手里有一些凌阳的SPHE1002A机顶盒图像解码芯片,有需要的吗
3057|0
 楼主| jetson001 发表于 2009-7-22 16:34 | 显示全部楼层 |阅读模式
官方资料链接http://w3.sunplus.com/products/STB/sphe1002.asp<br /><br />SPHE1002A<br />STB&nbsp;MPEG&nbsp;Decoder&nbsp;Single&nbsp;Chip&nbsp;<br /><br />SPHE1002&nbsp;A/V&nbsp;decoder&nbsp;is&nbsp;a&nbsp;cost&nbsp;effective&nbsp;DVB&nbsp;STB&nbsp;A/V&nbsp;decoder.&nbsp;SPHE1002&nbsp;can&nbsp;be&nbsp;applied&nbsp;in&nbsp;DVB&nbsp;STB,&nbsp;in&nbsp;Terrestrial,&nbsp;Satellite,&nbsp;and&nbsp;Cable&nbsp;fields,&nbsp;either&nbsp;in&nbsp;Free-To-Air&nbsp;or&nbsp;in&nbsp;Conditional&nbsp;Access/Common&nbsp;Interface&nbsp;applications.&nbsp;It&nbsp;integrates&nbsp;a&nbsp;MPEG-2&nbsp;Transport&nbsp;Demulitiplexer,&nbsp;a&nbsp;MPEG&nbsp;-1/-2/-4&nbsp;A/V&nbsp;decoding&nbsp;engine,&nbsp;a&nbsp;2-channel&nbsp;audio&nbsp;DAC&nbsp;and&nbsp;a&nbsp;4-channel&nbsp;multi-format&nbsp;TV-encoder.&nbsp;SPHE1002&nbsp;performs&nbsp;a&nbsp;real-time&nbsp;PID&nbsp;filtering&nbsp;of&nbsp;transport&nbsp;stream,&nbsp;decode&nbsp;and&nbsp;playback&nbsp;of&nbsp;MPEG-1&nbsp;and&nbsp;MPEG-2&nbsp;A/V&nbsp;from&nbsp;DVB&nbsp;NIM.&nbsp;Multimedia&nbsp;A/V&nbsp;functions,&nbsp;such&nbsp;as&nbsp;MPEG-1,&nbsp;MPEG-2&nbsp;and&nbsp;MPEG-4&nbsp;video&nbsp;or&nbsp;MPEGI/II&nbsp;Layer&nbsp;1/2/3&nbsp;,&nbsp;PCM&nbsp;,&nbsp;LPCM&nbsp;audio,&nbsp;can&nbsp;be&nbsp;real&nbsp;time&nbsp;decode&nbsp;and&nbsp;playback&nbsp;from&nbsp;SD/MMC/Memory&nbsp;Stick/Memory&nbsp;Stick&nbsp;Pro&nbsp;multi-in-one&nbsp;memory&nbsp;card&nbsp;or&nbsp;USB&nbsp;2.0&nbsp;Mass&nbsp;storage&nbsp;Device&nbsp;inputs&nbsp;by&nbsp;SPHE1002.&nbsp;<br /><br />...................<br /><br />有需要的给俺小纸条^_^<br />
