[AVR单片机] 两按键之间计时
1274|1
 楼主| 重新上路 发表于 2014-3-26 17:02 | 显示全部楼层 |阅读模式
求查看两按键之间计时程序哪里出错
#include <iom16v.h>
#include <macros.h>
#define uchar unsigned char
#define uint  unsigned int
uchar miao=0;
uchar feng=0;
uchar shi=0;
#pragma interrupt_handler kiao:9
#pragma data:code
const  table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d, 0x07,
                           0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
void delay(uint ms)
        uint i,j;
        for(i=0;i<ms;i++)
           for(j=0;j<1141;j++);
void show(uchar j,uchar k)
        PORTA|=BIT(3);
        PORTB=table[j];
        PORTA&=~BIT(3);
        PORTB=0XFF;
        PORTB&=~BIT(k);
        PORTA|=BIT(4);
        PORTA&=~BIT(4);
        delay(1);
uchar key_press()
{   uchar b;
     DDRD=0X0F;     //输出状态
     PORTD|=0X0F;  //输出高电平
         DDRD&=0x0f;   //输入状态
         b=PIND;       //记录电平状态
         b=b&0X0F;     //查看电平状态改变了旅挥?
         if(b==0x0f)
           return 0;
         else
         {  return 1;}
  uchar key_scan ()
  {   uchar s;
     delay (20);
    if(key_press)
        { s=PIND;       //记录电平状态
         s=s&0X0F;     //查看电平状态改变了旅挥?
    switch(s)
  case 0x0e:
         s=0;
         break;
case 0x0d:
               s=1;
               break;
case 0x0b:
               s=2;
               break;
case 0x07:
                s=3;
                break;
default :
           s=16        ;
  while(key_press())
  return s;
void kiao()
    if(miao==60)
{miao=0;
  miao++;
  feng++;
  if(feng==60)
    feng=0;
        feng++;
        shi++;
        if(shi==25)
          shi=0;
          shi++;
        else
         shi++;
  else
    feng++;
else
miao++;
        TCNT1H=0X85;
        TCNT1L=0XED;
void main()
    uchar l,j,i=0;
    DDRD=0X0F;
        DDRA|=0X18;
        l=key_press();
        if(l==1)
          j=key_scan();
        if(j==1)
        i=i+j;
        if(i%2)
        TCCR1B=0X04;
        TCNT1H=0X85;
        TCNT1L=0XED;
        TIMSK&=~BIT(2);
        SREG|=BIT(7);
        else
          TCCR1B=0X04;
        TCNT1H=0X85;
        TCNT1L=0XED;
        TIMSK|=BIT(2);
        SREG|=BIT(7);
        else
        miao=0;
        feng=0;
        shi=0;
        while(1)
            show(miao/10,4);
                show(miao%10,5);
                 show(feng/10,2);
                show(feng%10,3);
                 show(shi/10,0);
                show(shi%10,1);
huangxz 发表于 2014-3-30 22:12 | 显示全部楼层
问题描述不清楚
