[技术问题解答] 跪求KL25Z UART 模块程序,我的事CW10.6,不要IAR的(已解决)
1795|5
 楼主| 870205766 发表于 2014-5-8 19:35 | 显示全部楼层 |阅读模式
跪求KL25Z  UART 模块程序,我的是CW10.6,不要IAR的,只要codewarrior编译软件下的代码
FSL_TICS_A 发表于 2014-5-9 09:42 | 显示全部楼层
楼主,你好!
你可以按照快速入门手册,自己写UART程序,
同时也可以使用PE的UART组件来做,在组件中有个Help功能,可以帮你理解组件如何配置!
KLQRUG.pdf (2.04 MB, 下载次数: 35)
 楼主| 870205766 发表于 2014-5-9 10:13 | 显示全部楼层
楼主,你好!
同时也可以使用PE的UART组件来做,在组件中有个He ...
PE的UART组件哪里有呀
 楼主| 870205766 发表于 2014-5-9 10:14 | 显示全部楼层
楼主,你好!
#include "PE_Types.h"
#include "PE_Error.h"
#include "PE_Const.h"
#include "IO_Map.h"
#include "Blue_LED.h"
#include "Green_LED.h"
#include "Red_LED.h"
#include "CsIO1.h"
#include "IO1.h"
#include "PE_LDD.h"
没有发现UART 组件呀,
FSL_TICS_A 发表于 2014-5-9 10:38 | 显示全部楼层
楼主看来你对CW真的熟悉,
建议可以你可以参考一下此入门贴,熟悉一下CW,
还有KLQRUG中的UART章节对如何对UAR配置介绍的很详细啊,完全可以参考的啊!
入门贴:https://bbs.21ic.com/icview-619446-1-1.html
匿名  发表于 2014-5-13 16:30
void hw_uart_init()
        unsigned short uartclk_khz = 23961;
        unsigned short baud = 19200;
        unsigned short sbr,brfa;
        SIM_SCGC4 |= SIM_SCGC4_UART2_MASK;         /* Enable the clock to the selected UART */
        SIM_SCGC5 |= SIM_SCGC5_PORTE_MASK;         /* Turn on all port clocks */
        /* Enable the UART0_TXD function on PTE0 */
        PORTE_PCR16 = PORT_PCR_MUX(0x3); // UART is alt3 function for this pin
        /* Enable the UART0_RXD function on PTE1 */
        PORTE_PCR17 = PORT_PCR_MUX(0x3); // UART is alt3 function for this pin
        sbr = (unsigned short)((uartclk_khz *1000)/(baud * 16));
        UART2_BDH = (unsigned char)((sbr & 0x1F00) >> 8);
        UART2_BDL = (unsigned char)(sbr & 0x00FF);
        /* Determine if a fractional divider is needed to get closer to the baud rate */
        brfa = (((uartclk_khz*32000)/(baud * 16)) - (sbr * 32));
        UART2_C4 = (unsigned char)(brfa & 0x001F);
        UART2_C1 = 0;         /* Configure the UART for 8-bit mode, no parity */
        UART2_C2 |= (UART_C2_TE_MASK | UART_C2_RE_MASK );      /* Enable receiver and transmitter */
        UART2_S1|=UART_S1_RDRF_MASK;    /* receiver 中断标志位清零 */
        UART2_C2|=UART_C2_RIE_MASK;    /* Enable receiver 中断 */
        enable_irq(14);                /*开IRQ接收中断*/
//函数名称:hw_uart_re1
//参数说明:uartNo: 串口号
//          fp:接收成功标志的指针:*p=0,成功接收;*p=1,接收失败
//函数返回:接收返回字节
//功能概要:串行接收1个字节
unsigned char uart_getchar (void)
/* Wait until character has been received */
while (!(UART2_S1 & UART_S1_RDRF_MASK));
/* Return the 8-bit data from the receiver */
return UART2_D;
void uart_putchar (unsigned char data)
/* Wait until space is available in the FIFO */
while(!(UART2_S1 & UART_S1_TDRE_MASK));
/* Send the character */
UART2_D = data;
void uart_ReN (uint8* buff,uint16 len)
        int i;
        for(i=0;i<len;i++)
                buff=uart_getchar();
void uart_sendN (uint8* buff,uint16 len)
    int i;
    for(i=0;i<len;i++)
        uart_putchar(buff);
void uart_sendStr (const uint8* str)
    while(*str)
        uart_putchar(*str++);
void uart_getStrs(uint8* str)
        int i;
                for(i=0;uart_getchar()!= '\0';i++)
                        str=uart_getchar();
