stm32GPIO模拟时序读写nandflash(K9F1G08U0B)问题
2043|2
 楼主| 司空落星 发表于 2014-2-17 09:36 | 显示全部楼层 |阅读模式
我使用的STM32F103VBT6这款芯片,K9F1G08U0B和 STM32F103VBT6连接接口有如下对应关系:
ALE——PA1
WE——PA2
WP——PA3
R\B——PC0
RE——PC1
CE——PC2
CLE——PC3
8位IO口对应PE0——PE7
下面4个函数,对应的是读取设备的ID,我在main函数里调用函数Nand_Flash_ReadDeviceID();
则会从串口打印出DeviceID = ec f1 0 95 40,这个设备ID号是正确的。问题在下面。
写指令函数
void Nand_FlashCommandLatch(uint8_t CommandTypes)
        Data_PortOutputMode();
        Flash_CE_Low;
        Flash_CLE_Low;
        Flash_ALE_Low;
        Flash_WE_High;
        Flash_CLE_High;
        Flash_WE_Low;
        Data_Output(CommandTypes);
        Flash_WE_High;
        Flash_CLE_Low;
        Flash_ALE_High;
        Flash_CE_High;
设置地址函数
void Nand_Flash_Write_Address(uint32_t Address)
        Flash_CE_Low;
        Flash_CLE_Low;
        Flash_WE_High;
        Flash_ALE_Low;
        Flash_ALE_High;
        Flash_WE_Low;
        Data_Output((Address));
        Flash_WE_High;
        Flash_ALE_Low;
        Flash_ALE_High;
        Flash_WE_Low;
        Data_Output((Address >> 8) & 0x0f);
        Flash_WE_High;
        Flash_ALE_Low;
        Flash_ALE_High;
        Flash_WE_Low;
        Data_Output((Address >> 12) & 0xFF);
        Flash_WE_High;
        Flash_ALE_Low;
        Flash_ALE_High;
        Flash_WE_Low;
        Data_Output((Address >> 20) & 0xFF);
        Flash_WE_High;
        Flash_ALE_Low;
        Flash_CE_High;
用来读设备的ID
void Nand_FlashReadData(uint8_t *pBuffer,uint32_t rd_Length)
        uint32_t i = 0;
        Data_PortInputMode();
        Flash_CE_Low;
        while(rd_Length--)
                Flash_RE_Low;
                *(pBuffer + i) = Data_Input;
                Flash_RE_High;
                i++;
        Flash_RE_High;
        Flash_CE_High;
/*读设备ID函数*/
void Nand_Flash_ReadDeviceID(void)
        uint8_t array[5];
        Nand_FlashCommandLatch(0x90);
        Nand_Flash_Write_Address(0x00);
        Nand_FlashReadData(array,5);
        printf("DeviceID = %x %x %x %x %x\r\n",array[0],array[1],array[2],array[3],array[4]);
下面的两个函数分别是向一页中写数据的函数和从一页中读出数据,我是对照K9F1G08U0D数据手册中Page Program Operation的时序和Read Operation的时序写的, 虽然我用的是K9F1G08U0B,但我觉得这两个应该时序上差别,我在main函数里面执行红色标记的代码,从串口打印出的数据如下:
Nand_FlashPage_Program is Error
Page 0 data:0xff 0x1e 0xf0 0x0 0x7 0x0 0xe0 0x0 0x7 0x18
而我写入的数据为 uint8_t arr[]="0123456789";
哪位大侠遇到过这样的问题,帮小弟解决一下,到底我的写错在哪里还是我的操作顺序有问题呢?
向某一页中写数据
bool Nand_FlashPage_Program(uint32_t PageNumber,uint8_t *string)
        uint8_t regvalue = 0;
        uint32_t i=2048,j=0;
        uint32_t Address = PageNumber*2048;
        uint8_t *pBuffer=string;
        Flash_CE_Low;
        Flash_ALE_Low;
        Flash_RE_High;
        Flash_CLE_High;
        Flash_WE_Low;
        Data_Output(0x80);
        Flash_WE_High;
        Flash_CLE_Low;
        Flash_ALE_High;
        Flash_WE_Low;
        Flash_WE_High;
        Flash_WE_Low;
        Data_Output((Address >> 8) & 0x0F);
        Flash_WE_High;
        Flash_WE_Low;
        Flash_WE_High;
        Flash_WE_Low;
        Flash_WE_High;
        Flash_ALE_Low;
        while(i--)
                Flash_WE_Low;
                Data_Output(*(pBuffer + j));
                Flash_WE_High;
                j++;
        Flash_WE_Low;
        Flash_CLE_High;
        Data_Output(0x10);
        Flash_WE_High;
        Flash_Wait();
        Flash_WE_Low;
        Data_Output(0x70);
        Flash_WE_High;
        Flash_CLE_Low;
        Flash_RE_Low;
        regvalue = Data_Input;
        Flash_RE_High;
        if(!( (1 << 0) & regvalue))
                return TRUE;
        else
                return         FALSE;
从一页中读出数据
void Nand_Flash_ReadOnePage(uint32_t sc_address,uint8_t *string)
        uint32_t Address = 2048*sc_address;
        uint8_t dat;
        //Flash_CLE_Low;
        //Flash_CE_High;
        //Flash_WE_High;
        Flash_CE_Low;
        Flash_ALE_Low;
        Flash_RE_High;
        Flash_CLE_High;
        Flash_WE_Low;
        Data_Output(0x00);
        Flash_WE_Low;
        Flash_WE_High;
        Flash_CLE_Low;
        Flash_ALE_High;
        Flash_WE_Low;
        Data_Output(Address);
        Flash_WE_High;
        Flash_WE_Low;
        Flash_WE_High;
        Flash_WE_Low;
        Flash_WE_High;
        Flash_WE_Low;
        Flash_WE_High;
        Flash_ALE_Low;
        Flash_CLE_High;
        Flash_WE_Low;
        Data_Output(0x30);
        Flash_WE_High;
        Flash_CLE_Low;
        Flash_Wait();
        while(i--)
                Flash_RE_Low;
                *(string+j) = Data_Input;
                Flash_Delay(c_FlashDelayCnt);
                Flash_RE_High;
int main(void)
        uint8_t array[2112],i;
        bool Is_ok;
        Init_RCC();
        delay_init(64);                     //延时函数初始化
        NVIC_Configuration();          //设置NVIC中断分组2:2位抢占优先级,2位响应优先级
        uart_init(115200);
        Nandflash_Init();
        Is_ok = Nand_FlashPage_Program(0x00,arr);
        if(Is_ok==TRUE)
                printf("Nand_FlashPage_Program is Successful\r\n");
        else
                printf("Nand_FlashPage_Program is Error\r\n");
        while(1)
                        Nand_Flash_ReadOnePage(0x00,array);
                        printf("Page 0 data:");
                        for(i=0;i<10;i++)
                                printf("0x%x ",array);
                        printf("\r\n");
                        delay_ms(1000);
这是我的nandflash初始化函数
void Nandflash_Init()
        GPIO_InitTypeDef  GPIO_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOE, ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        GPIO_SetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3);
        GPIO_Init(GPIOC, &GPIO_InitStructure);
        GPIO_SetBits(GPIOC,GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
        GPIOE->CRL = 0x33333333;
        Flash_WP_High;
 楼主| 司空落星 发表于 2014-2-17 09:38 | 显示全部楼层
各位大神,帮小弟分析一下到底是哪里出了问题,万分感激!
52414133 发表于 2014-2-26 09:44 | 显示全部楼层
