怎么用MSP430F149和两组L298N控制四个电机呢?控制前进、后退、左转、右转,求程序,最好有注释。我现在能用一个L298N驱动两个电机。
#include "msp430x14x.h"
#define P1_0 0x01 // 左电机控制 IN1 00000001
#define P1_1 0x02 // 左电机控制 IN2 00000010
#define P1_2 0x04 // 左电机控制 PWM1 00000100
#define P1_3 0x08 // 右电机控制 PWM2 00001000
#define P1_4 0x10 // 右电机控制 IN3 00001010
#define P1_5 0x20 // 右电机控制 IN4 00010100
#define PWM_TIMES 200 //PWM周期为20ms
PWM设置函数 motor:设置的电机编号 0左电机,1右电机;
percent: PWM占空比; times:PWM周期 0.1ms为单位;
void Pwm_Set(unsigned char motor, unsigned int percent,unsigned int times)
unsigned int per;
unsigned long count=0;
if(percent==0)
TACTL=0x00;
if(percent<100)
percent=100-percent;
else
percent=percent-100;
count=80*times; //计时脉冲个数=80*times;
per=count*percent/100; //正脉冲计时个数
P1DIR |= 0x0C; // IO1.2 and IO1.3 output
P1SEL |= 0x0C; // IO1.2 and IO1.3 TA1/2 otions
CCR0 = count; // PWM Period
if(motor==0)
CCTL1 = OUTMOD_7; // CCR1 reset/set
CCR1 = per; // CCR1 PWM duty cycle
else if(motor==1)
CCTL2 = OUTMOD_7; // CCR2 reset/set
CCR2 = per; // CCR2 PWM duty cycle
TACTL = TASSEL_2 + MC_1; // SMCLK, up mode
// _BIS_SR(LPM0_bits); // Enter LPM0
功能:电机执行动作
参数:
motor_num: 电机的号码,1 右电机 ; 0 左电机
event: 电机的动作, 0停止,1前进,2后退,3刹车
speed: 电机的速度,既PWM占空比
void Motor(unsigned char motor_num,unsigned char event,unsigned char speed)
if(motor_num==0)
switch(event)
case 0: P1OUT&=~(P1_0+P1_1); //停止
break;
case 1: P1OUT|=P1_0;P1OUT&=~P1_1; //前进
break;
case 2: P1OUT|=P1_1;P1OUT&=~P1_0; //后退
break;
case 3: P1OUT|=(P1_0+P1_1); //刹车
break;
default:
break;
Pwm_Set(0,speed,PWM_TIMES);
else if(motor_num==1)
switch(event)
case 0: P1OUT&=~(P1_4+P1_5); //停止
break;
case 1: P1OUT|=P1_5;P1OUT&=~P1_4; //前进
break;
case 2: P1OUT|=P1_4;P1OUT&=~P1_5; //后退
break;
case 3: P1OUT|=(P1_4+P1_5); //刹车
break;
default:
break;
Pwm_Set(1,speed,PWM_TIMES);
void delay(void)
unsigned int count=0;
while(count<50000)
count++;
void delay_long(void)
int i=0;
while(i++<10)
delay();
int main( void )
WDTCTL=WDTPW + WDTHOLD;
P2DIR=0xff;
P2SEL=0x00;
P2OUT=0xff;
P1DIR=0xff;
P1SEL=0x00;
P1OUT=0x00;
Motor(0,1,50);
Motor(1,1,50); //小车前进
delay_long();
Motor(0,0,0);
Motor(1,1,50); //小车左拐弯
delay_long();
Motor(0,1,50);
Motor(1,0,0); //小车右拐弯
delay_long();
Motor(0,1,100);
Motor(1,1,100); //小车加速前进
delay_long();
Motor(0,3,50);
Motor(1,3,50); //小车刹车
delay_long();
Motor(0,2,10);
Motor(1,2,10); //小车后退
delay_long();
Motor(0,0,0);
Motor(1,0,0); //小车停止
delay_long();
return 0;
