38,0x10,0x00,0x7c,0xc6,0x70,0x1c,
  0xc6,0x7c,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x38,0x6c,0x00,0x78,
  0x0c,0x7c,0xcc,0xcc,0x76,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x7c,0xc6,0x70,0xc0,0xc6,0x7c,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x6c,0x96,0x7c,0xd0,0xd6,0x6c,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7c,0xc6,0x06,0x06,0xc6,
  0x7c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x38,0x6c,0xc6,0xc6,0xfe,
  0xc6,0xc6,0x6c,0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x10,0x38,0x28,0x6c,0x44,0xc6,0xc6,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x7c,0xc6,0x06,0xfe,0xc6,0x7c,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xdc,0x66,0x66,0x66,0xf6,0x06,
  0x06,0x66,0x3c,0x00,0x00,0x00,0x00,0x6c,0x38,0xf8,0x0c,0x7e,0xc6,
  0xc6,0xc6,0x7c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0e,0x1b,0x18,
  0x18,0x18,0x18,0x18,0x18,0x18,0xd8,0x70,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0xfe,0x86,0x0c,0x18,0x0c,0x06,0x06,0xc6,0x7c,0x00,0x00,
  0x00,0x00,0x76,0xdc,0x00,0x00,0x78,0x0c,0x7c,0xcc,0xcc,0x76,0x00,
  0x00,0x00,0x00,0x00,0x00,0x76,0xdc,0x00,0x00,0x7c,0xc6,0x06,0x06,
  0xc6,0x7c,0x00,0x00,0x00,0x00,0x00,0x00,0x76,0xdc,0x00,0x00,0xdc,
  0x66,0x66,0x66,0x66,0x66,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x76,0x99,0x9f,0x98,0x99,0x6f,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0c,0x06,0x06,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3c,
  0x66,0x66,0x3c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x3c,
  0x3c,0x3c,0x18,0x18,0x00,0x18,0x18,0x00,0x00,0x00,0x00,0x00,0x00,
  0xc6,0xc6,0xc6,0x44,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x6c,0x6c,0xfe,0x6c,0x6c,0x6c,0xfe,0x6c,0x6c,
  0x00,0x00,0x00,0x00,0x00,0x18,0x18,0x7c,0xc6,0xc2,0xc0,0x7c,0x06,
  0x86,0xc6,0x7c,0x18,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc3,
  0xc6,0x0c,0x18,0x30,0x63,0xc3,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x38,0x6c,0x6c,0x38,0x76,0xdc,0xcc,0xcc,0x76,0x00,0x00,0x00,0x00,
  0x00,0x00,0x30,0x30,0x30,0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x30,0x60,0x60,0x60,0x60,0x60,
  0x30,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x0c,0x06,0x06,
  0x06,0x06,0x06,0x0c,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x6c,0x38,0xfe,0x38,0x6c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x18,0x18,0x18,0x7e,0x18,0x18,0x18,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x18,
  0x18,0x30,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xfe,
  0x00,0x00,0x00,0x00,0x00,0x18,0x18,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x02,0x06,0x0c,0x18,0x30,0x60,0xc0,0x80,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x7c,0xc6,0xce,0xde,0xf6,0xe6,0xc6,0xc6,0x7c,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x38,0x78,0x18,0x18,0x18,
  0x18,0x18,0x7e,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7c,0xc6,0x06,
  0x0c,0x18,0x30,0x60,0xc6,0xfe,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x7c,0xc6,0x06,0x06,0x3c,0x06,0x06,0xc6,0x7c,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x0c,0x1c,0x3c,0x6c,0xcc,0xfe,0x0c,0x0c,0x1e,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0xfe,0xc0,0xc0,0xc0,0xfc,0x06,0x06,
  0xc6,0x7c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x38,0x60,0xc0,0xc0,
  0xfc,0xc6,0xc6,0xc6,0x7c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xfe,
  0xc6,0x06,0x0c,0x18,0x30,0x30,0x30,0x30,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x7c,0xc6,0xc6,0xc6,0x7c,0xc6,0xc6,0xc6,0x7c,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x7c,0xc6,0xc6,0xc6,0x7e,0x06,0x06,0x0c,
  0x78,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x18,0x00,0x00,
  0x00,0x18,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x18,
  0x18,0x00,0x00,0x00,0x18,0x18,0x30,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x06,0x0c,0x18,0x30,0x60,0x30,0x18,0x0c,0x06,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7e,0x00,0x00,0x7e,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x60,0x30,0x18,0x0c,0x06,0x0c,
  0x18,0x30,0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7c,0xc6,0xc6,
  0x0c,0x18,0x18,0x00,0x18,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x7c,0xc6,0xc6,0xde,0xde,0xde,0xdc,0xc0,0x7c,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x10,0x38,0x6c,0xc6,0xc6,0xfe,0xc6,0xc6,0xc6,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0xfc,0x66,0x66,0x66,0x7c,0x66,0x66,
  0x66,0xfc,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3c,0x66,0xc2,0xc0,
  0xc0,0xc0,0xc2,0x66,0x3c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xf8,
  0x6c,0x66,0x66,0x66,0x66,0x66,0x6c,0xf8,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0xfe,0x66,0x62,0x68,0x78,0x68,0x62,0x66,0xfe,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0xfe,0x66,0x62,0x68,0x78,0x68,0x60,0x60,
  0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3c,0x66,0xc2,0xc0,0xc0,
  0xde,0xc6,0x66,0x3a,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc6,0xc6,
  0xc6,0xc6,0xfe,0xc6,0xc6,0xc6,0xc6,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x3c,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x3c,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x1e,0x0c,0x0c,0x0c,0x0c,0x0c,0xcc,0xcc,0x78,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xe6,0x66,0x6c,0x6c,0x78,0x6c,
  0x6c,0x66,0xe6,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xf0,0x60,0x60,
  0x60,0x60,0x60,0x62,0x66,0xfe,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0xc6,0xee,0xfe,0xd6,0xc6,0xc6,0xc6,0xc6,0xc6,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0xc6,0xe6,0xf6,0xfe,0xde,0xce,0xc6,0xc6,0xc6,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x38,0x6c,0xc6,0xc6,0xc6,0xc6,0xc6,
  0x6c,0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xfc,0x66,0x66,0x66,
  0x7c,0x60,0x60,0x60,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7c,
  0xc6,0xc6,0xc6,0xd6,0xde,0x7c,0x0c,0x0e,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0xfc,0x66,0x66,0x66,0x7c,0x6c,0x66,0x66,0xe6,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x7c,0xc6,0xc6,0x60,0x38,0x0c,0xc6,0xc6,
  0x7c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7e,0x5a,0x18,0x18,0x18,
  0x18,0x18,0x18,0x3c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc6,0xc6,
  0xc6,0xc6,0xc6,0xc6,0xc6,0xc6,0x7c,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0xc6,0xc6,0xc6,0xc6,0xc6,0xc6,0x6c,0x38,0x10,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0xc6,0xc6,0xc6,0xc6,0xc6,0xd6,0xfe,0xee,0xc6,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc6,0xc6,0xc6,0x6c,0x38,0x6c,
  0xc6,0xc6,0xc6,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc6,0xc6,0xc6,
  0x6c,0x38,0x38,0x38,0x38,0x7c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0xfe,0xc6,0x8c,0x18,0x30,0x60,0xc2,0xc6,0xfe,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x3c,0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x3c,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xc0,0xe0,0x70,0x38,0x1c,0x0e,
  0x06,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3c,0x0c,0x0c,0x0c,
  0x0c,0x0c,0x0c,0x0c,0x3c,0x00,0x00,0x00,0x00,0x00,0x10,0x38,0x6c,
  0xc6,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xfe,
  0x00,0x00,0x00,0x00,0x30,0x30,0x18,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x78,0x0c,
  0x7c,0xcc,0xcc,0x76,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xe0,0x60,
  0x60,0x78,0x6c,0x66,0x66,0x66,0xdc,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x7c,0xc6,0xc0,0xc0,0xc6,0x7c,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x1c,0x0c,0x0c,0x3c,0x6c,0xcc,0xcc,0xcc,0x76,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7c,0xc6,0xfe,
  0xc0,0xc6,0x7c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1c,0x36,0x32,
  0x30,0x7c,0x30,0x30,0x30,0x78,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x76,0xcc,0xcc,0xcc,0x7c,0x0c,0xcc,0x78,0x00,0x00,
  0x00,0x00,0x00,0xe0,0x60,0x60,0x6c,0x76,0x66,0x66,0x66,0xe6,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x18,0x00,0x38,0x18,0x18,0x18,
  0x18,0x3c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x06,0x06,0x00,0x0e,
  0x06,0x06,0x06,0x06,0x66,0x66,0x3c,0x00,0x00,0x00,0x00,0x00,0xe0,
  0x60,0x60,0x66,0x6c,0x78,0x6c,0x66,0xe6,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x38,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x3c,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x44,0xfe,0xd6,0xd6,0xd6,
  0xd6,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xdc,0x66,
  0x66,0x66,0x66,0x66,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x7c,0xc6,0xc6,0xc6,0xc6,0x7c,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0xdc,0x66,0x66,0x66,0x7c,0x60,0x60,0xf0,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x76,0xcc,0xcc,0xcc,0x7c,0x0c,
  0x0c,0x1e,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xdc,0x76,0x66,
  0x60,0x60,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x7c,0xc6,0x70,0x1c,0xc6,0x7c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x10,0x30,0x30,0xfc,0x30,0x30,0x30,0x36,0x1c,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0xcc,0xcc,0xcc,0xcc,0xcc,0x76,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc6,0xc6,0xc6,0x6c,
  0x38,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc6,
  0xc6,0xc6,0xd6,0xfe,0x6c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0xc6,0x6c,0x38,0x38,0x6c,0xc6,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0xc6,0xc6,0xc6,0xc6,0x7e,0x06,0x0c,0x78,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xfe,0xcc,0x18,0x30,0x66,
  0xfe,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0e,0x18,0x18,0x18,0x70,
  0x18,0x18,0x18,0x0e,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x18,
  0x18,0x18,0x00,0x18,0x18,0x18,0x18,0x00,0x00,0x00,0x00,0x00,0x00,
更多资料请点击进入:http://tftmcu.taobao.com
dirtwillfly 发表于 2014-2-12 23:34 | 显示全部楼层
谢谢分享
人民币的幻想 发表于 2014-2-13 08:03 来自手机 | 显示全部楼层
用的80并口的接口啊
 楼主| fmzhangpei241 发表于 2014-2-13 13:27 | 显示全部楼层
不是80并口的,是SPI串口的,只需4个IO口
农家小孩 发表于 2014-4-29 19:34 | 显示全部楼层
有移植到过stm32上吗,我移植一直不成功?
 楼主| fmzhangpei241 发表于 2014-6-6 20:15 | 显示全部楼层
我们有STM32的程序教程
cjseng 发表于 2014-6-6 22:36 | 显示全部楼层
为什么都是竖屏,没有横屏吗?
xiaoguai12137 发表于 2015-5-16 22:22 | 显示全部楼层
我们有STM32的程序教程
在哪里呀?一直移植不成功
gdqinci 发表于 2015-9-15 11:24 | 显示全部楼层
很好,我现在就在用这个屏
个人签名:51/avr/stm32驱动TFT彩屏。http://tftmcu.taobao.com/
26
