[STM32F0] 谁有STM32F051的USART2的例程
8545|10
 楼主| lr2131 发表于 2014-5-5 20:13 | 显示全部楼层 |阅读模式
用的青风的例程,USART1是没问题的,但是改成USART2就不行,调了很长时间还是找不到原因。
先贴出USART1的例程吧,接受我用的是中断,发送没用中断。
int main(void)
    unsigned char i = 3;
    USART1_Configuration();
  while (1)
    USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
    UART1_send_byte(i ++);
extern void USART1_Configuration(void)//′??ú3?ê??ˉoˉêy
    GPIO_InitTypeDef  GPIO_InitStructure;
    USART_InitTypeDef USART_InitStructure;
    NVIC_SetPriority(USART1_IRQn, 0); /* (4) */
    NVIC_EnableIRQ(USART1_IRQn); /* (5) */
    RCC_AHBPeriphClockCmd( RCC_AHBPeriph_GPIOA, ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE );
    GPIO_PinAFConfig(GPIOA,GPIO_PinSource9,GPIO_AF_1);
    GPIO_PinAFConfig(GPIOA,GPIO_PinSource10,GPIO_AF_1);
    *  USART1_TX -> PA9 , USART1_RX ->  PA10
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9|GPIO_Pin_10;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
    GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    USART_InitStructure.USART_BaudRate = 115200;//éè??′??ú2¨ì??ê
    USART_InitStructure.USART_WordLength = USART_WordLength_8b;//éè??êy?Y??
    USART_InitStructure.USART_StopBits = USART_StopBits_1;//éè??í£?1??
    USART_InitStructure.USART_Parity = USART_Parity_No;//éè??D§?é??
    USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//éè??á÷????
    USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//éè??1¤×÷?£ê?
    USART_Init(USART1, &USART_InitStructure); //????è??á11ì?
   //USART_ITConfig(USART1, USART_IT_TXE, ENABLE);
    USART_Cmd(USART1, ENABLE);//ê1?ü′??ú1
extern void UART1_send_byte(uint8_t byte)
    while(!((USART1->ISR)&(1<<7)));
    USART1->TDR=byte;
extern volatile uint8_t USART_Data = 0;
extern void USART1_IRQHandler(void)
  if((USART1->ISR & USART_ISR_TC) == USART_ISR_TC)
    USART1->ICR |= USART_ICR_TCCF;/* clear transfer complete flag */
  else if((USART1->ISR & USART_ISR_RXNE) == USART_ISR_RXNE)
    USART_Data = USART1->RDR;/* receive data, clear flag */
  else
    NVIC_DisableIRQ(USART1_IRQn);/* Disable USART1_IRQn */
上面的代码是可以的,我用仿真器和逻辑分析仪查过,都是没问题的。
但是对着改USART2就是不行,用逻辑分析仪看,TX都没有输出信号。试过做回环测试,发不出数据,自然也不会收到数据,也就进不了接受中断。
int main(void)
    USART2_Configuration();
  while (1)
    USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);
    UART2_send_byte(i ++);
extern void USART2_Configuration(void)//′??ú3?ê??ˉoˉêy
    NVIC_SetPriority(USART2_IRQn, 0); /* (4) */
    NVIC_EnableIRQ(USART2_IRQn); /* (5) */
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE );
    GPIO_PinAFConfig(GPIOA,GPIO_PinSource2,GPIO_AF_1);
    GPIO_PinAFConfig(GPIOA,GPIO_PinSource3,GPIO_AF_1);
    *  USART2_TX -> PA2 , USART2_RX ->  PA3
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2|GPIO_Pin_3;
    USART_Init(USART2, &USART_InitStructure); //????è??á11ì?
   //USART_ITConfig(USART2, USART_IT_TXE, ENABLE);
    USART_Cmd(USART2, ENABLE);//ê1?ü′??ú1
extern void UART2_send_byte(uint8_t byte)
    while(!((USART2->ISR)&(1<<7)));
    USART2->TDR=byte;
extern void USART2_IRQHandler(void)
  if((USART2->ISR & USART_ISR_TC) == USART_ISR_TC)
    USART2->ICR |= USART_ICR_TCCF;/* clear transfer complete flag */
  else if((USART2->ISR & USART_ISR_RXNE) == USART_ISR_RXNE)
    USART_Data = USART2->RDR;/* receive data, clear flag */
  else
    NVIC_DisableIRQ(USART2_IRQn);/* Disable USART1_IRQn */
mmuuss586 发表于 2014-5-5 20:33 | 显示全部楼层
加上:
USART_DeInit(USART1);
USART_DeInit(USART2);
 楼主| lr2131 发表于 2014-5-7 13:08 | 显示全部楼层
加上:
我试试
 楼主| lr2131 发表于 2014-5-7 15:09 | 显示全部楼层
加上:
试过了,还是不行。
 楼主| lr2131 发表于 2014-5-19 17:44 | 显示全部楼层
问题已解决,测试的方法不对。
zhuri_1 发表于 2014-5-22 13:27 | 显示全部楼层
问题已解决,测试的方法不对。
我也是同样的问题啊, 用示波器看USART2的TX 都没有输出,配置和楼主的一样,请问是怎么解决的,谢谢
 楼主| lr2131 发表于 2014-5-22 13:45 | 显示全部楼层
我也是同样的问题啊, 用示波器看USART2的TX 都没有输出,配置和楼主的一样,请问是怎么解决的,谢谢  ...
我的已经解决了,代码是没有问题的。
我的是测试串口的方法不对,不能在接受中断中加断点,外部串口还不停的发送。
不然的话,在断点处,程序停下来,但硬件的RxFIFO,没有停止,下次进这个中断就变成了FIFO溢出中断。
在接受中断里面用局部静态变量记录下进入的次数就知道,其实每次都是正常的进入。
 楼主| lr2131 发表于 2014-5-23 16:31 | 显示全部楼层
1.你先查查你用示波器测的是不是TX,另外注意看看电平对不对
2.外部可能没有上拉电阻。
代码的话,应该是没问题,多查查硬件吧
880705lpdhr 发表于 2015-11-12 14:28 | 显示全部楼层
xingnaipeng 发表于 2016-1-19 10:12 | 显示全部楼层
我的也不能用啊,楼主怎么解决的?
xingnaipeng 发表于 2016-1-19 10:13 | 显示全部楼层
我的也不能用啊,你是怎么解决的?
