[DSP编程] 关于28335分频倍频程序问题
6896|7
 楼主| 黑石部队 发表于 2014-4-30 12:06 | 显示全部楼层 |阅读模式
这是ti官网的一个例子片段
void InitPll(Uint16 val, Uint16 divsel)
   // Make sure the PLL is not running in limp mode
   if (SysCtrlRegs.PLLSTS.bit.MCLKSTS != 0)
      // Missing external clock has been detected
      // Replace this line with a call to an appropriate
      // SystemShutdown(); function.
      asm("        ESTOP0");
   // DIVSEL MUST be 0 before PLLCR can be changed from
   // 0x0000. It is set to 0 by an external reset XRSn
   // This puts us in 1/4
   if (SysCtrlRegs.PLLSTS.bit.DIVSEL != 0)
       EALLOW;
       SysCtrlRegs.PLLSTS.bit.DIVSEL = 0;
       EDIS;
   // Change the PLLCR
   if (SysCtrlRegs.PLLCR.bit.DIV != val)
      EALLOW;
      // Before setting PLLCR turn off missing clock detect logic
      SysCtrlRegs.PLLSTS.bit.MCLKOFF = 1;
      SysCtrlRegs.PLLCR.bit.DIV = val;
      EDIS;
      // Optional: Wait for PLL to lock.
      // During this time the CPU will switch to OSCCLK/2 until
      // the PLL is stable.  Once the PLL is stable the CPU will
      // switch to the new PLL value.
      // This time-to-lock is monitored by a PLL lock counter.
      // Code is not required to sit and wait for the PLL to lock.
      // However, if the code does anything that is timing critical,
      // and requires the correct clock be locked, then it is best to
      // wait until this switching has completed.
      // Wait for the PLL lock bit to be set.
      // The watchdog should be disabled before this loop, or fed within
      // the loop via ServiceDog().
          // Uncomment to disable the watchdog
      DisableDog();
      while(SysCtrlRegs.PLLSTS.bit.PLLLOCKS != 1)
              // Uncomment to service the watchdog
          // ServiceDog();
      EALLOW;
      SysCtrlRegs.PLLSTS.bit.MCLKOFF = 0;
      EDIS;
    // If switching to 1/2
        if((divsel == 1)||(divsel == 2))
                EALLOW;
            SysCtrlRegs.PLLSTS.bit.DIVSEL = divsel;
            EDIS;
        // If switching to 1/1
        // * First go to 1/2 and let the power settle
        //   The time required will depend on the system, this is only an example
        // * Then switch to 1/1
        if(divsel == 3)
                EALLOW;
            SysCtrlRegs.PLLSTS.bit.DIVSEL = 2;
            DELAY_US(50L);
            SysCtrlRegs.PLLSTS.bit.DIVSEL = 3;
            EDIS;
从程序来看分频倍频由val divsel这两个变量决定,我在外部用30MHZ晶振,应选取10倍频,2分频,那这两个值需要在头文件分别定义为10和2,但是官方程序的头文件2833x_example.这样写的//#define DSP28_DIVSEL   0   // Enable /4 for SYSCLKOUT
//#define DSP28_DIVSEL   1 // Disable /4 for SYSCKOUT
#define DSP28_DIVSEL     2 // Enable /2 for SYSCLKOUT
//#define DSP28_DIVSEL     3 // Enable /1 for SYSCLKOUT
#define DSP28_PLLCR   10
//#define DSP28_PLLCR    9
//#define DSP28_PLLCR    8
//#define DSP28_PLLCR    7
//#define DSP28_PLLCR    6
//#define DSP28_PLLCR    5
//#define DSP28_PLLCR    4
//#define DSP28_PLLCR    3
//#define DSP28_PLLCR    2
//#define DSP28_PLLCR    1
//#define DSP28_PLLCR    0  /
意思是让我们从中各选择一个,其它的宏定义删掉,但是程序中是val divsel这两个值对寄存器赋值,而不是DSP28_DIVSEL 和DSP28_PLLCR,我是否应该改成/#define divsel 2和#define val 10?
zhangmangui 发表于 2014-5-3 10:20 | 显示全部楼层
直接这么写就可以啦    不知道为什么搞那么麻烦
// Initalize PLL
   SysCtrlRegs.PLLCR = 0x01;
   // Wait for PLL to lock
   for(i= 0; i< 5000; i++){}
// HISPCP/LOSPCP prescale register settings, normally it will be set to default values
   SysCtrlRegs.HISPCP.all = 0x0001;
   SysCtrlRegs.LOSPCP.all = 0x0002;
 楼主| 黑石部队 发表于 2014-5-3 17:14 | 显示全部楼层
对不起,可能是我表述有问题,我想用内置振荡器,30MHZ晶振是接在X1和X2之间的,究竟是对val divsel这两个值定义还是DSP28_DIVSEL 和DSP28_PLLCR定义?
airwill 发表于 2014-5-5 14:56 | 显示全部楼层
意思是让我们从中各选择一个,其它的宏定义删掉,           这里完全正确.
还是用 DSP28_DIVSEL 和DSP28_PLLCR,找找 InitPll(Uint16 val, Uint16 divsel) 是在哪里调用的,就知道了
DSP28_DIVSEL 和DSP28_PLLCR 作为变量传递给了 InitPll()了
 楼主| 黑石部队 发表于 2014-5-5 22:35 | 显示全部楼层
知道了,谢谢。
 楼主| 黑石部队 发表于 2014-5-5 22:51 | 显示全部楼层
看来是我太粗心了,没看到,从上文中找到了感谢大家无私帮助。
void InitSysCtrl(void)
   // Disable the watchdog
   DisableDog();
   // Initialize the PLL control: PLLCR and DIVSEL
   // DSP28_PLLCR and DSP28_DIVSEL are defined in DSP2833x_Examples.h
   InitPll(DSP28_PLLCR,DSP28_DIVSEL);
   // Initialize the peripheral clocks
   InitPeripheralClocks();
Laspide 发表于 2014-5-6 11:48 | 显示全部楼层
这种宏定义方式会把所有可能的配置情况都定义出来,好处就是如果程序的配置发生更改,只需要调整宏的使用就可以了,程序配置改起来很方便,因为所有可能的配置计算都已经在前面就设计好了。
只要修改H文件中的宏定义使用,而且不用修改C文件里的函数。
在较大规模的软件设计中,这种方式是首选的。
想想几个人开发一个软件,你修改或调试别人的程序,要重新看手册、计算参数,找函数
Lonny0406 发表于 2015-4-10 22:22 | 显示全部楼层
感觉TI公司给的初始化代码很繁琐,有简单的吗?
