[AVR单片机]
会汇编的进 帮忙翻译
1279|4
anne82820|  楼主 | 2014-4-11 15:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
; function:  N-次方差计算
;    INPUT:
;          ZH:ZL:= #R_SSP_ADC_CoorBuf_E0E2
;           VarL:= NUMBER
; VarL,VarH,VAR2,VAR3
Sub_calculation_Coording_3DEA:
                        CALL    Sub_OpenStk_withXDate__11F2
                        WDR
                        CLR     XH
                        CLR     XL
                        MOVW    dw4A, XL
                        WDR
                        LDD     ZH, Y+$04
                                                LDD     ZL, Y+$05 ;D
                                                MOVW    dw4E, ZL
                                ;       [ 信号曲线参数保存  ]
                        MOVW        ZL, dw4E
                        PUSH    ZL
                        PUSH    ZH
                        LDI                XH, HIGH(R_SSP_ADC_buffer_C307)
                        LDI                XL,  LOW(R_SSP_ADC_buffer_C307)
                        CALL    Sub_MOV_SMPADC_To_Coor_42E5
                        POP     ZH
                                                POP     ZL
                        LDI     XL, $01
                        LDD     XH, Y+$07
                                                TST     XH
                                                BREQ        _L_next_3E0F
                                                BRLT    _L_next_3E0F
_L_loop_3E0B:           LSL     XL
                        DEC     XH
                        TST                XH
                        BRNE    _L_loop_3E0B   ; bgt _L_loop_3E0B
_L_next_3E0F:           MOV     dw48, XL
                        LDI                ZH, HIGH(R_SSP_ADC_buffer_C307)
                        LDI                ZL,  LOW(R_SSP_ADC_buffer_C307)
                        MOVW    dw4d:dw4C, ZH:ZL
                        MOV     dw49, dw48
                        ;       RAM_dw4A <== Fun_SUM{ @R_SSP_ADC_buffer_C307+.. for 2^^Stk }
_L_loop_3E1A:           TST                dw49
                        BREQ    _L_next_3E30
                        MOVW        ZL, dw4D:dw4C
                        CLR     XH
                        LD      XL, Z+
                        MOVW    dw4D:dw4C, ZH:ZL
                        MOVW        ZH:ZL, dw4B:dw4A
                        ADD                ZL, XL
                        ADC                ZH, XH
                        MOVW    dw4B:dw4A, ZH:ZL
                                                DEC                dw49
                        JMP    _L_loop_3E1A
                                ;       RAM_dw4E <== RAM_dw4E + RAM_dw48+1/2
_L_next_3E30:           MOV     XL, dw48
                        LSR     XL
                        CLR     XH
                        MOVW        ZH:ZL, dw4F:dw4E
                        ADD                ZL, XL
                        ADC                ZH, XH
                        MOVW        dw4F:dw4E, ZH:ZL
                        CLR     ZH
                        MOV     ZL, dw48
                        LDI                XL,  LOW(D_LONGE_ADC/10)        ;
                        LDI                XH, HIGH(D_LONGE_ADC/10)        ;
                      SUB                XL, ZL
                        SBC                XH, ZH
                        MOVW    dw47:dw46, XH:XL
                        WDR
_L_loop_3E44:           ;                number
                        TST                dw46
                        BRNE    _L_0701_0514
                        TST                dw47
                        BRNE    _L_0701_0514
                        JMP        _L_exit_3E91
_L_0701_0514:               WDR
                        CLR     ZH
                        MOV     ZL, dw48
                        MOVW    XL, dw4A
                        CALL    SUB_HC_IDIV  ; X/Z == {Fun_SUM{@R_SSP_ADC_buffer_C307+.. for 2^^Stk}} / 2^^Stk
                        MOVW    XH:XL, ZL       ; X/Z =>Z, r=>X
                        MOVW    ZH:ZL, dw4E
                        ST      Z+, XL
                        MOVW    dw4E, ZL
                        MOVW    ZH:ZL, dw4D:dw4C
                        CLR     XH
                        MOV     XL, dw48
                        SUB                ZL, XL
                        SBC                ZH, XH
                        LD                XL, Z
                        CLR                XH
                        MOVW    ZH:ZL, dw4A
                        SUB                ZL, XL
                        SBC                ZH, XH
                        MOVW    dw4A, ZL
                        CLR     XH
                        LD      XL, Z+
                        ADD                dw4A, XL
                        ADC                dw4B, XH
                        MOVW    XH:XL, dw47:dw46
                        SBIW    XH:XL, 1
                        JMP    _L_loop_3E44
_L_exit_3E91:           MOVW    ZH:ZL, dw4E
                        SBIW    ZH:ZL, 1
                        LDD     XL, Z+$00
                        STS     R_C306, XL
                        MOVW    XL, dw48
                        LSR     XL
                        MOV     dw49, XL
_L_loop_3E9E:           TST     dw49
                        BREQ    _L_end_3EB2
                        MOVW        ZL, dw4E
                        ADIW    ZH:ZL, 1
                        MOVW    dw4E, ZL
                        SBIW    ZH:ZL, 1
                        LDS     XL, R_C306
                        STD     Z+$00, XL
                        DEC                dw49
                        JMP    _L_loop_3E9E
_L_end_3EB2:            CALL    Sub_CloseStk_withXDate__1232
anne82820|  楼主 | 2014-4-11 15:24 | 只看该作者
别人给的程序的,不太会汇编的,大家给翻译一下,看看什么思路,我用c语言写
望断云山| | 2014-4-16 13:28 | 只看该作者
这个程序明显是机器生成的汇编再人工修饰一下
anne82820|  楼主 | 2014-4-17 09:25 | 只看该作者
你的意思是被反汇编的程序嘛?然后在添加一些说明吗?靠,太黑了吧,坑爹
anne82820|  楼主 | 2014-4-17 09:26 | 只看该作者
那还能不能反回去的,可能之前的是c语言的版本吧
