提供CPU/H264_MPEG4/USB/PCIe/SATA/3D/2D/DDR2/DDR3/24bit DSP/PHY等常用IP cores -8bit 1T/2T/4T/12T MCU 8bit RISC CPU Turbo 186 V6502 V8086 16bit MCU 32bit RISC CPU (MIPS/ARC/ARM) IBM PowerPC405 IBM PowerPC440 IBM PowerPC460 IBM PowerPCPLB Audio Echo Processor 16/24 audio DSP Core 16bit audio echo DSP core 16bit audio DAC (Digital design parts)
- Interface IP: Usb1.0 Host/Device/Hub Usb1.0 Low speed/Full speed PHY Usb2.0 Host/Device/OTG controller USB2.0 HS/OTG PHY @180nm/130nm/90nm/65nm (TSMC/SMIC/IBM/Charted process) USB2.0 mobile nanoPHY @130nm/90nm/65nm (TSMC/SMIC/IBM/Charted process) Wireless USB controller/wirless usb driver PCI/PCI-X PCI-Express endpoint/rootmode/swtich brige controller PCI-Express PHY @130nm/90nm/65nm (TSMC/SMIC process) IEEE1394 Controller Ethernet 10/100/1000 Controller Ethernet 10G MAC controller & PHY IDE controoler SATA host/device Controller SATA PHY @130nm/90nm/65nm (TSMC/SMIC process) Media Local BUS IP SD_MMC host controller IP LCD controller MemoryStick Host controller Smart card reader AMBA2.0/3.0 IP AMBA Interface IP DDR2/DDR3 memory controller DDR2/DDR memory controller DDR3/DDR2 SDRAM PHY DDR2/DDR2 SDRAM PHY Mobile Storage controller (include SDIO/CEVA/MMC host controller) SDIO device controller WLAN AFE IP TSMC PLL Arasan Nand Flash controller/SDIO device controller CMOS Sensor Interface IP SPDIF Interface IP - JPEG Encoder/Decoder/Codec Motion-JPEG MPEG2 Decoder H264/MPEG4 codec H264/MPEG4 decoder H264/MPEG4 encoder H264/MPEG4 HD codec MPEG4 encoder 2D graphics core 3D graphics core for PDA & audio 3D graphics core for wirless products TV encoder
另外还提供各种各样得synopsys & cadence & mentor & magma 等ASIC设计EDA平台(windows & linux & Solaris版本),有需要 可以email联系详细谈。
Email: soft_cores@163.com |
