[51单片机] 新茂单片机的ADC
1947|5
 楼主| wajajn 发表于 2014-4-9 09:16 | 显示全部楼层 |阅读模式
#include "SM39R16A2.h"
#include "ad.h"
#define d_ADCnEN                 0x40
#define d_ADC_CLK_Sel        d_ADC_CLK_DIV2
#define d_ADCR                        0x00
double n_data,z;
double n_ADCD10 ;
double z_ADCD10 ;
void ADCstart(unsigned char n_ADC_CH)
        ADCC2 = (0x80|d_ADCR|n_ADC_CH);        //ADC start conversion
void ADCInit(unsigned char n_ADCnEN, unsigned char n_ADC_CLK)
        ADCC1 = n_ADCnEN;        //Set ADC channel
        ADCCS = n_ADC_CLK;        //Select ADC clock
        IEADC = 1;                        //Enable ADC interrupt.
        EA = 1;
double ADC_Read10()//10-bit ADC
        n_ADCD10 = (ADCDH<<2);        //10-bit ADC
        return n_ADCD10;
void ADCInterrupt(void) interrupt d_ADC_Vector        // ADC Interrupt Vector Address 0053h => interrupt 10
        n_data = ADC_Read10();        //Read ADC
void ADC_stop(void)
        ADCC2 =        0x00;        //ADC stop conversion
double ADC(void)
        if (d_ADCnEN & 0x01)
                ADCstart(d_ADC_CH0_IN);
                while(!ADCIF);
                ADC_stop();
        if (d_ADCnEN & 0x02)
                ADCstart(d_ADC_CH1_IN);
                while(!ADCIF);
                ADC_stop();
        if (d_ADCnEN & 0x04)
                ADCstart(d_ADC_CH2_IN);
                while(!ADCIF);
                ADC_stop();
        if (d_ADCnEN & 0x08)
                ADCstart(d_ADC_CH3_IN);
                while(!ADCIF);
                ADC_stop();
        if (d_ADCnEN & 0x10)
                ADCstart(d_ADC_CH4_IN);
                while(!ADCIF);
                ADC_stop();
        if (d_ADCnEN & 0x20)
                ADCstart(d_ADC_CH5_IN);
                while(!ADCIF);
                ADC_stop();
                if (d_ADCnEN & 0x40)
                        ADCstart(d_ADC_CH6_IN);
                        while(!ADCIF);
                        ADC_stop();
        if (d_ADCnEN & 0x80)
                ADCstart(d_ADC_CH7_IN);
                while(!ADCIF);
                ADC_stop();
        return n_data;
Header file for ADC.
Modify on 2010/07/1.
#ifndef                __ADC_H__
#define                __ADC_H__
// Example Code
void main(void)
        ADCInit(d_ADCnEN, d_ADC_CLK_Sel);
        ADC();
        ADC_stop();
        while(1);
void ADCstart(unsigned char n_ADC_CH);
void ADCInit(unsigned char n_ADCnEN, unsigned char n_ADC_CLK);
double ADC_Read10();
void ADC_stop(void);
double ADC(void);
//DEFINITIONs
#define d_ADC_CLK_DIV2                0x00
#define d_ADC_CLK_DIV4                0x01
#define d_ADC_CLK_DIV6                0x02
#define d_ADC_CLK_DIV8                0X03
#define d_ADC_CLK_DIV10                0x04
#define d_ADC_CLK_DIV12                0x05
#define d_ADC_CLK_DIV14                0x06
#define d_ADC_CLK_DIV16                0x07
#define d_ADC_CLK_DIV18                0x08
#define d_ADC_CLK_DIV20                0x09
#define d_ADC_CLK_DIV22                0x0A
#define d_ADC_CLK_DIV24                0x0B
#define d_ADC_CLK_DIV26                0x0C
#define d_ADC_CLK_DIV28                0x0D
#define d_ADC_CLK_DIV30                0x0E
#define d_ADC_CLK_DIV32                0x0F
#define d_ADC_CLK_DIV34                0x10
#define d_ADC_CLK_DIV36                0x11
#define d_ADC_CLK_DIV38                0x12
#define d_ADC_CLK_DIV40                0x13
#define d_ADC_CLK_DIV42                0x14
#define d_ADC_CLK_DIV44                0x15
#define d_ADC_CLK_DIV46                0x16
#define d_ADC_CLK_DIV48                0x17
#define d_ADC_CLK_DIV50                0x18
#define d_ADC_CLK_DIV52                0x19
#define d_ADC_CLK_DIV54                0x1A
#define d_ADC_CLK_DIV56                0x1B
#define d_ADC_CLK_DIV58                0x1C
#define d_ADC_CLK_DIV60                0x1D
#define d_ADC_CLK_DIV62                0x1E
#define d_ADC_CLK_DIV64                0x1F
#define d_ADC_CH0_IN                0
#define d_ADC_CH1_IN                1
#define d_ADC_CH2_IN                2
#define d_ADC_CH3_IN                3
#define d_ADC_CH4_IN                4
#define d_ADC_CH5_IN                5
#define d_ADC_CH6_IN                6
#define d_ADC_CH7_IN                7
#endif
为什么检测出来的adc不稳定,变化很大,波动,是片子的问题,我觉得硬件是没问题的
旭日东起 发表于 2014-4-9 14:55 | 显示全部楼层
取高8位的AD值嘛,电源波动大不大的?
 楼主| wajajn 发表于 2014-4-12 15:32 | 显示全部楼层
取高8位的AD值嘛,电源波动大不大的?
我试过了,不行,电压基本不变
 楼主| wajajn 发表于 2014-4-15 09:32 | 显示全部楼层
是不是要校准电压
 楼主| wajajn 发表于 2014-7-31 13:49 | 显示全部楼层
sm39r16a3的ad只有第一口有基准电压
微思科技 发表于 2014-7-31 16:18 | 显示全部楼层
单片机开发。
深圳微思科技电子有限公司
