在1082行后增加如下代码- #elif defined SYSCLK_FREQ_108MHz
- static void SetSysClockTo108(void)
- __IO uint32_t StartUpCounter = 0, HSEStatus = 0;
- /* SYSCLK, HCLK, PCLK2 and PCLK1 configuration ---------------------------*/
- /* Enable HSE */
- RCC->CR |= ((uint32_t)RCC_CR_HSEON);
- /* Wait till HSE is ready and if Time out is reached exit */
- do
- HSEStatus = RCC->CR & RCC_CR_HSERDY;
- StartUpCounter++;
- } while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
- if ((RCC->CR & RCC_CR_HSERDY) != RESET)
- HSEStatus = (uint32_t)0x01;
- else
- HSEStatus = (uint32_t)0x00;
- if (HSEStatus == (uint32_t)0x01)
- /* HCLK = SYSCLK */
- RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
- /* PCLK2 = HCLK */
- RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE2_DIV1;
- /* PCLK1 = HCLK */
- RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV2;
- /* PLL configuration: PLLCLK = HSE/2* (15+12) = 108 MHz */
- RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE |
- RCC_CFGR_PLLMULL));
- RCC->CFGR |= (uint32_t)(0x08000000 | RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLXTPRE_HSE_Div2 | RCC_CFGR_PLLMULL12);
- /* Enable PLL */
- RCC->CR |= RCC_CR_PLLON;
- /* Wait till PLL is ready */
- while((RCC->CR & RCC_CR_PLLRDY) == 0)
- /* Select PLL as system clock source */
- RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
- RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
- /* Wait till PLL is used as system clock source */
- while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x08)
- else
- { /* If HSE fails to start-up, the application will have wrong clock
- configuration. User can add here some code to deal with this error */
- #endif
增加后如下
