[i.MX] android 编译环境安装
2463|5
 楼主| lqland 发表于 2014-4-3 21:22 | 显示全部楼层 |阅读模式
$ sudo apt-get install git gnupg flex bison gperf build-essential \
  zip curl libc6-dev libncurses5-dev:i386 x11proto-core-dev \
  libx11-dev:i386 libreadline6-dev:i386 libgl1-mesa-glx:i386 \
  libgl1-mesa-dev g++-multilib mingw32 tofrodos \
  python-markdown libxml2-utils xsltproc zlib1g-dev:i386
上述安装,会提示如下信息,是何问题????
Reading package lists... Done
Building dependency tree
Reading state information... Done
gnupg is already the newest version.
libc6-dev is already the newest version.
libc6-dev set to manually installed.
zip is already the newest version.
zip set to manually installed.
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
build-essential : Depends: g++ (>= 4:4.4.3) but it is not installable
                   Depends: dpkg-dev (>= 1.13.5) but it is not going to be installed
g++-multilib:i386 : Depends: cpp:i386 (>= 4:4.6.3-1ubuntu5) but it is not going to be installed
                     Depends: gcc-multilib:i386 (>= 4:4.6.3-1ubuntu5) but it is not going to be installed
                     Depends: g++:i386 (>= 4:4.6.3-1ubuntu5) but it is not going to be installed
                     Depends: g++-4.6-multilib:i386 (>= 4.6.3-1~) but it is not going to be installed
git:i386 : Depends: perl-modules:i386 but it is not installable
            Depends: liberror-perl:i386 but it is not installable
            Depends: git-man:i386 (> 1:1.7.9.5) but it is not installable
            Depends: git-man:i386 (< 1:1.7.9.5-.) but it is not installable
            Recommends: less:i386 but it is not going to be installed
libgl1-mesa-dev : Depends: mesa-common-dev (= 8.0.4-0ubuntu0.7) or
                            mesa-common-dev-lts-quantal but it is not going to be installed or
                            mesa-common-dev-lts-raring but it is not going to be installed or
                            mesa-common-dev-lts-saucy but it is not going to be installed or
                            mesa-common-dev-lts-trusty but it is not installable
                   Depends: libxext-dev but it is not going to be installed
libgl1-mesa-glx:i386 : Depends: libglapi-mesa:i386 (= 8.0.4-0ubuntu0.7)
                        Recommends: libgl1-mesa-dri:i386 (>= 7.2)
libx11-dev:i386 : Depends: x11proto-kb-dev:i386 but it is not installable
                   Depends: xtrans-dev:i386 but it is not installable
                   Recommends: libx11-doc:i386
x11proto-core-dev : Depends: xorg-sgml-doctools (>= 1:1.5) but it is not installable
FSL_TICS_ZJJ 发表于 2014-4-4 14:52 | 显示全部楼层
楼主,你一口气问那么多贴,一样的问题,你就发一帖就行了。
FSL_TICS_Rita 发表于 2014-4-4 14:55 | 显示全部楼层
楼主你好,请问你是想要下载android哪个版本的源码?
 楼主| lqland 发表于 2014-4-4 15:05 | 显示全部楼层
楼上的老大,是我的帖子被删除了,现在一起恢复出来呢
FSL_TICS_Rita 发表于 2014-4-4 15:06 | 显示全部楼层
楼主你好,这里出现这个是由于apt-get 依赖版本过高的原因,你在google一下是可以搜索到的。解决办法,建议你下载android前,先更新一下你的源:
#sudo gedit /etc/apt/sources.list
Delete all item in this file, then copy the following server addresses to it (163 or Souhu):
163:
deb http://mirrors.163.com/ubuntu/ precise main restricted
deb-src http://mirrors.163.com/ubuntu/ precise main restricted
deb http://mirrors.163.com/ubuntu/ precise-updates main restricted
deb-src http://mirrors.163.com/ubuntu/ precise-updates main restricted
deb http://mirrors.163.com/ubuntu/ precise universe
deb-src http://mirrors.163.com/ubuntu/ precise universe
deb http://mirrors.163.com/ubuntu/ precise-updates universe
deb-src http://mirrors.163.com/ubuntu/ precise-updates universe
deb http://mirrors.163.com/ubuntu/ precise multiverse
deb-src http://mirrors.163.com/ubuntu/ precise multiverse
deb http://mirrors.163.com/ubuntu/ precise-updates multiverse
deb-src http://mirrors.163.com/ubuntu/ precise-updates multiverse
deb http://mirrors.163.com/ubuntu/ precise-backports main restricted universe multiverse
deb-src http://mirrors.163.com/ubuntu/ precise-backports main restricted universe multiverse
deb http://mirrors.163.com/ubuntu/ precise-security main restricted
deb-src http://mirrors.163.com/ubuntu/ precise-security main restricted
deb http://mirrors.163.com/ubuntu/ precise-security universe
deb-src http://mirrors.163.com/ubuntu/ precise-security universe
deb http://mirrors.163.com/ubuntu/ precise-security multiverse
deb-src http://mirrors.163.com/ubuntu/ precise-security multiverse
deb http://extras.ubuntu.com/ubuntu precise main
deb-src http://extras.ubuntu.com/ubuntu precise main
保存退出。然后执行命令:
#sudo apt-get update
更新之后,你再安装那些包的话就不会有问题了。
FSL_TICS_Rita 发表于 2014-4-8 15:42 | 显示全部楼层
楼主你好,如果这个问题你已经解决,麻烦把贴结了,如果没有,欢迎继续在这里讨论。
