[STM32] 用stm32控制Nokia5110,不知为啥无法显示
1306|0
 楼主| 辉色天空 发表于 2014-10-2 18:35 | 显示全部楼层 |阅读模式
以下是我的程序,大神看看是不是我的引脚模式配置不对,还是我的写数据命令函数,或者显示字符或字符串的函数不对,由于字节数限制,我只发了部分程序源码
#include "bsp_nokia5110_lcd.h"
#include "ascii.h"
#define WIDTH   6
#define HEIGHT  8
#define DEBUG_DELAY()
void LCD_GPIO_Config(void)
        RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA, ENABLE);
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 ;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12 ;
    GPIO_InitStructure.GPIO_Mode =  GPIO_Mode_AF_PP;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11
        GPIO_SetBits(GPIOA,GPIO_Pin_12);//
void LCD_write_byte(unsigned char dat ,unsigned char command)
        unsigned char i;
        LCD_ce_0;
        if(command==0)
                LCD_dc_0;
        else LCD_dc_1;
        for(i=0;i<8;i++)
                if(dat&0x80)
                        LCD_sdin_1;
                else
                        LCD_sdin_0;
                dat=dat<<1;
                LCD_sclk_0;
                LCD_sclk_1;
        LCD_dc_1;
        LCD_ce_1;
        LCD_sdin_1;
void delay_ms(unsigned int t)
        unsigned i,j;
        for(i=t;i>0;i--)
        for(j=110;j>0;j--);
void LCD5110_init(void)
                LCD_GPIO_Config();
        LCD_ce_1;
        LCD_rst_0;
          delay_ms(10);
          LCD_rst_1;
        delay_ms(100);
         LCD_write_byte(0x21,0);
    LCD_write_byte(0x13,0);
    LCD_write_byte(0xbb,0);
    LCD_write_byte(0x20,0);
        LCD_write_byte(0x0c,0);
    LCD_clear();
void LCD_clear(void)
        unsigned int i;
        LCD_set_XY(0,0);
        for(i=0;i<504;i++)
        LCD_write_byte(0x00,1);
void LCD_write_string(unsigned char X,unsigned char Y,char *s)
        unsigned char i=0,j=0;
    while (*s)
                                LCD_set_XY(X,Y);
        LCD_write_char(*s++);
        X+=WIDTH;
        i++;
        if(i>=(84/WIDTH))
                        X=0;
                        Y+=HEIGHT;
                        i=0;
                        j++;
                if(j>=(48/HEIGHT))
                 return  ;
#define LCD_rst_0   GPIOA->BRR=1<<7
#define LCD_rst_1   GPIOA->BSRR=1<<7
#define LCD_ce_0   GPIOA->BRR=1<<8
#define LCD_ce_1   GPIOA->BSRR=1<<8
#define LCD_dc_0   GPIOA->BRR=1<<9
#define LCD_dc_1    GPIOA->BSRR=1<<9
#define LCD_sdin_0   GPIOA->BRR=1<<10
#define LCD_sdin_1   GPIOA->BSRR=1<<10
#define LCD_sclk_0   GPIOA->BRR=1<<11
#define LCD_sclk_1   GPIOA->BSRR=1<<11
#define LCD_bl_0   GPIOA->BRR=1<<12
#define LCD_bl_1   GPIOA->BSRR=1<<12
int main(void)
        LCD5110_init();
        LCD_clear();
        while(1)
        LCD_write_string(0,0,"nakia5110");
